• DeepStream Version :5.1
Hi, everyone .
I am using “nvv4l2h264enc” to save mp4 file in pipeline
I save mp4 file every 10 seconds , After a while get “GST_MESSAGE_QOS” from “bus_call” callback ,then pipeline cann’t work
code
typedef struct _passenger_flow_info passenger_flow_info;
struct _passenger_flow_info {
// gboolean jpg_flag;
gboolean mp4_flag;
gboolean tee_file;
char filepath[FILE_NAME_SIZE];
GstElement *pipeline;
static gboolean eos_fun(passenger_flow_info *p_info) {
g_print("\nEOS\n");
GstElement *qtmux_0 = NULL, *filesink_0 = NULL, *parse_0 = NULL,
*qtmux_1 = NULL, *filesink_1 = NULL, *parse_1 = NULL,
*tee_file = NULL;
GstPad *srcpad = NULL, *sinkpad = NULL;
tee_file = gst_bin_get_by_name(GST_BIN(p_info->pipeline), "tee_file");
if (!p_info->tee_file) {
parse_1 = gst_element_factory_make("h264parse", "parse_1");
qtmux_1 = gst_element_factory_make("qtmux", "qtmux_1");
filesink_1 = gst_element_factory_make("filesink", "filesink_1");
time_t nowtime;
struct tm *p;
time(&nowtime);
p = localtime(&nowtime);
char filename[FILE_NAME_SIZE];
snprintf((char *)filename, FILE_NAME_SIZE, "%s/%02d_%02d_%02d",
p_info->filepath, p->tm_year + 1900, p->tm_mon + 1, p->tm_mday);
if (access(filename, 0) == -1)
mkdir(filename, S_IRUSR | S_IWUSR | S_IXUSR | S_IRWXG | S_IRWXO);
char mp4_path[FILE_NAME_SIZE];
snprintf((char *)mp4_path, FILE_NAME_SIZE,
"%s/video_%02d_%02d_%02d_%02d_%02d_%02d.mp4", filename,
p->tm_year + 1900, p->tm_mon + 1, p->tm_mday, p->tm_hour,
p->tm_min, p->tm_sec);
g_print("path:%s\n", mp4_path);
g_object_set(G_OBJECT(filesink_1), "location", mp4_path, NULL);
gst_bin_add_many(GST_BIN(p_info->pipeline), parse_1, qtmux_1, filesink_1,
NULL);
gst_element_link_many(parse_1, qtmux_1, filesink_1, NULL);
srcpad = gst_element_get_request_pad(tee_file, "src_1");
sinkpad = gst_element_get_static_pad(parse_1, "sink");
if (gst_pad_link(srcpad, sinkpad) != GST_PAD_LINK_OK) {
g_printerr("Failed to link tee to parse. Exiting.\n");
return -1;
gst_object_unref(srcpad);
gst_object_unref(sinkpad);
state_return(gst_element_set_state(qtmux_1, GST_STATE_PLAYING));
state_return(gst_element_set_state(filesink_1, GST_STATE_PLAYING));
state_return(gst_element_set_state(parse_1, GST_STATE_PLAYING));
gst_print("unlink\n");
parse_0 = gst_bin_get_by_name(GST_BIN(p_info->pipeline), "parse_0");
qtmux_0 = gst_bin_get_by_name(GST_BIN(p_info->pipeline), "qtmux_0");
filesink_0 = gst_bin_get_by_name(GST_BIN(p_info->pipeline), "filesink_0");
gst_element_send_event(parse_0, gst_event_new_eos());
// sinkpad = gst_element_get_static_pad(parse_0, "sink_0");
// gst_pad_send_event(sinkpad, gst_event_new_flush_stop(FALSE));
// gst_object_unref(srcpad);
state_return(gst_element_set_state(parse_0, GST_STATE_NULL));
state_return(gst_element_set_state(qtmux_0, GST_STATE_NULL));
state_return(gst_element_set_state(filesink_0, GST_STATE_NULL));
gst_bin_remove(GST_BIN(p_info->pipeline), qtmux_0);
gst_bin_remove(GST_BIN(p_info->pipeline), filesink_0);
gst_bin_remove(GST_BIN(p_info->pipeline), parse_0);
gst_object_unref(qtmux_0);
gst_object_unref(filesink_0);
gst_object_unref(parse_0);
srcpad = gst_element_get_static_pad(tee_file, "src_0");
gst_element_release_request_pad(tee_file, srcpad);
p_info->tee_file = true;
} else {
parse_0 = gst_element_factory_make("h264parse", "parse_0");
qtmux_0 = gst_element_factory_make("qtmux", "qtmux_0");
filesink_0 = gst_element_factory_make("filesink", "filesink_0");
time_t nowtime;
struct tm *p;
time(&nowtime);
g_object_set(G_OBJECT(filesink_0), "location", mp4_path, NULL);
gst_bin_add_many(GST_BIN(p_info->pipeline), parse_0, qtmux_0, filesink_0,
NULL);
gst_element_link_many(parse_0, qtmux_0, filesink_0, NULL);
srcpad = gst_element_get_request_pad(tee_file, "src_0");
