Germline pipeline exit in MarkDuplicate step with unknown reasons
I am analyzing the WGS data using germline pipeline. The command is:
bsub -n 24 -M 150GB -R 'gpuhost rusage[mem=150GB] span[hosts=1]' -G compute-jin810 -o /dev/null -e /storage1/fs1/jin810/Active/Qichen/test-%J.err -q general -a 'docker(nvcr.io/nvidia/clara/clara-parabricks:4.0.0-1)' -gpu "num=1:gmodel=TeslaV100_SXM2_32GB:j_exclusive=no" bash /storage1/fs1/jin810/Active/germline.sh
gremlin.sh (partial):
pbrun germline --ref "${REF}" \
			--in-fq "${fastq_r1}" "${fastq_r2}" \
			--out-variants "${out_path}"/"${sample_name}"_germline.g.vcf --gvcf \
			--knownSites "${KS1}" \
			--knownSites "${KS2}" \
			--knownSites "${KS3}" \
			--out-bam "${out_path}/${sample_name}_fq2bam_output.bam" \
			--out-recal-file "${out_recal}" \
			--out-duplicate-metrics "${out_duplicate_metrics}" \
			--bwa-options='-Y' \
			--read-group-pl ILLUMINA \
			--read-group-sm "${sample_name}" \
			--tmp-dir "${temp_dir}" \
			--num-gpus 1
The pipeline exited at MarkDuplicates step at 32% progress as show in the following log:
[PB Info 2023-Nov-12 02:29:45] ||                 Parabricks accelerated Genomics Pipeline                 ||
[PB Info 2023-Nov-12 02:29:45] ||                              Version 4.0.0-1                             ||
[PB Info 2023-Nov-12 02:29:45] ||                         Marking Duplicates, BQSR                         ||
[PB Info 2023-Nov-12 02:29:45] ------------------------------------------------------------------------------
[PB Info 2023-Nov-12 02:29:45] progressMeter -	Percentage
[PB Info 2023-Nov-12 02:29:55] 0.0	 23.91 GB
[PB Info 2023-Nov-12 02:30:05] 0.0	 39.88 GB
[PB Info 2023-Nov-12 02:30:15] 0.0	 57.18 GB
[PB Info 2023-Nov-12 02:30:25] 0.0	 73.89 GB
[PB Info 2023-Nov-12 02:30:35] 0.0	 92.22 GB
[PB Info 2023-Nov-12 02:30:45] 0.0	 106.64 GB
[PB Info 2023-Nov-12 02:30:55] 0.0	 123.36 GB
[PB Info 2023-Nov-12 02:31:05] 0.0	 138.98 GB
[PB Info 2023-Nov-12 02:31:15] 0.0	 140.03 GB
[PB Info 2023-Nov-12 02:31:25] 0.0	 140.03 GB
[PB Info 2023-Nov-12 02:31:35] 0.0	 140.03 GB
[PB Info 2023-Nov-12 02:31:45] 0.0	 140.03 GB
[PB Info 2023-Nov-12 02:31:55] 0.0	 140.03 GB
[PB Info 2023-Nov-12 02:32:05] 0.0	 140.03 GB
[PB Info 2023-Nov-12 02:32:15] 0.0	 140.03 GB
[PB Info 2023-Nov-12 02:32:25] 1.1	 141.16 GB
[PB Info 2023-Nov-12 02:32:35] 2.0	 140.86 GB
[PB Info 2023-Nov-12 02:32:45] 2.8	 140.95 GB
[PB Info 2023-Nov-12 02:32:55] 3.5	 140.54 GB
