Hi pnahar,
Thanks for the reply! Followings are the output after I ran the commands.
- printenv | grep DOCKER
output is empty
- sudo kubectl config get-contexts
haonan@haonan-XPS-15-9560:~/Downloads/ClaraSDK/scripts$ sudo kubectl config get-contexts
CURRENT NAME CLUSTER AUTHINFO NAMESPACE
- snap list | grep microk8s -C 2
haonan@haonan-XPS-15-9560:~/Downloads/ClaraSDK/scripts$ snap list | grep microk8s -C 2
helm 2.14.3 124 stable snapcrafters classic
kubectl 1.15.3 1189 stable canonical* classic
microk8s v1.15.2 743 stable canonical* classic
- sudo docker version
haonan@haonan-XPS-15-9560:~/Downloads/ClaraSDK/scripts$ sudo docker version
Client: Docker Engine - Community
Version: 19.03.2
API version: 1.40
Go version: go1.12.8
Git commit: 6a30dfc
Built: Thu Aug 29 05:29:11 2019
OS/Arch: linux/amd64
Experimental: false
Server: Docker Engine - Community
Engine:
Version: 19.03.2
API version: 1.40 (minimum version 1.12)
Git commit: 6a30dfc
Built: Thu Aug 29 05:27:45 2019
Experimental: false
containerd:
Version: 1.2.6
GitCommit: 894b81a4b802e4eb2a91d1ce216b8817763c29fb
nvidia:
Version: 1.0.0-rc8
GitCommit: 425e105d5a03fabd737a126ad93d62a9eeede87f
docker-init:
Version: 0.18.0
GitCommit: fec3683
- journalctl -xe | grep “PullImage” -C 5
haonan@haonan-XPS-15-9560:~/Downloads/ClaraSDK/scripts$ journalctl -xe | grep "PullImage" -C 5
-- Logs begin at Tue 2019-08-27 07:51:42 PDT, end at Fri 2019-09-06 14:29:36 PDT. --
Sep 06 14:16:57 haonan-XPS-15-9560 microk8s.daemon-containerd[3993]: time="2019-09-06T14:16:57.709264430-07:00" level=info msg="PullImage "clara/argoui:0.2.0""
Sep 06 14:16:57 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:16:57.708620 4070 remote_image.go:113] PullImage "clara/argo-controller:0.2.0" from image service failed: rpc error: code = Unknown desc = failed to resolve image "docker.io/clara/argo-controller:0.2.0": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed
Sep 06 14:16:57 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:16:57.708737 4070 kuberuntime_image.go:51] Pull image "clara/argo-controller:0.2.0" failed: rpc error: code = Unknown desc = failed to resolve image "docker.io/clara/argo-controller:0.2.0": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed
Sep 06 14:16:57 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:16:57.708986 4070 kuberuntime_manager.go:779] container start failed: ErrImagePull: rpc error: code = Unknown desc = failed to resolve image "docker.io/clara/argo-controller:0.2.0": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed
Sep 06 14:16:57 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:16:57.709097 4070 pod_workers.go:190] Error syncing pod e2bc13cd-3f2e-477d-afed-66617af06f33 ("clara-workflow-controller-796b77b8d-bhfxz_default(e2bc13cd-3f2e-477d-afed-66617af06f33)"), skipping: failed to "StartContainer" for "controller" with ErrImagePull: "rpc error: code = Unknown desc = failed to resolve image \"docker.io/clara/argo-controller:0.2.0\": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed"
Sep 06 14:16:57 haonan-XPS-15-9560 systemd[1]: kubelet.service: Service hold-off time over, scheduling restart.
Sep 06 14:16:57 haonan-XPS-15-9560 systemd[1]: kubelet.service: Scheduled restart job, restart counter is at 66.
-- The start-up result is RESULT.
Sep 06 14:16:57 haonan-XPS-15-9560 kubelet[13834]: F0906 14:16:57.922972 13834 server.go:198] failed to load Kubelet config file /var/lib/kubelet/config.yaml, error failed to read kubelet config file "/var/lib/kubelet/config.yaml", error: open /var/lib/kubelet/config.yaml: no such file or directory
Sep 06 14:16:57 haonan-XPS-15-9560 systemd[1]: kubelet.service: Main process exited, code=exited, status=255/n/a
Sep 06 14:16:57 haonan-XPS-15-9560 systemd[1]: kubelet.service: Failed with result 'exit-code'.
