Isaac Sim Version
4.2.0
Operating System
Ubuntu 24.04
Hi. I am trying to use ultrasonic sensor and I simply create one emiter, one firing group setting that emitter to be both emitting and recevivng, and one firing array with use_brdf = true. See below implementation:
emitter_pose = ((180, 0, 0), self._sensor_location)
adjacency = [0] result, emitter_prim = omni.kit.commands.execute(
"RangeSensorCreateUltrasonicEmitter",
path=robot_prim_path + "/UltrasonicEmitter",
per_ray_intensity=1.0,
yaw_offset = 0.0,
adjacency_list = adjacency
result, group = omni.kit.commands.execute(
"RangeSensorCreateUltrasonicFiringGroup",
path="/World/UltrasonicFiringGroup",
emitter_modes=[(0,1)],
receiver_modes=[(0,1)],
self._ultrasonic_path = "/World/UltrasonicArray"
result, self.ultrasonic = omni.kit.commands.execute(
"RangeSensorCreateUltrasonicArray",
path=self._ultrasonic_path,
# Min and max range for the ULTRASONIC. This defines the starting and stopping locations for the linetrace
min_range=1,
max_range=4.5,
# These attributes affect drawing the ultrasonic in the viewport. High Level Of Detail (HighLod) = True will draw
# all rays. If false it will only draw horizontal rays. Draw Ultrasonic Points = True will draw the actual
# ULTRASONIC rays in the viewport.
draw_points=False,
draw_lines=True,
# Horizontal and vertical resolution in degrees. Rays will be fired on the bin boundries defined by the
# resolution. If your FOV is 45 degrees and your resolution is 15 degrees, you will get rays at
# 0, 15, 30, and 45 degrees.
horizontal_fov=90.0, # set wedge vertical extent in degrees
vertical_fov=15.0, # set wedge horizontal extent in degrees
horizontal_resolution=0.9,
vertical_resolution=0.25,
num_bins=30, # number of bins that the emiiters output (numBins divides minRange to maxRange distance.)
use_brdf = True,
use_uss_materials = False,
emitter_prims=[emitter_path],
firing_group_prims=[group.GetPath()],
However, when I use get_intensity_data() to retrieve the ray intensity of each ray cast. I am getting only 255 upon hitting and 0 for non hitting. I am expecting some value to be between 0 and 255.
Is this a bug? Can you share the source code for implementing this sensor?
