Here is the convert script:
trtexec --minShapes=img:8x3x352x640 \
--maxShapes=img:8x3x352x640 \
--optShapes=img:8x3x352x640 \
--shapes=img:8x3x352x640 \
--onnx=${MODEL}_noqdq.onnx \
--useDLACore=0 \
--buildDLAStandalone \
--saveEngine=${WORKDIR}/model.int8.fp16.linear.in.fp16.linear.out.standalone.bin \
--inputIOFormats=fp16:dla_linear \
--outputIOFormats=fp16:dla_linear \
--int8 --fp16 \
--verbose \
--calib=${MODEL}_precision_config_calib.cache \
--precisionConstraints=obey \
--layerPrecisions=$(cat ${MODEL}_precision_config_layer_arg.txt) \
> dla_int8_linear.log 2>&1
Here is the convert log
&&&& RUNNING TensorRT.trtexec [TensorRT v8502] # /usr/src/tensorrt/bin/trtexec --minShapes=img:8x3x352x640 --maxShapes=img:8x3x352x640 --optShapes=img:8x3x352x640 --shapes=img:8x3x352x640 --onnx=model_dync_bs1/TL_FULL_XG_qat_simplified_modified_noqdq.onnx --useDLACore=0 --buildDLAStandalone --saveEngine=model_dync_bs1/model.fp16.linearin.fp16linearout.standalone.bin --inputIOFormats=fp16:dla_linear --outputIOFormats=fp16:dla_linear --int8 --fp16 --verbose --calib=model_dync_bs1/TL_FULL_XG_qat_simplified_modified_precision_config_calib.cache --precisionConstraints=obey --layerPrecisions=/normalize_input/Conv:fp16,
[06/13/2024-10:16:05] [I] === Model Options ===
[06/13/2024-10:16:05] [I] Format: ONNX
[06/13/2024-10:16:05] [I] Model: model_dync_bs1/TL_FULL_XG_qat_simplified_modified_noqdq.onnx
[06/13/2024-10:16:05] [I] Output:
[06/13/2024-10:16:05] [I] === Build Options ===
[06/13/2024-10:16:05] [I] Max batch: explicit batch
[06/13/2024-10:16:05] [I] Memory Pools: workspace: default, dlaSRAM: default, dlaLocalDRAM: default, dlaGlobalDRAM: default
[06/13/2024-10:16:05] [I] minTiming: 1
[06/13/2024-10:16:05] [I] avgTiming: 8
[06/13/2024-10:16:05] [I] Precision: FP32+FP16+INT8 (obey precision constraints)
[06/13/2024-10:16:05] [I] LayerPrecisions: /normalize_input/Conv:fp16
[06/13/2024-10:16:05] [I] Calibration: model_dync_bs1/TL_FULL_XG_qat_simplified_modified_precision_config_calib.cache
[06/13/2024-10:16:05] [I] Refit: Disabled
[06/13/2024-10:16:05] [I] Sparsity: Disabled
[06/13/2024-10:16:05] [I] Safe mode: Disabled
[06/13/2024-10:16:05] [I] DirectIO mode: Disabled
[06/13/2024-10:16:05] [I] Restricted mode: Disabled
[06/13/2024-10:16:05] [I] Build only: Enabled
[06/13/2024-10:16:05] [I] Save engine: model_dync_bs1/model.fp16.linearin.fp16linearout.standalone.bin
[06/13/2024-10:16:05] [I] Load engine:
[06/13/2024-10:16:05] [I] Profiling verbosity: 0
[06/13/2024-10:16:05] [I] Tactic sources: Using default tactic sources
[06/13/2024-10:16:05] [I] timingCacheMode: local
[06/13/2024-10:16:05] [I] timingCacheFile:
[06/13/2024-10:16:05] [I] Heuristic: Disabled
[06/13/2024-10:16:05] [I] Preview Features: Use default preview flags.
[06/13/2024-10:16:05] [I] Input(s): fp16:+dla_linear
[06/13/2024-10:16:05] [I] Output(s): fp16:+dla_linear
[06/13/2024-10:16:05] [I] Input build shape: img=8x3x352x640+8x3x352x640+8x3x352x640
[06/13/2024-10:16:05] [I] Input calibration shape: img=8x3x352x640+8x3x352x640+8x3x352x640
[06/13/2024-10:16:05] [I] === System Options ===
[06/13/2024-10:16:05] [I] Device: 0
[06/13/2024-10:16:05] [I] DLACore: 0
[06/13/2024-10:16:05] [I] Plugins:
[06/13/2024-10:16:05] [I] === Inference Options ===
[06/13/2024-10:16:05] [I] Batch: Explicit
[06/13/2024-10:16:05] [I] Input inference shape: img=8x3x352x640
[06/13/2024-10:16:05] [I] Iterations: 10
[06/13/2024-10:16:05] [I] Duration: 3s (+ 200ms warm up)
[06/13/2024-10:16:05] [I] Sleep time: 0ms
[06/13/2024-10:16:05] [I] Idle time: 0ms
[06/13/2024-10:16:05] [I] Streams: 1
[06/13/2024-10:16:05] [I] ExposeDMA: Disabled
[06/13/2024-10:16:05] [I] Data transfers: Enabled
[06/13/2024-10:16:05] [I] Spin-wait: Disabled
[06/13/2024-10:16:05] [I] Multithreading: Disabled
[06/13/2024-10:16:05] [I] CUDA Graph: Disabled
[06/13/2024-10:16:05] [I] Separate profiling: Disabled
[06/13/2024-10:16:05] [I] Time Deserialize: Disabled
[06/13/2024-10:16:05] [I] Time Refit: Disabled
[06/13/2024-10:16:05] [I] NVTX verbosity: 0
[06/13/2024-10:16:05] [I] Persistent Cache Ratio: 0
[06/13/2024-10:16:05] [I] Inputs:
[06/13/2024-10:16:05] [I] === Reporting Options ===
[06/13/2024-10:16:05] [I] Verbose: Enabled
[06/13/2024-10:16:05] [I] Averages: 10 inferences
[06/13/2024-10:16:05] [I] Percentiles: 90,95,99
[06/13/2024-10:16:05] [I] Dump refittable layers:Disabled
[06/13/2024-10:16:05] [I] Dump output: Disabled
[06/13/2024-10:16:05] [I] Profile: Disabled
[06/13/2024-10:16:05] [I] Export timing to JSON file:
[06/13/2024-10:16:05] [I] Export output to JSON file:
[06/13/2024-10:16:05] [I] Export profile to JSON file:
[06/13/2024-10:16:05] [I] === Device Information ===
[06/13/2024-10:16:05] [I] Selected Device: Orin
[06/13/2024-10:16:05] [I] Compute Capability: 8.7
[06/13/2024-10:16:05] [I] SMs: 8
[06/13/2024-10:16:05] [I] Compute Clock Rate: 1.3 GHz
[06/13/2024-10:16:05] [I] Device Global Memory: 30592 MiB