Sep 06 14:16:58 haonan-XPS-15-9560 microk8s.daemon-containerd[3993]: time="2019-09-06T14:16:58.264748211-07:00" level=error msg="PullImage "clara/argoui:0.2.0" failed" error="failed to resolve image "docker.io/clara/argoui:0.2.0": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed"
Sep 06 14:16:58 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:16:58.265111 4070 remote_image.go:113] PullImage "clara/argoui:0.2.0" from image service failed: rpc error: code = Unknown desc = failed to resolve image "docker.io/clara/argoui:0.2.0": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed
Sep 06 14:16:58 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:16:58.265191 4070 kuberuntime_image.go:51] Pull image "clara/argoui:0.2.0" failed: rpc error: code = Unknown desc = failed to resolve image "docker.io/clara/argoui:0.2.0": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed
Sep 06 14:16:58 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:16:58.265324 4070 kuberuntime_manager.go:779] container start failed: ErrImagePull: rpc error: code = Unknown desc = failed to resolve image "docker.io/clara/argoui:0.2.0": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed
Sep 06 14:16:58 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:16:58.265421 4070 pod_workers.go:190] Error syncing pod 20eebe37-f431-4f68-80e4-ba33c3cf6aae ("clara-ui-58b97bc76b-pglz2_default(20eebe37-f431-4f68-80e4-ba33c3cf6aae)"), skipping: failed to "StartContainer" for "ui" with ErrImagePull: "rpc error: code = Unknown desc = failed to resolve image \"docker.io/clara/argoui:0.2.0\": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed"
Sep 06 14:17:01 haonan-XPS-15-9560 CRON[13891]: pam_unix(cron:session): session opened for user root by (uid=0)
Sep 06 14:17:01 haonan-XPS-15-9560 CRON[13898]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Sep 06 14:17:01 haonan-XPS-15-9560 CRON[13891]: pam_unix(cron:session): session closed for user root
Sep 06 14:17:07 haonan-XPS-15-9560 systemd-timesyncd[644]: Timed out waiting for reply from 91.189.91.157:123 (ntp.ubuntu.com).
Sep 06 14:17:07 haonan-XPS-15-9560 microk8s.daemon-containerd[3993]: time="2019-09-06T14:17:07.606638287-07:00" level=info msg="PullImage "clara/resultsservice:0.2.0""
Sep 06 14:17:08 haonan-XPS-15-9560 systemd[1]: kubelet.service: Service hold-off time over, scheduling restart.
Sep 06 14:17:08 haonan-XPS-15-9560 systemd[1]: kubelet.service: Scheduled restart job, restart counter is at 67.
-- Subject: Automatic restarting of a unit has been scheduled
-- Defined-By: systemd
-- Support: http://www.ubuntu.com/support
-- Unit kubelet.service has finished starting up.
Sep 06 14:17:08 haonan-XPS-15-9560 microk8s.daemon-containerd[3993]: time="2019-09-06T14:17:08.176515877-07:00" level=error msg="PullImage "clara/resultsservice:0.2.0" failed" error="failed to resolve image "docker.io/clara/resultsservice:0.2.0": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed"
Sep 06 14:17:08 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:17:08.176689 4070 remote_image.go:113] PullImage "clara/resultsservice:0.2.0" from image service failed: rpc error: code = Unknown desc = failed to resolve image "docker.io/clara/resultsservice:0.2.0": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed
Sep 06 14:17:08 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:17:08.176735 4070 kuberuntime_image.go:51] Pull image "clara/resultsservice:0.2.0" failed: rpc error: code = Unknown desc = failed to resolve image "docker.io/clara/resultsservice:0.2.0": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed
Sep 06 14:17:08 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:17:08.176911 4070 kuberuntime_manager.go:779] container start failed: ErrImagePull: rpc error: code = Unknown desc = failed to resolve image "docker.io/clara/resultsservice:0.2.0": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed
Sep 06 14:17:08 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:17:08.176949 4070 pod_workers.go:190] Error syncing pod 060bcc1a-d357-44bf-ab83-5fddb9a8c80a ("clara-results-service-58d7cdc45-mkc2j_default(060bcc1a-d357-44bf-ab83-5fddb9a8c80a)"), skipping: failed to "StartContainer" for "results-service" with ErrImagePull: "rpc error: code = Unknown desc = failed to resolve image \"docker.io/clara/resultsservice:0.2.0\": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed"
Sep 06 14:17:08 haonan-XPS-15-9560 microk8s.daemon-containerd[3993]: time="2019-09-06T14:17:08.176969199-07:00" level=info msg="PullImage "clara/platformapiserver:0.2.0""
Sep 06 14:17:08 haonan-XPS-15-9560 kubelet[13969]: F0906 14:17:08.193147 13969 server.go:198] failed to load Kubelet config file /var/lib/kubelet/config.yaml, error failed to read kubelet config file "/var/lib/kubelet/config.yaml", error: open /var/lib/kubelet/config.yaml: no such file or directory
Sep 06 14:17:08 haonan-XPS-15-9560 systemd[1]: kubelet.service: Main process exited, code=exited, status=255/n/a
Sep 06 14:17:08 haonan-XPS-15-9560 systemd[1]: kubelet.service: Failed with result 'exit-code'.
