hi,
i works on jetpack 5.0.2 with deepstream 6.1 on jetson xavier nx box.
i try to get snap images with bbox together at transfer_learning app.
i moved after_pgie_image_meta_save probe to overlay probe, but it happens segment error.
after_pgie_image_meta_save(appCtx, buf, batch_meta, index);
sorry, i tried original transfer_learning app again.
above way can works to get images, but no bbox on snap images.
i want to add a new osd src probe at inside the app to try again, like this:
osd_src_probe(GstPad * pad, GstPadProbeInfo * info, gpointer u_data)
but there is a appCtx inside of ImageMetaProducer::IPData make_ipdata probe:
ipdata.video_path = appCtx->config.multi_source_config[ipdata.video_stream_nb].uri
how should i define the appCtx in my osd_src_probe? could you pls give an advice for that?
You can refer the deepstream_app.h, or you can directly reference this header file and use the struct.