[06/13/2024-10:16:05] [I] Shared Memory per SM: 164 KiB
[06/13/2024-10:16:05] [I] Memory Bus Width: 256 bits (ECC disabled)
[06/13/2024-10:16:05] [I] Memory Clock Rate: 0.612 GHz
[06/13/2024-10:16:05] [I] TensorRT version: 8.5.2
[06/13/2024-10:16:05] [V] [TRT] Registered plugin creator - ::BatchedNMSDynamic_TRT version 1
[06/13/2024-10:16:05] [V] [TRT] Registered plugin creator - ::BatchedNMS_TRT version 1
[06/13/2024-10:16:05] [V] [TRT] Registered plugin creator - ::BatchTilePlugin_TRT version 1
[06/13/2024-10:16:05] [V] [TRT] Registered plugin creator - ::Clip_TRT version 1
[06/13/2024-10:16:05] [V] [TRT] Registered plugin creator - ::CoordConvAC version 1
[06/13/2024-10:16:05] [V] [TRT] Registered plugin creator - ::CropAndResizeDynamic version 1
[06/13/2024-10:16:05] [V] [TRT] Registered plugin creator - ::CropAndResize version 1
[06/13/2024-10:16:05] [V] [TRT] Registered plugin creator - ::DecodeBbox3DPlugin version 1
[06/13/2024-10:16:05] [V] [TRT] Registered plugin creator - ::DetectionLayer_TRT version 1
[06/13/2024-10:16:05] [V] [TRT] Registered plugin creator - ::EfficientNMS_Explicit_TF_TRT version 1
[06/13/2024-10:16:05] [V] [TRT] Registered plugin creator - ::EfficientNMS_Implicit_TF_TRT version 1
[06/13/2024-10:16:05] [V] [TRT] Registered plugin creator - ::EfficientNMS_ONNX_TRT version 1
[06/13/2024-10:16:05] [V] [TRT] Registered plugin creator - ::EfficientNMS_TRT version 1
[06/13/2024-10:16:05] [V] [TRT] Registered plugin creator - ::FlattenConcat_TRT version 1
[06/13/2024-10:16:05] [V] [TRT] Registered plugin creator - ::GenerateDetection_TRT version 1
[06/13/2024-10:16:05] [V] [TRT] Registered plugin creator - ::GridAnchor_TRT version 1
[06/13/2024-10:16:05] [V] [TRT] Registered plugin creator - ::GridAnchorRect_TRT version 1
[06/13/2024-10:16:05] [V] [TRT] Registered plugin creator - ::GroupNorm version 1
[06/13/2024-10:16:05] [V] [TRT] Registered plugin creator - ::InstanceNormalization_TRT version 1
[06/13/2024-10:16:05] [V] [TRT] Registered plugin creator - ::InstanceNormalization_TRT version 2
[06/13/2024-10:16:05] [V] [TRT] Registered plugin creator - ::LayerNorm version 1
[06/13/2024-10:16:05] [V] [TRT] Registered plugin creator - ::LReLU_TRT version 1
[06/13/2024-10:16:05] [V] [TRT] Registered plugin creator - ::MultilevelCropAndResize_TRT version 1
[06/13/2024-10:16:05] [V] [TRT] Registered plugin creator - ::MultilevelProposeROI_TRT version 1
[06/13/2024-10:16:05] [V] [TRT] Registered plugin creator - ::MultiscaleDeformableAttnPlugin_TRT version 1
[06/13/2024-10:16:05] [V] [TRT] Registered plugin creator - ::NMSDynamic_TRT version 1
[06/13/2024-10:16:05] [V] [TRT] Registered plugin creator - ::NMS_TRT version 1
[06/13/2024-10:16:05] [V] [TRT] Registered plugin creator - ::Normalize_TRT version 1
[06/13/2024-10:16:05] [V] [TRT] Registered plugin creator - ::PillarScatterPlugin version 1
[06/13/2024-10:16:05] [V] [TRT] Registered plugin creator - ::PriorBox_TRT version 1
[06/13/2024-10:16:05] [V] [TRT] Registered plugin creator - ::ProposalDynamic version 1
[06/13/2024-10:16:05] [V] [TRT] Registered plugin creator - ::ProposalLayer_TRT version 1
[06/13/2024-10:16:05] [V] [TRT] Registered plugin creator - ::Proposal version 1
[06/13/2024-10:16:05] [V] [TRT] Registered plugin creator - ::PyramidROIAlign_TRT version 1
[06/13/2024-10:16:05] [V] [TRT] Registered plugin creator - ::Region_TRT version 1
[06/13/2024-10:16:05] [V] [TRT] Registered plugin creator - ::Reorg_TRT version 1
[06/13/2024-10:16:05] [V] [TRT] Registered plugin creator - ::ResizeNearest_TRT version 1
[06/13/2024-10:16:05] [V] [TRT] Registered plugin creator - ::ROIAlign_TRT version 1
[06/13/2024-10:16:05] [V] [TRT] Registered plugin creator - ::RPROI_TRT version 1
[06/13/2024-10:16:05] [V] [TRT] Registered plugin creator - ::ScatterND version 1
[06/13/2024-10:16:05] [V] [TRT] Registered plugin creator - ::SeqLen2Spatial version 1
[06/13/2024-10:16:05] [V] [TRT] Registered plugin creator - ::SpecialSlice_TRT version 1
[06/13/2024-10:16:05] [V] [TRT] Registered plugin creator - ::SplitGeLU version 1
[06/13/2024-10:16:05] [V] [TRT] Registered plugin creator - ::Split version 1
[06/13/2024-10:16:05] [V] [TRT] Registered plugin creator - ::VoxelGeneratorPlugin version 1
[06/13/2024-10:16:06] [I] [TRT] [MemUsageChange] Init CUDA: CPU +220, GPU +0, now: CPU 249, GPU 7620 (MiB)
[06/13/2024-10:16:06] [V] [TRT] Trying to load shared library libnvinfer_builder_resource.so.8.5.2
[06/13/2024-10:16:06] [V] [TRT] Loaded shared library libnvinfer_builder_resource.so.8.5.2
[06/13/2024-10:16:09] [I] [TRT] [MemUsageChange] Init builder kernel library: CPU +302, GPU +418, now: CPU 574, GPU 8058 (MiB)
[06/13/2024-10:16:09] [I] Start parsing network model
[06/13/2024-10:16:09] [I] [TRT] ----------------------------------------------------------------
[06/13/2024-10:16:09] [I] [TRT] Input filename: model_dync_bs1/TL_FULL_XG_qat_simplified_modified_noqdq.onnx
