Hello everyone,
I have a custom model generate heatmap, the goal is to get the raw output tensor and visualize it using Python Binding, but I’m currently stuck in how to get the raw output tensor.
INFO: [Implicit Engine Info]: layers num: 2
0 INPUT kFLOAT input 3x512x512 <= This is input tensor shape
1 OUTPUT kFLOAT output 1x64x64 <= This is output tensor shape
As this model is similar to segmentation, so I’s trying to get raw output from class_probabilities_map
in NVDSINFER_SEGMENTATION_META
My first step is to get frame_user_meta_list
and cast it to NvDsUserMeta
like below:
l_user = frame_meta.frame_user_meta_list
user_meta = pyds.NvDsUserMeta.cast(l_user.data)
After that, I skip the user_meta that does not belong to NVDSINFER_SEGMENTATION_META
by:
if (
user_meta.base_meta.meta_type
!= pyds.NvDsMetaType.NVDSINFER_SEGMENTATION_META
continue
But unfortunately, I’m not able to get the class_probabilities_map
either from user_meta.class_probabilities_map
nor from user_meta.base_meta.class_probabilities_map
Could someone tell me how to get the class_probabilities_map
Any advice is appreciated :)
• Hardware Platform (Jetson)
• DeepStream Version (V 5.0)
• JetPack Version (V4.4)
• TensorRT Version (V 7.1.3)
• Issue Type (questions)