[PB Info 2023-Nov-12 02:33:05] 3.7	 141.46 GB
[PB Info 2023-Nov-12 02:33:15] 5.4	 140.24 GB
[PB Info 2023-Nov-12 02:33:25] 6.1	 140.40 GB
[PB Info 2023-Nov-12 02:33:35] 7.1	 140.57 GB
[PB Info 2023-Nov-12 02:33:45] 7.9	 140.13 GB
[PB Info 2023-Nov-12 02:33:55] 8.8	 140.39 GB
[PB Info 2023-Nov-12 02:34:05] 9.5	 140.42 GB
[PB Info 2023-Nov-12 02:34:15] 10.1	 140.85 GB
[PB Info 2023-Nov-12 02:34:25] 10.8	 140.86 GB
[PB Info 2023-Nov-12 02:34:35] 11.4	 139.91 GB
[PB Info 2023-Nov-12 02:34:45] 12.2	 140.08 GB
[PB Info 2023-Nov-12 02:34:55] 13.0	 140.96 GB
[PB Info 2023-Nov-12 02:35:05] 13.7	 141.39 GB
[PB Info 2023-Nov-12 02:35:15] 14.5	 140.11 GB
[PB Info 2023-Nov-12 02:35:25] 15.1	 141.59 GB
[PB Info 2023-Nov-12 02:35:35] 15.9	 141.06 GB
[PB Info 2023-Nov-12 02:35:45] 16.4	 140.73 GB
[PB Info 2023-Nov-12 02:35:55] 17.3	 140.33 GB
[PB Info 2023-Nov-12 02:36:05] 17.8	 141.29 GB
[PB Info 2023-Nov-12 02:36:15] 18.8	 140.49 GB
[PB Info 2023-Nov-12 02:36:25] 19.6	 141.36 GB
[PB Info 2023-Nov-12 02:36:35] 20.4	 139.70 GB
[PB Info 2023-Nov-12 02:36:45] 21.0	 140.36 GB
[PB Info 2023-Nov-12 02:36:55] 21.6	 140.41 GB
[PB Info 2023-Nov-12 02:37:05] 22.3	 140.35 GB
[PB Info 2023-Nov-12 02:37:15] 22.5	 141.23 GB
[PB Info 2023-Nov-12 02:37:25] 22.5	 141.23 GB
[PB Info 2023-Nov-12 02:37:35] 23.8	 139.88 GB
[PB Info 2023-Nov-12 02:37:45] 24.4	 140.32 GB
[PB Info 2023-Nov-12 02:37:55] 24.9	 139.76 GB
[PB Info 2023-Nov-12 02:38:05] 25.7	 141.46 GB
[PB Info 2023-Nov-12 02:38:15] 26.4	 141.56 GB
[PB Info 2023-Nov-12 02:38:25] 26.8	 141.07 GB
[PB Info 2023-Nov-12 02:38:35] 27.3	 140.02 GB
[PB Info 2023-Nov-12 02:38:45] 27.9	 140.06 GB
[PB Info 2023-Nov-12 02:38:55] 28.2	 140.04 GB
[PB Info 2023-Nov-12 02:39:05] 28.5	 141.31 GB
[PB Info 2023-Nov-12 02:39:15] 28.7	 140.37 GB
[PB Info 2023-Nov-12 02:39:25] 29.3	 140.26 GB
[PB Info 2023-Nov-12 02:39:35] 29.5	 141.28 GB
[PB Info 2023-Nov-12 02:39:45] 29.7	 140.32 GB
[PB Info 2023-Nov-12 02:39:55] 29.7	 140.32 GB
[PB Info 2023-Nov-12 02:40:05] 30.5	 140.19 GB
[PB Info 2023-Nov-12 02:40:15] 31.2	 140.65 GB
[PB Info 2023-Nov-12 02:40:25] 32.0	 140.69 GB
Nov 11 20:41:20 docker1_starter[156983]: DEBUG:       run_docker returns 255
Nov 11 20:41:20 docker1_starter[156983]: DEBUG:       Cleaning up temp files
Nov 11 20:41:20 docker1_starter[156983]: DEBUG:       About to exit 255
May I ask about the solution for this? Also, does the last column of the progressmeter show the memory in use? Thanks!