[06/13/2024-10:16:09] [I] [TRT] ONNX IR version: 0.0.9
[06/13/2024-10:16:09] [I] [TRT] Opset version: 13
[06/13/2024-10:16:09] [I] [TRT] Producer name:
[06/13/2024-10:16:09] [I] [TRT] Producer version:
[06/13/2024-10:16:09] [I] [TRT] Domain:
[06/13/2024-10:16:09] [I] [TRT] Model version: 0
[06/13/2024-10:16:09] [I] [TRT] Doc string:
[06/13/2024-10:16:09] [V] [TRT] Plugin creator already registered - ::BatchedNMSDynamic_TRT version 1
[06/13/2024-10:16:09] [V] [TRT] Plugin creator already registered - ::BatchedNMS_TRT version 1
[06/13/2024-10:16:09] [V] [TRT] Plugin creator already registered - ::BatchTilePlugin_TRT version 1
[06/13/2024-10:16:09] [V] [TRT] Plugin creator already registered - ::Clip_TRT version 1
[06/13/2024-10:16:09] [V] [TRT] Plugin creator already registered - ::CoordConvAC version 1
[06/13/2024-10:16:09] [V] [TRT] Plugin creator already registered - ::CropAndResizeDynamic version 1
[06/13/2024-10:16:09] [V] [TRT] Plugin creator already registered - ::CropAndResize version 1
[06/13/2024-10:16:09] [V] [TRT] Plugin creator already registered - ::DecodeBbox3DPlugin version 1
[06/13/2024-10:16:09] [V] [TRT] Plugin creator already registered - ::DetectionLayer_TRT version 1
[06/13/2024-10:16:09] [V] [TRT] Plugin creator already registered - ::EfficientNMS_Explicit_TF_TRT version 1
[06/13/2024-10:16:09] [V] [TRT] Plugin creator already registered - ::EfficientNMS_Implicit_TF_TRT version 1
[06/13/2024-10:16:09] [V] [TRT] Plugin creator already registered - ::EfficientNMS_ONNX_TRT version 1
[06/13/2024-10:16:09] [V] [TRT] Plugin creator already registered - ::EfficientNMS_TRT version 1
[06/13/2024-10:16:09] [V] [TRT] Plugin creator already registered - ::FlattenConcat_TRT version 1
[06/13/2024-10:16:09] [V] [TRT] Plugin creator already registered - ::GenerateDetection_TRT version 1
[06/13/2024-10:16:09] [V] [TRT] Plugin creator already registered - ::GridAnchor_TRT version 1
[06/13/2024-10:16:09] [V] [TRT] Plugin creator already registered - ::GridAnchorRect_TRT version 1
[06/13/2024-10:16:09] [V] [TRT] Plugin creator already registered - ::GroupNorm version 1
[06/13/2024-10:16:09] [V] [TRT] Plugin creator already registered - ::InstanceNormalization_TRT version 1
[06/13/2024-10:16:09] [V] [TRT] Plugin creator already registered - ::InstanceNormalization_TRT version 2
[06/13/2024-10:16:09] [V] [TRT] Plugin creator already registered - ::LayerNorm version 1
[06/13/2024-10:16:09] [V] [TRT] Plugin creator already registered - ::LReLU_TRT version 1
[06/13/2024-10:16:09] [V] [TRT] Plugin creator already registered - ::MultilevelCropAndResize_TRT version 1
[06/13/2024-10:16:09] [V] [TRT] Plugin creator already registered - ::MultilevelProposeROI_TRT version 1
[06/13/2024-10:16:09] [V] [TRT] Plugin creator already registered - ::MultiscaleDeformableAttnPlugin_TRT version 1
[06/13/2024-10:16:09] [V] [TRT] Plugin creator already registered - ::NMSDynamic_TRT version 1
[06/13/2024-10:16:09] [V] [TRT] Plugin creator already registered - ::NMS_TRT version 1
[06/13/2024-10:16:09] [V] [TRT] Plugin creator already registered - ::Normalize_TRT version 1
[06/13/2024-10:16:09] [V] [TRT] Plugin creator already registered - ::PillarScatterPlugin version 1
[06/13/2024-10:16:09] [V] [TRT] Plugin creator already registered - ::PriorBox_TRT version 1
[06/13/2024-10:16:09] [V] [TRT] Plugin creator already registered - ::ProposalDynamic version 1
[06/13/2024-10:16:09] [V] [TRT] Plugin creator already registered - ::ProposalLayer_TRT version 1
[06/13/2024-10:16:09] [V] [TRT] Plugin creator already registered - ::Proposal version 1
[06/13/2024-10:16:09] [V] [TRT] Plugin creator already registered - ::PyramidROIAlign_TRT version 1
[06/13/2024-10:16:09] [V] [TRT] Plugin creator already registered - ::Region_TRT version 1
[06/13/2024-10:16:09] [V] [TRT] Plugin creator already registered - ::Reorg_TRT version 1
[06/13/2024-10:16:09] [V] [TRT] Plugin creator already registered - ::ResizeNearest_TRT version 1
[06/13/2024-10:16:09] [V] [TRT] Plugin creator already registered - ::ROIAlign_TRT version 1
[06/13/2024-10:16:09] [V] [TRT] Plugin creator already registered - ::RPROI_TRT version 1
[06/13/2024-10:16:09] [V] [TRT] Plugin creator already registered - ::ScatterND version 1
[06/13/2024-10:16:09] [V] [TRT] Plugin creator already registered - ::SeqLen2Spatial version 1
[06/13/2024-10:16:09] [V] [TRT] Plugin creator already registered - ::SpecialSlice_TRT version 1
[06/13/2024-10:16:09] [V] [TRT] Plugin creator already registered - ::SplitGeLU version 1
[06/13/2024-10:16:09] [V] [TRT] Plugin creator already registered - ::Split version 1
[06/13/2024-10:16:09] [V] [TRT] Plugin creator already registered - ::VoxelGeneratorPlugin version 1
[06/13/2024-10:16:09] [V] [TRT] Adding network input: img with dtype: float32, dimensions: (-1, 3, 352, 640)
[06/13/2024-10:16:09] [V] [TRT] Registering tensor: img for ONNX tensor: img