Sep 06 14:17:08 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:17:08.606382 4070 pod_workers.go:190] Error syncing pod 20eebe37-f431-4f68-80e4-ba33c3cf6aae ("clara-ui-58b97bc76b-pglz2_default(20eebe37-f431-4f68-80e4-ba33c3cf6aae)"), skipping: failed to "StartContainer" for "ui" with ImagePullBackOff: "Back-off pulling image \"clara/argoui:0.2.0\""
Sep 06 14:17:08 haonan-XPS-15-9560 microk8s.daemon-containerd[3993]: time="2019-09-06T14:17:08.759572881-07:00" level=error msg="PullImage "clara/platformapiserver:0.2.0" failed" error="failed to resolve image "docker.io/clara/platformapiserver:0.2.0": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed"
Sep 06 14:17:08 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:17:08.759839 4070 remote_image.go:113] PullImage "clara/platformapiserver:0.2.0" from image service failed: rpc error: code = Unknown desc = failed to resolve image "docker.io/clara/platformapiserver:0.2.0": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed
Sep 06 14:17:08 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:17:08.759899 4070 kuberuntime_image.go:51] Pull image "clara/platformapiserver:0.2.0" failed: rpc error: code = Unknown desc = failed to resolve image "docker.io/clara/platformapiserver:0.2.0": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed
Sep 06 14:17:08 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:17:08.760001 4070 kuberuntime_manager.go:779] container start failed: ErrImagePull: rpc error: code = Unknown desc = failed to resolve image "docker.io/clara/platformapiserver:0.2.0": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed
Sep 06 14:17:08 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:17:08.760057 4070 pod_workers.go:190] Error syncing pod 7fffe677-d713-4b94-a059-88309e26a417 ("clara-clara-platformapiserver-59dfbcd6b6-rcvtk_default(7fffe677-d713-4b94-a059-88309e26a417)"), skipping: failed to "StartContainer" for "platformapiserver" with ErrImagePull: "rpc error: code = Unknown desc = failed to resolve image \"docker.io/clara/platformapiserver:0.2.0\": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed"
Sep 06 14:17:09 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:17:09.605795 4070 pod_workers.go:190] Error syncing pod e2bc13cd-3f2e-477d-afed-66617af06f33 ("clara-workflow-controller-796b77b8d-bhfxz_default(e2bc13cd-3f2e-477d-afed-66617af06f33)"), skipping: failed to "StartContainer" for "controller" with ImagePullBackOff: "Back-off pulling image \"clara/argo-controller:0.2.0\""
Sep 06 14:17:13 haonan-XPS-15-9560 kernel: pcieport 0000:00:1d.0: AER: Corrected error received: 0000:00:1d.0
Sep 06 14:21:55 haonan-XPS-15-9560 systemd[1]: kubelet.service: Main process exited, code=exited, status=255/n/a
Sep 06 14:21:55 haonan-XPS-15-9560 systemd[1]: kubelet.service: Failed with result 'exit-code'.
