Hi there,
I’m implementing deepstream-5.0 on docker in my project and I need to get car’s color and type as an output in the txt file which is generated for tracking results. (So in the tracking result I have the coloro and type of car as well.) in the source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8_gpu1.txt I just enabled all secondary-gie’s to get these info but it is not showing the results anywhere (even on the video). Would you please let me know how I can overcome this problem. I run the following command in docker to run the model: deepstream-test5-app -c source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8_gpu1.txt