[06/13/2024-10:16:09] [V] [TRT] Importing initializer: normalize_input.weight
[06/13/2024-10:16:09] [V] [TRT] Importing initializer: normalize_input.bias
[06/13/2024-10:16:09] [V] [TRT] Importing initializer: onnx::QuantizeLinear_1775
[06/13/2024-10:16:09] [V] [TRT] Importing initializer: _v_792
[06/13/2024-10:16:09] [V] [TRT] Importing initializer: onnx::QuantizeLinear_1786
[06/13/2024-10:16:09] [V] [TRT] Importing initializer: _v_795
[06/13/2024-10:16:09] [V] [TRT] Importing initializer: onnx::QuantizeLinear_1797
[06/13/2024-10:16:09] [V] [TRT] Importing initializer: _v_798
[06/13/2024-10:16:09] [V] [TRT] Importing initializer: onnx::QuantizeLinear_1808
[06/13/2024-10:16:09] [V] [TRT] Importing initializer: _v_801
[06/13/2024-10:16:09] [V] [TRT] Importing initializer: onnx::QuantizeLinear_1830
[06/13/2024-10:16:09] [V] [TRT] Importing initializer: _v_807
[06/13/2024-10:16:09] [V] [TRT] Importing initializer: onnx::QuantizeLinear_1819
[06/13/2024-10:16:09] [V] [TRT] Importing initializer: _v_804
[06/13/2024-10:16:09] [V] [TRT] Importing initializer: onnx::QuantizeLinear_1842
[06/13/2024-10:16:09] [V] [TRT] Importing initializer: _v_810
[06/13/2024-10:16:09] [V] [TRT] Importing initializer: onnx::QuantizeLinear_1853
[06/13/2024-10:16:09] [V] [TRT] Importing initializer: _v_813
[06/13/2024-10:16:09] [V] [TRT] Importing initializer: onnx::QuantizeLinear_1866
[06/13/2024-10:16:09] [V] [TRT] Importing initializer: _v_816
[06/13/2024-10:16:09] [V] [TRT] Importing initializer: onnx::QuantizeLinear_1888
[06/13/2024-10:16:09] [V] [TRT] Importing initializer: _v_822
[06/13/2024-10:16:09] [V] [TRT] Importing initializer: onnx::QuantizeLinear_1910
[06/13/2024-10:16:09] [V] [TRT] Importing initializer: _v_828
[06/13/2024-10:16:09] [V] [TRT] Importing initializer: onnx::QuantizeLinear_1899
[06/13/2024-10:16:09] [V] [TRT] Importing initializer: _v_825
[06/13/2024-10:16:09] [V] [TRT] Importing initializer: onnx::QuantizeLinear_1922
[06/13/2024-10:16:09] [V] [TRT] Importing initializer: _v_831
[06/13/2024-10:16:09] [V] [TRT] Importing initializer: onnx::QuantizeLinear_1933
[06/13/2024-10:16:09] [V] [TRT] Importing initializer: _v_834
[06/13/2024-10:16:09] [V] [TRT] Importing initializer: onnx::QuantizeLinear_1946
[06/13/2024-10:16:09] [V] [TRT] Importing initializer: _v_837
[06/13/2024-10:16:09] [V] [TRT] Parsing node: /normalize_input/Conv [Conv]
[06/13/2024-10:16:09] [V] [TRT] Searching for input: img
[06/13/2024-10:16:09] [V] [TRT] Searching for input: normalize_input.weight
[06/13/2024-10:16:09] [V] [TRT] Searching for input: normalize_input.bias
[06/13/2024-10:16:09] [V] [TRT] /normalize_input/Conv [Conv] inputs: [img -> (-1, 3, 352, 640)[FLOAT]], [normalize_input.weight -> (3, 1, 1, 1)[FLOAT]], [normalize_input.bias -> (3)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Convolution input dimensions: (-1, 3, 352, 640)
[06/13/2024-10:16:09] [V] [TRT] Registering layer: /normalize_input/Conv for ONNX node: /normalize_input/Conv
[06/13/2024-10:16:09] [V] [TRT] Using kernel: (1, 1), strides: (1, 1), prepadding: (0, 0), postpadding: (0, 0), dilations: (1, 1), numOutputs: 3
[06/13/2024-10:16:09] [V] [TRT] Convolution output dimensions: (-1, 3, 352, 640)
[06/13/2024-10:16:09] [V] [TRT] Registering tensor: /normalize_input/Conv_output_0 for ONNX tensor: /normalize_input/Conv_output_0
[06/13/2024-10:16:09] [V] [TRT] /normalize_input/Conv [Conv] outputs: [/normalize_input/Conv_output_0 -> (-1, 3, 352, 640)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Parsing node: /backbone_base_base_layer_0/Conv [Conv]
[06/13/2024-10:16:09] [V] [TRT] Searching for input: /normalize_input/Conv_output_0
[06/13/2024-10:16:09] [V] [TRT] Searching for input: onnx::QuantizeLinear_1775
[06/13/2024-10:16:09] [V] [TRT] Searching for input: _v_792
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_base_layer_0/Conv [Conv] inputs: [/normalize_input/Conv_output_0 -> (-1, 3, 352, 640)[FLOAT]], [onnx::QuantizeLinear_1775 -> (16, 3, 3, 3)[FLOAT]], [_v_792 -> (16)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Registering layer: /backbone_base_base_layer_0/Conv for ONNX node: /backbone_base_base_layer_0/Conv
[06/13/2024-10:16:09] [V] [TRT] Using kernel: (3, 3), strides: (2, 2), prepadding: (1, 1), postpadding: (1, 1), dilations: (1, 1), numOutputs: 16
[06/13/2024-10:16:09] [V] [TRT] Convolution output dimensions: (-1, 16, 176, 320)
[06/13/2024-10:16:09] [V] [TRT] Registering tensor: /backbone_base_base_layer_0/Conv_output_0 for ONNX tensor: /backbone_base_base_layer_0/Conv_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_base_layer_0/Conv [Conv] outputs: [/backbone_base_base_layer_0/Conv_output_0 -> (-1, 16, 176, 320)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Parsing node: /backbone_base_base_layer_0/Relu [Relu]