Sep 06 14:21:56 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:21:56.606376 4070 pod_workers.go:190] Error syncing pod e2bc13cd-3f2e-477d-afed-66617af06f33 ("clara-workflow-controller-796b77b8d-bhfxz_default(e2bc13cd-3f2e-477d-afed-66617af06f33)"), skipping: failed to "StartContainer" for "controller" with ImagePullBackOff: "Back-off pulling image \"clara/argo-controller:0.2.0\""
Sep 06 14:22:02 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:22:02.605859 4070 pod_workers.go:190] Error syncing pod 060bcc1a-d357-44bf-ab83-5fddb9a8c80a ("clara-results-service-58d7cdc45-mkc2j_default(060bcc1a-d357-44bf-ab83-5fddb9a8c80a)"), skipping: failed to "StartContainer" for "results-service" with ImagePullBackOff: "Back-off pulling image \"clara/resultsservice:0.2.0\""
Sep 06 14:22:02 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:22:02.605884 4070 pod_workers.go:190] Error syncing pod 7fffe677-d713-4b94-a059-88309e26a417 ("clara-clara-platformapiserver-59dfbcd6b6-rcvtk_default(7fffe677-d713-4b94-a059-88309e26a417)"), skipping: failed to "StartContainer" for "platformapiserver" with ImagePullBackOff: "Back-off pulling image \"clara/platformapiserver:0.2.0\""
Sep 06 14:22:03 haonan-XPS-15-9560 microk8s.daemon-containerd[3993]: time="2019-09-06T14:22:03.606335918-07:00" level=info msg="PullImage "clara/argoui:0.2.0""
Sep 06 14:22:04 haonan-XPS-15-9560 microk8s.daemon-containerd[3993]: time="2019-09-06T14:22:04.674374892-07:00" level=error msg="PullImage "clara/argoui:0.2.0" failed" error="failed to resolve image "docker.io/clara/argoui:0.2.0": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed"
Sep 06 14:22:04 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:22:04.674842 4070 remote_image.go:113] PullImage "clara/argoui:0.2.0" from image service failed: rpc error: code = Unknown desc = failed to resolve image "docker.io/clara/argoui:0.2.0": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed
Sep 06 14:22:04 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:22:04.674942 4070 kuberuntime_image.go:51] Pull image "clara/argoui:0.2.0" failed: rpc error: code = Unknown desc = failed to resolve image "docker.io/clara/argoui:0.2.0": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed
Sep 06 14:22:04 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:22:04.675063 4070 kuberuntime_manager.go:779] container start failed: ErrImagePull: rpc error: code = Unknown desc = failed to resolve image "docker.io/clara/argoui:0.2.0": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed
Sep 06 14:22:04 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:22:04.675138 4070 pod_workers.go:190] Error syncing pod 20eebe37-f431-4f68-80e4-ba33c3cf6aae ("clara-ui-58b97bc76b-pglz2_default(20eebe37-f431-4f68-80e4-ba33c3cf6aae)"), skipping: failed to "StartContainer" for "ui" with ErrImagePull: "rpc error: code = Unknown desc = failed to resolve image \"docker.io/clara/argoui:0.2.0\": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed"
Sep 06 14:22:05 haonan-XPS-15-9560 systemd[1]: kubelet.service: Service hold-off time over, scheduling restart.
Sep 06 14:22:05 haonan-XPS-15-9560 systemd[1]: kubelet.service: Scheduled restart job, restart counter is at 96.
Sep 06 14:22:05 haonan-XPS-15-9560 kubelet[17489]: F0906 14:22:05.431556 17489 server.go:198] failed to load Kubelet config file /var/lib/kubelet/config.yaml, error failed to read kubelet config file "/var/lib/kubelet/config.yaml", error: open /var/lib/kubelet/config.yaml: no such file or directory
Sep 06 14:22:05 haonan-XPS-15-9560 systemd[1]: kubelet.service: Main process exited, code=exited, status=255/n/a
Sep 06 14:22:05 haonan-XPS-15-9560 systemd[1]: kubelet.service: Failed with result 'exit-code'.
Sep 06 14:22:09 haonan-XPS-15-9560 microk8s.daemon-containerd[3993]: time="2019-09-06T14:22:09.606523884-07:00" level=info msg="PullImage "clara/argo-controller:0.2.0""
Sep 06 14:22:10 haonan-XPS-15-9560 microk8s.daemon-containerd[3993]: time="2019-09-06T14:22:10.155148376-07:00" level=error msg="PullImage "clara/argo-controller:0.2.0" failed" error="failed to resolve image "docker.io/clara/argo-controller:0.2.0": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed"
Sep 06 14:22:10 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:22:10.156824 4070 remote_image.go:113] PullImage "clara/argo-controller:0.2.0" from image service failed: rpc error: code = Unknown desc = failed to resolve image "docker.io/clara/argo-controller:0.2.0": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed
Sep 06 14:22:10 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:22:10.156935 4070 kuberuntime_image.go:51] Pull image "clara/argo-controller:0.2.0" failed: rpc error: code = Unknown desc = failed to resolve image "docker.io/clara/argo-controller:0.2.0": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed
Sep 06 14:22:10 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:22:10.157092 4070 kuberuntime_manager.go:779] container start failed: ErrImagePull: rpc error: code = Unknown desc = failed to resolve image "docker.io/clara/argo-controller:0.2.0": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed
Sep 06 14:22:10 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:22:10.157195 4070 pod_workers.go:190] Error syncing pod e2bc13cd-3f2e-477d-afed-66617af06f33 ("clara-workflow-controller-796b77b8d-bhfxz_default(e2bc13cd-3f2e-477d-afed-66617af06f33)"), skipping: failed to "StartContainer" for "controller" with ErrImagePull: "rpc error: code = Unknown desc = failed to resolve image \"docker.io/clara/argo-controller:0.2.0\": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed"
Sep 06 14:22:15 haonan-XPS-15-9560 systemd[1]: kubelet.service: Service hold-off time over, scheduling restart.
