Consider the official deepstream example deepstream_test1_rtsp_in_rtsp_out.py
that can be found here: deepstream_python_apps/deepstream_test1_rtsp_in_rtsp_out.py at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub
As you can see, at line 59 of the script, you can find the function tiler_src_pad_buffer_probe
. This function is not currently used in the example. You can simply double check it with a Ctrl-F.
I’d like to use that function to retrieve the metadata associated to each stream.
So far I have been able to do this:
osdsinkpad = nvosd.get_static_pad("sink")
if not osdsinkpad:
sys.stderr.write(" Unable to get sink pad of nvosd \n")
osdsinkpad.add_probe(Gst.PadProbeType.BUFFER, self.tiler_src_pad_buffer_probe, 0)
This let me retrieve the number of detections but unfortunately, since nvosd
is placed after nvmultistreamtiler
it won’t allow me to discern the streams. In fact I believe that after the nvmultistreamtiler
there will be a unique stream. In fact, frame_meta.pad_index
in function tiler_src_pad_buffer_probe
will always return 0.
I tried this:
osdsinkpad = nvosd.get_static_pad("pgie")
if not osdsinkpad:
sys.stderr.write(" Unable to get sink pad of pgie \n")
Unfortunately this does not work as it does not retrieve any metadata. It does not throw any error, but the number of people and vehicles are always 0 even if I can see that the pipeline has detected them because I see cars bounding boxes in the output rtsp stream.
How can I retrieve the metadata associated to the object detection to each stream? I’d like know the bounding boxes and detection class of each object detected in each stream.
E.g.
- stream 1 has 1 car at position x0,y0
- stream 2 has has 2 cars at position x1,y1 and x2,y2
- stream 3 has 0 cars