[06/13/2024-10:16:09] [V] [TRT] Searching for input: /backbone_base_base_layer_0/Conv_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_base_layer_0/Relu [Relu] inputs: [/backbone_base_base_layer_0/Conv_output_0 -> (-1, 16, 176, 320)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Registering layer: /backbone_base_base_layer_0/Relu for ONNX node: /backbone_base_base_layer_0/Relu
[06/13/2024-10:16:09] [V] [TRT] Registering tensor: /backbone_base_base_layer_0/Relu_output_0 for ONNX tensor: /backbone_base_base_layer_0/Relu_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_base_layer_0/Relu [Relu] outputs: [/backbone_base_base_layer_0/Relu_output_0 -> (-1, 16, 176, 320)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Parsing node: /backbone_base_level0_0/Conv [Conv]
[06/13/2024-10:16:09] [V] [TRT] Searching for input: /backbone_base_base_layer_0/Relu_output_0
[06/13/2024-10:16:09] [V] [TRT] Searching for input: onnx::QuantizeLinear_1786
[06/13/2024-10:16:09] [V] [TRT] Searching for input: _v_795
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level0_0/Conv [Conv] inputs: [/backbone_base_base_layer_0/Relu_output_0 -> (-1, 16, 176, 320)[FLOAT]], [onnx::QuantizeLinear_1786 -> (16, 16, 3, 3)[FLOAT]], [_v_795 -> (16)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Convolution input dimensions: (-1, 16, 176, 320)
[06/13/2024-10:16:09] [V] [TRT] Registering layer: /backbone_base_level0_0/Conv for ONNX node: /backbone_base_level0_0/Conv
[06/13/2024-10:16:09] [V] [TRT] Using kernel: (3, 3), strides: (1, 1), prepadding: (1, 1), postpadding: (1, 1), dilations: (1, 1), numOutputs: 16
[06/13/2024-10:16:09] [V] [TRT] Registering tensor: /backbone_base_level0_0/Conv_output_0 for ONNX tensor: /backbone_base_level0_0/Conv_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level0_0/Conv [Conv] outputs: [/backbone_base_level0_0/Conv_output_0 -> (-1, 16, 176, 320)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Parsing node: /backbone_base_level0_0/Relu [Relu]
[06/13/2024-10:16:09] [V] [TRT] Searching for input: /backbone_base_level0_0/Conv_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level0_0/Relu [Relu] inputs: [/backbone_base_level0_0/Conv_output_0 -> (-1, 16, 176, 320)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Registering layer: /backbone_base_level0_0/Relu for ONNX node: /backbone_base_level0_0/Relu
[06/13/2024-10:16:09] [V] [TRT] Registering tensor: /backbone_base_level0_0/Relu_output_0 for ONNX tensor: /backbone_base_level0_0/Relu_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level0_0/Relu [Relu] outputs: [/backbone_base_level0_0/Relu_output_0 -> (-1, 16, 176, 320)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Parsing node: /backbone_base_level1_0/Conv [Conv]
[06/13/2024-10:16:09] [V] [TRT] Searching for input: /backbone_base_level0_0/Relu_output_0
[06/13/2024-10:16:09] [V] [TRT] Searching for input: onnx::QuantizeLinear_1797
[06/13/2024-10:16:09] [V] [TRT] Searching for input: _v_798
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level1_0/Conv [Conv] inputs: [/backbone_base_level0_0/Relu_output_0 -> (-1, 16, 176, 320)[FLOAT]], [onnx::QuantizeLinear_1797 -> (32, 16, 3, 3)[FLOAT]], [_v_798 -> (32)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Registering layer: /backbone_base_level1_0/Conv for ONNX node: /backbone_base_level1_0/Conv
[06/13/2024-10:16:09] [V] [TRT] Using kernel: (3, 3), strides: (1, 1), prepadding: (1, 1), postpadding: (1, 1), dilations: (1, 1), numOutputs: 32
[06/13/2024-10:16:09] [V] [TRT] Convolution output dimensions: (-1, 32, 176, 320)
[06/13/2024-10:16:09] [V] [TRT] Registering tensor: /backbone_base_level1_0/Conv_output_0 for ONNX tensor: /backbone_base_level1_0/Conv_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level1_0/Conv [Conv] outputs: [/backbone_base_level1_0/Conv_output_0 -> (-1, 32, 176, 320)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Parsing node: /backbone_base_level1_0/Relu [Relu]
[06/13/2024-10:16:09] [V] [TRT] Searching for input: /backbone_base_level1_0/Conv_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level1_0/Relu [Relu] inputs: [/backbone_base_level1_0/Conv_output_0 -> (-1, 32, 176, 320)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Registering layer: /backbone_base_level1_0/Relu for ONNX node: /backbone_base_level1_0/Relu
[06/13/2024-10:16:09] [V] [TRT] Registering tensor: /backbone_base_level1_0/Relu_output_0 for ONNX tensor: /backbone_base_level1_0/Relu_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level1_0/Relu [Relu] outputs: [/backbone_base_level1_0/Relu_output_0 -> (-1, 32, 176, 320)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Parsing node: /backbone_base_level2_tree1_conv1/Conv [Conv]
[06/13/2024-10:16:09] [V] [TRT] Searching for input: /backbone_base_level1_0/Relu_output_0
[06/13/2024-10:16:09] [V] [TRT] Searching for input: onnx::QuantizeLinear_1808
[06/13/2024-10:16:09] [V] [TRT] Searching for input: _v_801