Sep 06 14:22:15 haonan-XPS-15-9560 systemd[1]: kubelet.service: Scheduled restart job, restart counter is at 97.
Sep 06 14:22:15 haonan-XPS-15-9560 kubelet[17607]: F0906 14:22:15.508632 17607 server.go:198] failed to load Kubelet config file /var/lib/kubelet/config.yaml, error failed to read kubelet config file "/var/lib/kubelet/config.yaml", error: open /var/lib/kubelet/config.yaml: no such file or directory
Sep 06 14:22:15 haonan-XPS-15-9560 systemd[1]: kubelet.service: Main process exited, code=exited, status=255/n/a
Sep 06 14:22:15 haonan-XPS-15-9560 systemd[1]: kubelet.service: Failed with result 'exit-code'.
Sep 06 14:22:15 haonan-XPS-15-9560 microk8s.daemon-containerd[3993]: time="2019-09-06T14:22:15.606365380-07:00" level=info msg="PullImage "clara/platformapiserver:0.2.0""
Sep 06 14:22:16 haonan-XPS-15-9560 microk8s.daemon-containerd[3993]: time="2019-09-06T14:22:16.138465418-07:00" level=error msg="PullImage "clara/platformapiserver:0.2.0" failed" error="failed to resolve image "docker.io/clara/platformapiserver:0.2.0": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed"
Sep 06 14:22:16 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:22:16.138898 4070 remote_image.go:113] PullImage "clara/platformapiserver:0.2.0" from image service failed: rpc error: code = Unknown desc = failed to resolve image "docker.io/clara/platformapiserver:0.2.0": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed
Sep 06 14:22:16 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:22:16.139093 4070 kuberuntime_image.go:51] Pull image "clara/platformapiserver:0.2.0" failed: rpc error: code = Unknown desc = failed to resolve image "docker.io/clara/platformapiserver:0.2.0": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed
Sep 06 14:22:16 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:22:16.139208 4070 kuberuntime_manager.go:779] container start failed: ErrImagePull: rpc error: code = Unknown desc = failed to resolve image "docker.io/clara/platformapiserver:0.2.0": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed
Sep 06 14:22:16 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:22:16.139276 4070 pod_workers.go:190] Error syncing pod 7fffe677-d713-4b94-a059-88309e26a417 ("clara-clara-platformapiserver-59dfbcd6b6-rcvtk_default(7fffe677-d713-4b94-a059-88309e26a417)"), skipping: failed to "StartContainer" for "platformapiserver" with ErrImagePull: "rpc error: code = Unknown desc = failed to resolve image \"docker.io/clara/platformapiserver:0.2.0\": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed"
Sep 06 14:22:16 haonan-XPS-15-9560 microk8s.daemon-containerd[3993]: time="2019-09-06T14:22:16.606666653-07:00" level=info msg="PullImage "clara/resultsservice:0.2.0""
Sep 06 14:22:17 haonan-XPS-15-9560 microk8s.daemon-containerd[3993]: time="2019-09-06T14:22:17.391359032-07:00" level=error msg="PullImage "clara/resultsservice:0.2.0" failed" error="failed to resolve image "docker.io/clara/resultsservice:0.2.0": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed"
Sep 06 14:22:17 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:22:17.391858 4070 remote_image.go:113] PullImage "clara/resultsservice:0.2.0" from image service failed: rpc error: code = Unknown desc = failed to resolve image "docker.io/clara/resultsservice:0.2.0": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed
Sep 06 14:22:17 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:22:17.391964 4070 kuberuntime_image.go:51] Pull image "clara/resultsservice:0.2.0" failed: rpc error: code = Unknown desc = failed to resolve image "docker.io/clara/resultsservice:0.2.0": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed
Sep 06 14:22:17 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:22:17.392119 4070 kuberuntime_manager.go:779] container start failed: ErrImagePull: rpc error: code = Unknown desc = failed to resolve image "docker.io/clara/resultsservice:0.2.0": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed
Sep 06 14:22:17 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:22:17.392269 4070 pod_workers.go:190] Error syncing pod 060bcc1a-d357-44bf-ab83-5fddb9a8c80a ("clara-results-service-58d7cdc45-mkc2j_default(060bcc1a-d357-44bf-ab83-5fddb9a8c80a)"), skipping: failed to "StartContainer" for "results-service" with ErrImagePull: "rpc error: code = Unknown desc = failed to resolve image \"docker.io/clara/resultsservice:0.2.0\": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed"
Sep 06 14:22:17 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:22:17.606387 4070 pod_workers.go:190] Error syncing pod 20eebe37-f431-4f68-80e4-ba33c3cf6aae ("clara-ui-58b97bc76b-pglz2_default(20eebe37-f431-4f68-80e4-ba33c3cf6aae)"), skipping: failed to "StartContainer" for "ui" with ImagePullBackOff: "Back-off pulling image \"clara/argoui:0.2.0\""
Sep 06 14:22:24 haonan-XPS-15-9560 systemd[1]: Starting Message of the Day...