sinkpad = gst_element_get_static_pad(parse_0, "sink");
return -1;
state_return(gst_element_set_state(qtmux_0, GST_STATE_PLAYING));
state_return(gst_element_set_state(filesink_0, GST_STATE_PLAYING));
state_return(gst_element_set_state(parse_0, GST_STATE_PLAYING));
parse_1 = gst_bin_get_by_name(GST_BIN(p_info->pipeline), "parse_1");
qtmux_1 = gst_bin_get_by_name(GST_BIN(p_info->pipeline), "qtmux_1");
filesink_1 = gst_bin_get_by_name(GST_BIN(p_info->pipeline), "filesink_1");
gst_element_send_event(parse_1, gst_event_new_eos());
state_return(gst_element_set_state(qtmux_1, GST_STATE_NULL));
state_return(gst_element_set_state(filesink_1, GST_STATE_NULL));
state_return(gst_element_set_state(parse_1, GST_STATE_NULL));
gst_bin_remove(GST_BIN(p_info->pipeline), qtmux_1);
gst_bin_remove(GST_BIN(p_info->pipeline), filesink_1);
gst_bin_remove(GST_BIN(p_info->pipeline), parse_1);
gst_object_unref(qtmux_1);
gst_object_unref(filesink_1);
gst_object_unref(parse_1);
srcpad = gst_element_get_static_pad(tee_file, "src_1");
p_info->tee_file = false;
return true;
int main(int argc, char *argv[]) {
GMainLoop *loop = NULL;
GstElement *streammux = NULL, *tee = NULL, *tee_file = NULL,
*nvvidconv = NULL, *nvosd = NULL, *nvosd_post = NULL,
*filter = NULL, *encoder = NULL, *rtppay = NULL, *sink = NULL,
*nvvidconv_file = NULL, *h264enc_file = NULL, *parse = NULL,
*qtmux = NULL, *filesink = NULL, *queue1 = NULL, *queue2 = NULL,
*queue3 = NULL, *queue4 = NULL, *queue5 = NULL, *queue6 = NULL,
*pgie = NULL, *tracker = NULL, *nvdsanalytics = NULL;
GstPad *sinkpad, *srcpad, *nvosd_src_pad;
GstBus *bus = NULL;
passenger_flow_info *p_info;
p_info = g_slice_alloc0(sizeof(passenger_flow_info));
// check device
int current_device = -1;
cudaGetDevice(¤t_device);
struct cudaDeviceProp prop;
cudaGetDeviceProperties(&prop, current_device);
// gst_init
gst_init(&argc, &argv);
loop = g_main_loop_new(NULL, FALSE);
p_info->pipeline = gst_pipeline_new("NN_passenger_flow");
// make some element
streammux = gst_element_factory_make("nvstreammux", "stream");
GstElement *source_bin = create_source_bin(
0,rtspurl);
pgie = gst_element_factory_make("nvinfer", "pgie-nvinfer");
tracker = gst_element_factory_make("nvtracker", "tracker");
nvdsanalytics = gst_element_factory_make("nvdsanalytics", "analytics");
nvvidconv = gst_element_factory_make("nvvideoconvert", "nvvideo-converter");
nvosd = gst_element_factory_make("nvdsosd", "nv-onscreendisplay");
tee = gst_element_factory_make("tee", "tee");
// to rtsp
nvosd_post = gst_element_factory_make("nvvideoconvert", "convertor_postosd");
encoder = gst_element_factory_make("nvv4l2h264enc", "encoder");
filter = gst_element_factory_make("capsfilter", "filter");
rtppay = gst_element_factory_make("rtph264pay", "rtppay");
sink = gst_element_factory_make("udpsink", "udpsink");
// to mp4 file
nvvidconv_file = gst_element_factory_make("nvvideoconvert", "convertor_file");
h264enc_file = gst_element_factory_make("nvv4l2h264enc", "h264enc");
tee_file = gst_element_factory_make("tee", "tee_file");
parse = gst_element_factory_make("h264parse", "parse_0");
qtmux = gst_element_factory_make("qtmux", "qtmux_0");
filesink = gst_element_factory_make("filesink", "filesink_0");
// queue
queue1 = gst_element_factory_make("queue", "queue1");
queue2 = gst_element_factory_make("queue", "queue2");
queue3 = gst_element_factory_make("queue", "queue3");
queue4 = gst_element_factory_make("queue", "queue4");
queue5 = gst_element_factory_make("queue", "queue5");
queue6 = gst_element_factory_make("queue", "queue6");
g_object_set(G_OBJECT(streammux), "width", 1920, "height", 1080, "batch-size",
1, "live-source", 1, "batched-push-timeout", 40000, NULL);