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level2_tree1_conv1/Conv [Conv] inputs: [/backbone_base_level1_0/Relu_output_0 -> (-1, 32, 176, 320)[FLOAT]], [onnx::QuantizeLinear_1808 -> (48, 32, 3, 3)[FLOAT]], [_v_801 -> (48)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Convolution input dimensions: (-1, 32, 176, 320)
[06/13/2024-10:16:09] [V] [TRT] Registering layer: /backbone_base_level2_tree1_conv1/Conv for ONNX node: /backbone_base_level2_tree1_conv1/Conv
[06/13/2024-10:16:09] [V] [TRT] Using kernel: (3, 3), strides: (2, 2), prepadding: (1, 1), postpadding: (1, 1), dilations: (1, 1), numOutputs: 48
[06/13/2024-10:16:09] [V] [TRT] Convolution output dimensions: (-1, 48, 88, 160)
[06/13/2024-10:16:09] [V] [TRT] Registering tensor: /backbone_base_level2_tree1_conv1/Conv_output_0 for ONNX tensor: /backbone_base_level2_tree1_conv1/Conv_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level2_tree1_conv1/Conv [Conv] outputs: [/backbone_base_level2_tree1_conv1/Conv_output_0 -> (-1, 48, 88, 160)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Parsing node: /backbone_base_level2_downsample/MaxPool [MaxPool]
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level2_downsample/MaxPool [MaxPool] inputs: [/backbone_base_level1_0/Relu_output_0 -> (-1, 32, 176, 320)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Registering layer: /backbone_base_level2_downsample/MaxPool for ONNX node: /backbone_base_level2_downsample/MaxPool
[06/13/2024-10:16:09] [V] [TRT] Registering tensor: /backbone_base_level2_downsample/MaxPool_output_0 for ONNX tensor: /backbone_base_level2_downsample/MaxPool_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level2_downsample/MaxPool [MaxPool] outputs: [/backbone_base_level2_downsample/MaxPool_output_0 -> (-1, 32, 88, 160)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Parsing node: /backbone_base_level2_tree1_conv1/Relu [Relu]
[06/13/2024-10:16:09] [V] [TRT] Searching for input: /backbone_base_level2_tree1_conv1/Conv_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level2_tree1_conv1/Relu [Relu] inputs: [/backbone_base_level2_tree1_conv1/Conv_output_0 -> (-1, 48, 88, 160)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Registering layer: /backbone_base_level2_tree1_conv1/Relu for ONNX node: /backbone_base_level2_tree1_conv1/Relu
[06/13/2024-10:16:09] [V] [TRT] Registering tensor: /backbone_base_level2_tree1_conv1/Relu_output_0 for ONNX tensor: /backbone_base_level2_tree1_conv1/Relu_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level2_tree1_conv1/Relu [Relu] outputs: [/backbone_base_level2_tree1_conv1/Relu_output_0 -> (-1, 48, 88, 160)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Parsing node: /backbone_base_level2_project_0/Conv [Conv]
[06/13/2024-10:16:09] [V] [TRT] Searching for input: /backbone_base_level2_downsample/MaxPool_output_0
[06/13/2024-10:16:09] [V] [TRT] Searching for input: onnx::QuantizeLinear_1830
[06/13/2024-10:16:09] [V] [TRT] Searching for input: _v_807
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level2_project_0/Conv [Conv] inputs: [/backbone_base_level2_downsample/MaxPool_output_0 -> (-1, 32, 88, 160)[FLOAT]], [onnx::QuantizeLinear_1830 -> (48, 32, 1, 1)[FLOAT]], [_v_807 -> (48)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Convolution input dimensions: (-1, 32, 88, 160)
[06/13/2024-10:16:09] [V] [TRT] Registering layer: /backbone_base_level2_project_0/Conv for ONNX node: /backbone_base_level2_project_0/Conv
[06/13/2024-10:16:09] [V] [TRT] Using kernel: (1, 1), strides: (1, 1), prepadding: (0, 0), postpadding: (0, 0), dilations: (1, 1), numOutputs: 48
[06/13/2024-10:16:09] [V] [TRT] Registering tensor: /backbone_base_level2_project_0/Conv_output_0 for ONNX tensor: /backbone_base_level2_project_0/Conv_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level2_project_0/Conv [Conv] outputs: [/backbone_base_level2_project_0/Conv_output_0 -> (-1, 48, 88, 160)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Parsing node: /backbone_base_level2_tree1_conv2/Conv [Conv]
[06/13/2024-10:16:09] [V] [TRT] Searching for input: /backbone_base_level2_tree1_conv1/Relu_output_0
[06/13/2024-10:16:09] [V] [TRT] Searching for input: onnx::QuantizeLinear_1819
[06/13/2024-10:16:09] [V] [TRT] Searching for input: _v_804
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level2_tree1_conv2/Conv [Conv] inputs: [/backbone_base_level2_tree1_conv1/Relu_output_0 -> (-1, 48, 88, 160)[FLOAT]], [onnx::QuantizeLinear_1819 -> (48, 48, 3, 3)[FLOAT]], [_v_804 -> (48)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Convolution input dimensions: (-1, 48, 88, 160)
[06/13/2024-10:16:09] [V] [TRT] Registering layer: /backbone_base_level2_tree1_conv2/Conv for ONNX node: /backbone_base_level2_tree1_conv2/Conv
[06/13/2024-10:16:09] [V] [TRT] Using kernel: (3, 3), strides: (1, 1), prepadding: (1, 1), postpadding: (1, 1), dilations: (1, 1), numOutputs: 48