Sep 06 14:27:01 haonan-XPS-15-9560 kubelet[21020]: F0906 14:27:01.921839 21020 server.go:198] failed to load Kubelet config file /var/lib/kubelet/config.yaml, error failed to read kubelet config file "/var/lib/kubelet/config.yaml", error: open /var/lib/kubelet/config.yaml: no such file or directory
Sep 06 14:27:01 haonan-XPS-15-9560 systemd[1]: kubelet.service: Main process exited, code=exited, status=255/n/a
Sep 06 14:27:01 haonan-XPS-15-9560 systemd[1]: kubelet.service: Failed with result 'exit-code'.
Sep 06 14:27:02 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:27:02.605835 4070 pod_workers.go:190] Error syncing pod 060bcc1a-d357-44bf-ab83-5fddb9a8c80a ("clara-results-service-58d7cdc45-mkc2j_default(060bcc1a-d357-44bf-ab83-5fddb9a8c80a)"), skipping: failed to "StartContainer" for "results-service" with ImagePullBackOff: "Back-off pulling image \"clara/resultsservice:0.2.0\""
Sep 06 14:27:10 haonan-XPS-15-9560 microk8s.daemon-containerd[3993]: time="2019-09-06T14:27:10.605849088-07:00" level=info msg="PullImage "clara/argoui:0.2.0""
Sep 06 14:27:11 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:27:11.605912 4070 pod_workers.go:190] Error syncing pod 7fffe677-d713-4b94-a059-88309e26a417 ("clara-clara-platformapiserver-59dfbcd6b6-rcvtk_default(7fffe677-d713-4b94-a059-88309e26a417)"), skipping: failed to "StartContainer" for "platformapiserver" with ImagePullBackOff: "Back-off pulling image \"clara/platformapiserver:0.2.0\""
Sep 06 14:27:11 haonan-XPS-15-9560 microk8s.daemon-containerd[3993]: time="2019-09-06T14:27:11.970590519-07:00" level=error msg="PullImage "clara/argoui:0.2.0" failed" error="failed to resolve image "docker.io/clara/argoui:0.2.0": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed"
Sep 06 14:27:11 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:27:11.970947 4070 remote_image.go:113] PullImage "clara/argoui:0.2.0" from image service failed: rpc error: code = Unknown desc = failed to resolve image "docker.io/clara/argoui:0.2.0": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed
Sep 06 14:27:11 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:27:11.971068 4070 kuberuntime_image.go:51] Pull image "clara/argoui:0.2.0" failed: rpc error: code = Unknown desc = failed to resolve image "docker.io/clara/argoui:0.2.0": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed
Sep 06 14:27:11 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:27:11.971341 4070 kuberuntime_manager.go:779] container start failed: ErrImagePull: rpc error: code = Unknown desc = failed to resolve image "docker.io/clara/argoui:0.2.0": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed
Sep 06 14:27:11 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:27:11.971462 4070 pod_workers.go:190] Error syncing pod 20eebe37-f431-4f68-80e4-ba33c3cf6aae ("clara-ui-58b97bc76b-pglz2_default(20eebe37-f431-4f68-80e4-ba33c3cf6aae)"), skipping: failed to "StartContainer" for "ui" with ErrImagePull: "rpc error: code = Unknown desc = failed to resolve image \"docker.io/clara/argoui:0.2.0\": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed"
Sep 06 14:27:11 haonan-XPS-15-9560 microk8s.daemon-containerd[3993]: time="2019-09-06T14:27:11.971725003-07:00" level=info msg="PullImage "clara/argo-controller:0.2.0""
Sep 06 14:27:12 haonan-XPS-15-9560 systemd[1]: kubelet.service: Service hold-off time over, scheduling restart.
