Get PTP time for image capture in NVSIPL
Software Version
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.3.10904
other
Host Machine Version
other
When we enabled profile writing with nvsipl sample, we noticed that the time logged into the CSV is not PTP time . This is the case of raw capture. Is there a way to get the PTP time of each incoming camera frame and not TSC SOF time in TSC ticks? The reason is I cannot relate the camera to the lidar frame which has PTP time embedded.
I did see the below ticket but I haven’t tried the changes recommended. Wanted to check first with Nvidia team.
Thanks!!
Jishnu
To correlate PTP time with TSC time in NVSIPL samples, you can refer to the NVPPS_GETPARAMS function as mentioned in the NvPPS document section. This function provides the necessary parameters for obtaining the correlation between PTP and TSC times.