[06/13/2024-10:16:09] [V] [TRT] Registering tensor: /backbone_base_level2_tree1_conv2/Conv_output_0 for ONNX tensor: /backbone_base_level2_tree1_conv2/Conv_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level2_tree1_conv2/Conv [Conv] outputs: [/backbone_base_level2_tree1_conv2/Conv_output_0 -> (-1, 48, 88, 160)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Parsing node: /backbone_base_level2_tree1_Add/Add [Add]
[06/13/2024-10:16:09] [V] [TRT] Searching for input: /backbone_base_level2_tree1_conv2/Conv_output_0
[06/13/2024-10:16:09] [V] [TRT] Searching for input: /backbone_base_level2_project_0/Conv_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level2_tree1_Add/Add [Add] inputs: [/backbone_base_level2_tree1_conv2/Conv_output_0 -> (-1, 48, 88, 160)[FLOAT]], [/backbone_base_level2_project_0/Conv_output_0 -> (-1, 48, 88, 160)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Registering layer: /backbone_base_level2_tree1_Add/Add for ONNX node: /backbone_base_level2_tree1_Add/Add
[06/13/2024-10:16:09] [V] [TRT] Registering tensor: /backbone_base_level2_tree1_Add/Add_output_0 for ONNX tensor: /backbone_base_level2_tree1_Add/Add_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level2_tree1_Add/Add [Add] outputs: [/backbone_base_level2_tree1_Add/Add_output_0 -> (-1, 48, 88, 160)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Parsing node: /backbone_base_level2_tree1_Add/relu/Relu [Relu]
[06/13/2024-10:16:09] [V] [TRT] Searching for input: /backbone_base_level2_tree1_Add/Add_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level2_tree1_Add/relu/Relu [Relu] inputs: [/backbone_base_level2_tree1_Add/Add_output_0 -> (-1, 48, 88, 160)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Registering layer: /backbone_base_level2_tree1_Add/relu/Relu for ONNX node: /backbone_base_level2_tree1_Add/relu/Relu
[06/13/2024-10:16:09] [V] [TRT] Registering tensor: /backbone_base_level2_tree1_Add/relu/Relu_output_0 for ONNX tensor: /backbone_base_level2_tree1_Add/relu/Relu_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level2_tree1_Add/relu/Relu [Relu] outputs: [/backbone_base_level2_tree1_Add/relu/Relu_output_0 -> (-1, 48, 88, 160)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Parsing node: /backbone_base_level2_tree2_conv1/Conv [Conv]
[06/13/2024-10:16:09] [V] [TRT] Searching for input: /backbone_base_level2_tree1_Add/relu/Relu_output_0
[06/13/2024-10:16:09] [V] [TRT] Searching for input: onnx::QuantizeLinear_1842
[06/13/2024-10:16:09] [V] [TRT] Searching for input: _v_810
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level2_tree2_conv1/Conv [Conv] inputs: [/backbone_base_level2_tree1_Add/relu/Relu_output_0 -> (-1, 48, 88, 160)[FLOAT]], [onnx::QuantizeLinear_1842 -> (48, 48, 3, 3)[FLOAT]], [_v_810 -> (48)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Registering layer: /backbone_base_level2_tree2_conv1/Conv for ONNX node: /backbone_base_level2_tree2_conv1/Conv
[06/13/2024-10:16:09] [V] [TRT] Registering tensor: /backbone_base_level2_tree2_conv1/Conv_output_0 for ONNX tensor: /backbone_base_level2_tree2_conv1/Conv_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level2_tree2_conv1/Conv [Conv] outputs: [/backbone_base_level2_tree2_conv1/Conv_output_0 -> (-1, 48, 88, 160)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Parsing node: /backbone_base_level2_tree2_conv1/Relu [Relu]
[06/13/2024-10:16:09] [V] [TRT] Searching for input: /backbone_base_level2_tree2_conv1/Conv_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level2_tree2_conv1/Relu [Relu] inputs: [/backbone_base_level2_tree2_conv1/Conv_output_0 -> (-1, 48, 88, 160)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Registering layer: /backbone_base_level2_tree2_conv1/Relu for ONNX node: /backbone_base_level2_tree2_conv1/Relu
[06/13/2024-10:16:09] [V] [TRT] Registering tensor: /backbone_base_level2_tree2_conv1/Relu_output_0 for ONNX tensor: /backbone_base_level2_tree2_conv1/Relu_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level2_tree2_conv1/Relu [Relu] outputs: [/backbone_base_level2_tree2_conv1/Relu_output_0 -> (-1, 48, 88, 160)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Parsing node: /backbone_base_level2_tree2_conv2/Conv [Conv]
[06/13/2024-10:16:09] [V] [TRT] Searching for input: /backbone_base_level2_tree2_conv1/Relu_output_0
[06/13/2024-10:16:09] [V] [TRT] Searching for input: onnx::QuantizeLinear_1853
[06/13/2024-10:16:09] [V] [TRT] Searching for input: _v_813
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level2_tree2_conv2/Conv [Conv] inputs: [/backbone_base_level2_tree2_conv1/Relu_output_0 -> (-1, 48, 88, 160)[FLOAT]], [onnx::QuantizeLinear_1853 -> (48, 48, 3, 3)[FLOAT]], [_v_813 -> (48)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Registering layer: /backbone_base_level2_tree2_conv2/Conv for ONNX node: /backbone_base_level2_tree2_conv2/Conv