Sep 06 14:27:12 haonan-XPS-15-9560 systemd[1]: kubelet.service: Scheduled restart job, restart counter is at 126.
Sep 06 14:27:12 haonan-XPS-15-9560 kubelet[21153]: F0906 14:27:12.192884 21153 server.go:198] failed to load Kubelet config file /var/lib/kubelet/config.yaml, error failed to read kubelet config file "/var/lib/kubelet/config.yaml", error: open /var/lib/kubelet/config.yaml: no such file or directory
Sep 06 14:27:12 haonan-XPS-15-9560 systemd[1]: kubelet.service: Main process exited, code=exited, status=255/n/a
Sep 06 14:27:12 haonan-XPS-15-9560 systemd[1]: kubelet.service: Failed with result 'exit-code'.
Sep 06 14:27:12 haonan-XPS-15-9560 microk8s.daemon-containerd[3993]: time="2019-09-06T14:27:12.511862669-07:00" level=error msg="PullImage "clara/argo-controller:0.2.0" failed" error="failed to resolve image "docker.io/clara/argo-controller:0.2.0": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed"
Sep 06 14:27:12 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:27:12.512342 4070 remote_image.go:113] PullImage "clara/argo-controller:0.2.0" from image service failed: rpc error: code = Unknown desc = failed to resolve image "docker.io/clara/argo-controller:0.2.0": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed
Sep 06 14:27:12 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:27:12.512465 4070 kuberuntime_image.go:51] Pull image "clara/argo-controller:0.2.0" failed: rpc error: code = Unknown desc = failed to resolve image "docker.io/clara/argo-controller:0.2.0": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed
Sep 06 14:27:12 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:27:12.512630 4070 kuberuntime_manager.go:779] container start failed: ErrImagePull: rpc error: code = Unknown desc = failed to resolve image "docker.io/clara/argo-controller:0.2.0": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed
Sep 06 14:27:12 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:27:12.512742 4070 pod_workers.go:190] Error syncing pod e2bc13cd-3f2e-477d-afed-66617af06f33 ("clara-workflow-controller-796b77b8d-bhfxz_default(e2bc13cd-3f2e-477d-afed-66617af06f33)"), skipping: failed to "StartContainer" for "controller" with ErrImagePull: "rpc error: code = Unknown desc = failed to resolve image \"docker.io/clara/argo-controller:0.2.0\": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed"
Sep 06 14:27:15 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:27:15.605731 4070 pod_workers.go:190] Error syncing pod 060bcc1a-d357-44bf-ab83-5fddb9a8c80a ("clara-results-service-58d7cdc45-mkc2j_default(060bcc1a-d357-44bf-ab83-5fddb9a8c80a)"), skipping: failed to "StartContainer" for "results-service" with ImagePullBackOff: "Back-off pulling image \"clara/resultsservice:0.2.0\""
Sep 06 14:27:22 haonan-XPS-15-9560 systemd[1]: kubelet.service: Service hold-off time over, scheduling restart.
