NvDsObjectMeta has a pointer to the parent NvDsObjectMeta:
struct _NvDsObjectMeta *parent
Is there any solution how to get descendants of NvDsObjectMeta without writing own code?
• DeepStream Version
• TensorRT Version
• Hardware Platform (Jetson / GPU): GPU
• DeepStream Version: 6.0
• TensorRT Version: 8.0.1
• NVIDIA GPU Driver Version (valid for GPU only): 495.29.05
• Issue Type( questions, new requirements, bugs): questions
No, you need search in the batch meta.
I ask this question because when a secondary detector is used and its output is bbox (for example car license plate detector) , all detected objects (from a primary detector and from the secondary detector) are included in one NvDsObjectMetaList and it’s necessary to verify each obejct , if the object came from primary detector or secondary detector. I need a solution that give me all descendants of object from primary detector. There is easy way to find out what is the parent object of detected object ( struct _NvDsObjectMeta *parent
), but there is no “easy” way to know which objects are descendants of given objects.
