Hiya,
I’ve been digging around for a way to get a GPU handle to a render product. The SyntheticData SdRenderVarPtr node seems promising as it can be hooked up to a viewports render product, and outputs a “cudaDeviceIndex” and “dataPtr” . According to the documentation I found here, dataPtr should be a cuda device pointer if cudaDeviceIndex is not -1.
I’ve put together some code to make use of the node similar to how omni.syntheticdata.sensors.get_rgb() and omni.syntheticdata.sensors.enable_sensors() are implemented and from what I can tell this is working as the node has reasonable outputs. The width/height are correct, cudaDeviceIndex is 0 and dataPtr seems ok. However, if I try use dataPtr in any cuda functions I get an invalid parameter error.
Here are the relevant bits of code,
# Activate SdRenderVarPtr for LdrColor render var
from omni.syntheticdata import sensors
viewport_api = ... # An omni.kit.widget.viewport.widget.ViewportAPI
render_var = "LdrColorSDPtr"
sd = sensors.get_synthetic_data()
sd.activate_node_template(render_var, 0, [viewport_api.render_product_path])
... in an update subscription (omni.kit.app.get_app().get_update_event_stream().create_subscription_to_pop)
# Get the node outputs
output_names = [
"outputs:dataPtr",
"outputs:cudaDeviceIndex",
"outputs:width",
"outputs:height",
"outputs:format",
sd.get_node_attributes(render_var, output_names, viewport_api.render_product_path)
ptr = outputs["outputs:dataPtr"]
device = outputs["outputs:cudaDeviceIndex"]
width = outputs["outputs:width"]
height = outputs["outputs:height"]
format = outputs["outputs:format"]
if device != -1:
# Call a C function (that uses cuda) with ptr, width, height, and format.
pass
Is there any advice you can give for using this node or any potential alternatives?
Cheers,
Michael