Sep 06 14:27:23 haonan-XPS-15-9560 kernel: pcieport 0000:00:1d.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
Sep 06 14:27:23 haonan-XPS-15-9560 kernel: pcieport 0000:00:1d.0: device [8086:a118] error status/mask=00001000/00002000
Sep 06 14:27:23 haonan-XPS-15-9560 kernel: pcieport 0000:00:1d.0: [12] Timeout
Sep 06 14:27:23 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:27:23.606374 4070 pod_workers.go:190] Error syncing pod 20eebe37-f431-4f68-80e4-ba33c3cf6aae ("clara-ui-58b97bc76b-pglz2_default(20eebe37-f431-4f68-80e4-ba33c3cf6aae)"), skipping: failed to "StartContainer" for "ui" with ImagePullBackOff: "Back-off pulling image \"clara/argoui:0.2.0\""
Sep 06 14:27:23 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:27:23.606621 4070 pod_workers.go:190] Error syncing pod e2bc13cd-3f2e-477d-afed-66617af06f33 ("clara-workflow-controller-796b77b8d-bhfxz_default(e2bc13cd-3f2e-477d-afed-66617af06f33)"), skipping: failed to "StartContainer" for "controller" with ImagePullBackOff: "Back-off pulling image \"clara/argo-controller:0.2.0\""
Sep 06 14:27:26 haonan-XPS-15-9560 microk8s.daemon-containerd[3993]: time="2019-09-06T14:27:26.606054888-07:00" level=info msg="PullImage "clara/platformapiserver:0.2.0""
Sep 06 14:27:27 haonan-XPS-15-9560 microk8s.daemon-containerd[3993]: time="2019-09-06T14:27:27.172501382-07:00" level=error msg="PullImage "clara/platformapiserver:0.2.0" failed" error="failed to resolve image "docker.io/clara/platformapiserver:0.2.0": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed"
Sep 06 14:27:27 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:27:27.172871 4070 remote_image.go:113] PullImage "clara/platformapiserver:0.2.0" from image service failed: rpc error: code = Unknown desc = failed to resolve image "docker.io/clara/platformapiserver:0.2.0": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed
Sep 06 14:27:27 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:27:27.172986 4070 kuberuntime_image.go:51] Pull image "clara/platformapiserver:0.2.0" failed: rpc error: code = Unknown desc = failed to resolve image "docker.io/clara/platformapiserver:0.2.0": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed
Sep 06 14:27:27 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:27:27.173129 4070 kuberuntime_manager.go:779] container start failed: ErrImagePull: rpc error: code = Unknown desc = failed to resolve image "docker.io/clara/platformapiserver:0.2.0": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed
Sep 06 14:27:27 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:27:27.173191 4070 pod_workers.go:190] Error syncing pod 7fffe677-d713-4b94-a059-88309e26a417 ("clara-clara-platformapiserver-59dfbcd6b6-rcvtk_default(7fffe677-d713-4b94-a059-88309e26a417)"), skipping: failed to "StartContainer" for "platformapiserver" with ErrImagePull: "rpc error: code = Unknown desc = failed to resolve image \"docker.io/clara/platformapiserver:0.2.0\": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed"
Sep 06 14:27:27 haonan-XPS-15-9560 microk8s.daemon-containerd[3993]: time="2019-09-06T14:27:27.604750520-07:00" level=info msg="PullImage "clara/resultsservice:0.2.0""
Sep 06 14:27:28 haonan-XPS-15-9560 microk8s.daemon-containerd[3993]: time="2019-09-06T14:27:28.141118946-07:00" level=error msg="PullImage "clara/resultsservice:0.2.0" failed" error="failed to resolve image "docker.io/clara/resultsservice:0.2.0": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed"
Sep 06 14:27:28 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:27:28.141498 4070 remote_image.go:113] PullImage "clara/resultsservice:0.2.0" from image service failed: rpc error: code = Unknown desc = failed to resolve image "docker.io/clara/resultsservice:0.2.0": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed
Sep 06 14:27:28 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:27:28.141596 4070 kuberuntime_image.go:51] Pull image "clara/resultsservice:0.2.0" failed: rpc error: code = Unknown desc = failed to resolve image "docker.io/clara/resultsservice:0.2.0": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed
Sep 06 14:27:28 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:27:28.141755 4070 kuberuntime_manager.go:779] container start failed: ErrImagePull: rpc error: code = Unknown desc = failed to resolve image "docker.io/clara/resultsservice:0.2.0": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed
Sep 06 14:27:28 haonan-XPS-15-9560 microk8s.daemon-kubelet[4070]: E0906 14:27:28.141861 4070 pod_workers.go:190] Error syncing pod 060bcc1a-d357-44bf-ab83-5fddb9a8c80a ("clara-results-service-58d7cdc45-mkc2j_default(060bcc1a-d357-44bf-ab83-5fddb9a8c80a)"), skipping: failed to "StartContainer" for "results-service" with ErrImagePull: "rpc error: code = Unknown desc = failed to resolve image \"docker.io/clara/resultsservice:0.2.0\": no available registry endpoint: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed"
Sep 06 14:27:32 haonan-XPS-15-9560 systemd[1]: kubelet.service: Service hold-off time over, scheduling restart.
Sep 06 14:27:32 haonan-XPS-15-9560 systemd[1]: kubelet.service: Scheduled restart job, restart counter is at 128.
