hi,
i want to do cascaded inference according to test app 2 from deepstream.
i have a yolo vehicle detector as primary inference(which is working fine in deepstream) and then i want to feed the cropped vehicles to the secondary model to get the license plates.
i have two questions regarding the above scenario.
1- does the pipeline automatically crop the output objects from the primary inference and feed it as input to the secondary inference model?
2- where do i find secondary model output?
my goal is to get cropped license plates that i can display with openCV or save locally.
thanks
Yes.
In metadata. gstnvinfer.cpp → attach_metadata_classifier()
Here has nvinfer process: https://devtalk.nvidia.com/default/topic/1061492/deepstream-sdk/deepstream-sdk-faq/
You can refer to dsexample plugin sample. → sources/gst-plugins/gst-dsexample
thanks for you response
my secondary model is a yolo detector not a classifier. will the attach_metadata_classifier() include cropped license plate and other meta data just like the primary model meta?
this was very helpful! i was able to adapt above sample to my yolo models.
now i have a tracker for the vehicle detector(primary) in my pipeline and i am wondering weather a correlation between the license plate and its respective vehicle through tracker ID is made automatically.
i have also added dsexample plugin to my piple line, but i have two issues regarding that.
1- on the display i always have two bboxes called obj0 and Obj1
2- i can only save full frames with opencv, but i want to access nvbufsurface of secondary model and save cropped license plates as well.
thanks
Here is metadata structure. I think you can get tracker ID from objectMeta which license plate belongs.
https://docs.nvidia.com/metropolis/deepstream/plugin-manual/index.html#page/DeepStream_Plugin_Manual%2Fdeepstream_plugin_metadata.03.2.html%23wwconnect_header
NvDsObjectMeta → object_id is the tracking ID
https://devtalk.nvidia.com/default/topic/1061492/deepstream-sdk/deepstream-sdk-faq/ → 2. Sample of customizing gst-dsexample:
