Get compiler issue using CUDA in the OpenMP GPU offloading code
We have one OpenMP GPU offloading code (compiled using nvfortran/nvc) calling CUDA functions (compiled using nvc). It works fines with smaller cases. But when increase the array sizes, we got error for the cuda program
in function `__cudaUnregisterBinaryUtil()':
tmpxft_00003429_00000000-6_kernels.cudafe1.cpp:(.text+0x3): relocation truncated to fit: R_X86_64_PC32 against `.bss'
obj/kernels.o: in function `init()':
tmpxft_00003429_00000000-6_kernels.cudafe1.cpp:(.text+0x1b): relocation truncated to fit: R_X86_64_PC32 against `.bss'
tmpxft_00003429_00000000-6_kernels.cudafe1.cpp:(.text+0x31): relocation truncated to fit: R_X86_64_PC32 against `.bss'
tmpxft_00003429_00000000-6_kernels.cudafe1.cpp:(.text+0x45): relocation truncated to fit: R_X86_64_PC32 against `.bss
The flags such as
nvcc -shared -Xcompiler -fPIC ...
seem not to fix the issue.
Is there any similar flag “-mcmodel=medium” available for nvcc with .bss section extend to 2GB?
Thanks. /Jing
Hi Jing,
The error looks to be coming from the host code so you’d want try passing the “-mcmodel=medium” option to the host compiler via the -Xcompiler option.
-Mat
Hi Mat,
The flag “-mcmodel=medium” has been added to compiler nvfortran/nvc for the OpenMP host code and “-Xcompiler” added to nvcc for CUDA code. Without calling the cuda kernels, the OpenMP offloading code works for large cases. Do any other flags need to be added?
Thanks. /Jing
Hi Jing,
I can’t find anything in the nvcc documentation related to setting it to use the medium memory model. nvcc is developed by a different team within NVIDIA so I don’t know it’s internals, but my best guess is that the error, given the filename, is occurring in a compiler auto-generated routine to handle the unregistration of the device binary.
We can move this question over to the CUDA forums, and they may have better ideas, but as a work around, I’m wondering if you can try using nvc++ instead of nvcc? While not official, we have added some support for CUDA C++ in nvc++. No guarentee that it will work since support since full support is still under development, but might be worth a try.
Though is the array in question fixed size? If so, can you instead make it allocatable?
-Mat
Hi Mat,
nvc++ works properly though the performance seems to be a bit worse (doing some benchmarking tests)
Yes, all arrays are fixed sizes. It can be changed in the mini-app but perhaps difficult in the full code.
Thanks. /Jing
