Get a VPIIMage from NvBufferSurface
Hello, I have a working code C++ on Jetson AGX Xavier. I get image in NvBufferSurface and create an OpenCV image of type cv::cuda::GpuMat from it to make a preprocessing and pass image to an AI model. Now I would like to try to make a preprocessing with VPI instead of OpenCV. But it doesn’t work.
The working code with OpenCV looks as follows:
GstBuffer* buffer = gst_sample_get_buffer(sample); // get frame from a stream
auto gst_buffer_map_result = gst_buffer_map(buffer, &map, GST_MAP_READ);
NvBufSurface *surface{};
surface = reinterpret_cast<NvBufSurface *>(map.data);
// make a EglImage
NvBufSurfaceMapEglImage(surface, -1);
cuGraphicsEGLRegisterImage(&pCudaResource, surface->surfaceList[0].mappedAddr.eglImage, CU_GRAPHICS_MAP_RESOURCE_FLAGS_NONE);
cuGraphicsResourceGetMappedEglFrame(&eglFrame, pCudaResource, 0, 0);
// make OpenvCV image on GPU
img_gpu_aux = cv::cuda::GpuMat(cv::Size(1920, 1080), CV_8UC4, (void *)(eglFrame.frame.pArray[0]));
cv::cuda::cvtColor(img_gpu_aux, img_gpu, cv::COLOR_BGRA2BGR, 3); // remove one channel
doPreprocessing with img_gpu here…
Now I want to do the same but using VPIImage:
// try to build VPIImage from NvBufSurface
VPIIMage img_vpi;
VPIStatus err_vpi = vpiImageCreateWrapper((VPIImageData *)surface, nullptr, VPI_BACKEND_CUDA, &img_vpi);
std::cout << "err = " << vpiStatusGetName(err_vpi) << std::endl;
but I have an error “VPI_ERROR_INVALID_ARGUMENT”. It looks like that pointer conversion from surface to VPIImageData is a bad idea, because VPIImageData has a different structure. But how should I pass the pointer to memory to be wrapped?
With the best wishes,
Valeriy
It looks like you are using JetPack 5 + VPI 2, is this correct?
If yes, VPI can wrap EGLImage directly:
https://docs.nvidia.com/vpi/group__VPI__Image.html#ga895b41338ff328601a68383c7ae939d0
Thank you for your fast answer!
yes, JetPack 5 and vpi 2.
I tried to do this also like:
VPIStatus err_vpi = vpiImageCreateWrapper((VPIImageData *)eglFrame.frame.pArray[0], nullptr, VPI_BACKEND_CUDA, &img_vpi);
but it didn’t work (memory access error)
Ok, with the EGL images the following looks to work:
VPIImageData img_data;
img_data.bufferType = VPI_IMAGE_BUFFER_EGLIMAGE;
img_data.buffer.egl = surface->surfaceList[0].mappedAddr.eglImage;
VPIStatus err_vpi = vpiImageCreateWrapper(&img_data, nullptr, VPI_BACKEND_CUDA, &img_vpi);
And my question is: is it necessary to create the EGL image? Cannot I work with the NvBufSurface directly? According to VPI - Vision Programming Interface: Image there is “VPI_IMAGE_BUFFER_NVBUFFER” buffer type.
The problem looks to be solved. For someone who needs it:
NvBufSurfaceMapParams buffer_params;
NvBufSurfaceGetMapParams(surface, 0, &buffer_params);
img_data.bufferType = VPI_IMAGE_BUFFER_NVBUFFER;
img_data.buffer.fd = buffer_params.fd;
Sorry for the late update.
Yes, NvBufferSurface is also supported.
Thanks for the feedback.
