• Hardware Platform (Jetson / GPU) dGPU
• DeepStream Version 6.2
• TensorRT Version
hello
Deepstream app is being developed using the pyds library provided at GitHub - NVIDIA-AI-IOT/deepstream_python_apps: DeepStream SDK Python bindings and sample applications
By the way, NvDsInferSegmentationMeta The class_map information of segmeta, which can be known through the above, can be obtained because the API (pyds.get_segmentation_masks(segmeta)) is supported, class_probabilities_map is not supported.
So, I wrote it as below, but it is not parsed well (only one value is called), so can the gloat* type be called as an API type only supported by pybind? Or can you call me if there is a code fix?
width, height, num_classes are printed well
def get_class_probabilities_map(meta):
width = meta.width
height = meta.height
num_classes = meta.classes
probabilities_ptr = meta.class_probabilities_map
probabilities = np.ctypeslib.as_array(probabilities_ptr, shape=(num_classes, height, width))
return probabilities
probabilities = get_class_probabilities_map(segmeta)
probabilities = np.array(probabilities, copy=True, order='C')