g_object_set(G_OBJECT(pgie), "config-file-path",
"nvdsanalytics_pgie_config.txt", NULL);
if (!set_tracker_properties(tracker)) {
g_printerr("Failed to set tracker properties. Exiting.\n");
return -1;
g_object_set(G_OBJECT(nvdsanalytics), "config-file",
"config_nvdsanalytics.txt", NULL);
g_object_set(G_OBJECT(encoder), "bitrate", 4000000, NULL);
g_object_set(G_OBJECT(sink), "host", "224.224.255.255", "port", 18000,
"async", false, "sync", 1, NULL);
GstCaps *caps = NULL;
caps = gst_caps_from_string("video/x-raw(memory:NVMM),format=I420");
g_object_set(G_OBJECT(filter), "caps", caps, NULL);
gst_caps_unref(caps);
g_object_set(G_OBJECT(nvvidconv_file), "qos", true, NULL);
g_object_set(G_OBJECT(h264enc_file), "qos", true, NULL);
snprintf((char *)p_info->filepath, FILE_NAME_SIZE, "tet");
time_t nowtime;
struct tm *p;
time(&nowtime);
p->tm_year + 1900, p->tm_mon + 1, p->tm_mday, p->tm_hour, p->tm_min,
p->tm_sec);
g_object_set(GST_OBJECT(filesink), "location", mp4_path, NULL);
// add elements to pipeline and link
gst_bin_add_many(GST_BIN(p_info->pipeline), source_bin, streammux, pgie,
queue1, tracker, nvdsanalytics, nvvidconv, queue2, nvosd,
tee, queue3, nvosd_post, filter, encoder, rtppay, sink,
queue4, nvvidconv_file, queue6, h264enc_file, parse,
tee_file, queue5, qtmux, filesink, NULL);
gst_element_link_many(streammux, pgie, queue1, tracker, nvdsanalytics,
nvvidconv, queue2, nvosd, tee, NULL);
gst_element_link_many(queue3, nvosd_post, filter, encoder, rtppay, sink,
NULL);
gst_element_link_many(queue4, nvvidconv_file, queue6, h264enc_file, tee_file,
NULL);
gst_element_link_many(parse, qtmux, filesink, NULL);
// link source to streammux
sinkpad = gst_element_get_request_pad(streammux, "sink_0");
srcpad = gst_element_get_static_pad(source_bin, "src");
if (!srcpad) {
g_printerr("Failed to get src pad of source bin. Exiting.\n");
return -1;
g_printerr("Failed to link source bin to stream muxer. Exiting.\n");
return -1;
// link src_0 of tee to RTSP
srcpad = gst_element_get_request_pad(tee, "src_0");
sinkpad = gst_element_get_static_pad(queue3, "sink");
g_printerr("Failed to link tee to queue3. Exiting.\n");
return -1;
// link src_1 of tee to mp4
srcpad = gst_element_get_request_pad(tee, "src_1");
sinkpad = gst_element_get_static_pad(queue4, "sink");
return -1;
// link src_1 of tee to mp4_0
sinkpad = gst_element_get_static_pad(parse, "sink");
g_printerr("Failed to link tee to queue5. Exiting.\n");
return -1;
bus = gst_pipeline_get_bus(GST_PIPELINE(p_info->pipeline));
gst_bus_add_watch(bus, bus_call, loop);
// rtsp server
GstRTSPServer *server;
GstRTSPMountPoints *mounts;
GstRTSPMediaFactory *factory;
server = gst_rtsp_server_new();
mounts = gst_rtsp_server_get_mount_points(server);
factory = gst_rtsp_media_factory_new();
g_object_set(server, "service", "8555", NULL);
gst_rtsp_media_factory_set_launch(
factory, "( udpsrc name=pay0 port=18000 buffer-size=524288 "
"caps=\"application/x-rtp, media=video, clock-rate=90000, "
"encoding-name=(string)H264, payload=96 \" )");
gst_rtsp_media_factory_set_shared(factory, TRUE);
gst_rtsp_mount_points_add_factory(mounts, "/ds-test", factory);
g_object_unref(mounts);
gst_rtsp_server_attach(server, NULL);
gst_element_set_state(p_info->pipeline, GST_STATE_PLAYING);
g_timeout_add_seconds(10, eos_fun, (passenger_flow_info *)p_info);
g_print("Running...\n");
g_main_loop_run(loop);
/* Out of the main loop, clean up nicely */
g_print("Returned, stopping playback\n");
gst_element_set_state(p_info->pipeline, GST_STATE_NULL);
g_print("Deleting pipeline\n");
gst_object_unref(GST_OBJECT(p_info->pipeline));
g_main_loop_unref(loop);
return 0;
pipeline
log
Qos
type:16777216
src:h264enc
Do you have any ideas? Looking forward to your reply