[06/13/2024-10:16:09] [V] [TRT] Registering tensor: /backbone_base_level2_tree2_conv2/Conv_output_0 for ONNX tensor: /backbone_base_level2_tree2_conv2/Conv_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level2_tree2_conv2/Conv [Conv] outputs: [/backbone_base_level2_tree2_conv2/Conv_output_0 -> (-1, 48, 88, 160)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Parsing node: /backbone_base_level2_tree2_Add/Add [Add]
[06/13/2024-10:16:09] [V] [TRT] Searching for input: /backbone_base_level2_tree2_conv2/Conv_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level2_tree2_Add/Add [Add] inputs: [/backbone_base_level2_tree2_conv2/Conv_output_0 -> (-1, 48, 88, 160)[FLOAT]], [/backbone_base_level2_tree1_Add/relu/Relu_output_0 -> (-1, 48, 88, 160)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Registering layer: /backbone_base_level2_tree2_Add/Add for ONNX node: /backbone_base_level2_tree2_Add/Add
[06/13/2024-10:16:09] [V] [TRT] Registering tensor: /backbone_base_level2_tree2_Add/Add_output_0 for ONNX tensor: /backbone_base_level2_tree2_Add/Add_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level2_tree2_Add/Add [Add] outputs: [/backbone_base_level2_tree2_Add/Add_output_0 -> (-1, 48, 88, 160)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Parsing node: /backbone_base_level2_tree2_Add/relu/Relu [Relu]
[06/13/2024-10:16:09] [V] [TRT] Searching for input: /backbone_base_level2_tree2_Add/Add_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level2_tree2_Add/relu/Relu [Relu] inputs: [/backbone_base_level2_tree2_Add/Add_output_0 -> (-1, 48, 88, 160)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Registering layer: /backbone_base_level2_tree2_Add/relu/Relu for ONNX node: /backbone_base_level2_tree2_Add/relu/Relu
[06/13/2024-10:16:09] [V] [TRT] Registering tensor: /backbone_base_level2_tree2_Add/relu/Relu_output_0 for ONNX tensor: /backbone_base_level2_tree2_Add/relu/Relu_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level2_tree2_Add/relu/Relu [Relu] outputs: [/backbone_base_level2_tree2_Add/relu/Relu_output_0 -> (-1, 48, 88, 160)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Parsing node: /Concat [Concat]
[06/13/2024-10:16:09] [V] [TRT] Searching for input: /backbone_base_level2_tree2_Add/relu/Relu_output_0
[06/13/2024-10:16:09] [V] [TRT] /Concat [Concat] inputs: [/backbone_base_level2_tree2_Add/relu/Relu_output_0 -> (-1, 48, 88, 160)[FLOAT]], [/backbone_base_level2_tree1_Add/relu/Relu_output_0 -> (-1, 48, 88, 160)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Registering layer: /Concat for ONNX node: /Concat
[06/13/2024-10:16:09] [V] [TRT] Registering tensor: /Concat_output_0 for ONNX tensor: /Concat_output_0
[06/13/2024-10:16:09] [V] [TRT] /Concat [Concat] outputs: [/Concat_output_0 -> (-1, 96, 88, 160)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Parsing node: /backbone_base_level2_root_conv/Conv [Conv]
[06/13/2024-10:16:09] [V] [TRT] Searching for input: /Concat_output_0
[06/13/2024-10:16:09] [V] [TRT] Searching for input: onnx::QuantizeLinear_1866
[06/13/2024-10:16:09] [V] [TRT] Searching for input: _v_816
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level2_root_conv/Conv [Conv] inputs: [/Concat_output_0 -> (-1, 96, 88, 160)[FLOAT]], [onnx::QuantizeLinear_1866 -> (48, 96, 1, 1)[FLOAT]], [_v_816 -> (48)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Convolution input dimensions: (-1, 96, 88, 160)
[06/13/2024-10:16:09] [V] [TRT] Registering layer: /backbone_base_level2_root_conv/Conv for ONNX node: /backbone_base_level2_root_conv/Conv
[06/13/2024-10:16:09] [V] [TRT] Registering tensor: /backbone_base_level2_root_conv/Conv_output_0 for ONNX tensor: /backbone_base_level2_root_conv/Conv_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level2_root_conv/Conv [Conv] outputs: [/backbone_base_level2_root_conv/Conv_output_0 -> (-1, 48, 88, 160)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Parsing node: /backbone_base_level2_root_conv/Relu [Relu]
[06/13/2024-10:16:09] [V] [TRT] Searching for input: /backbone_base_level2_root_conv/Conv_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level2_root_conv/Relu [Relu] inputs: [/backbone_base_level2_root_conv/Conv_output_0 -> (-1, 48, 88, 160)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Registering layer: /backbone_base_level2_root_conv/Relu for ONNX node: /backbone_base_level2_root_conv/Relu
[06/13/2024-10:16:09] [V] [TRT] Registering tensor: /backbone_base_level2_root_conv/Relu_output_0 for ONNX tensor: /backbone_base_level2_root_conv/Relu_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level2_root_conv/Relu [Relu] outputs: [/backbone_base_level2_root_conv/Relu_output_0 -> (-1, 48, 88, 160)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Parsing node: /backbone_base_level3_tree1_conv1/Conv [Conv]
[06/13/2024-10:16:09] [V] [TRT] Searching for input: /backbone_base_level2_root_conv/Relu_output_0
[06/13/2024-10:16:09] [V] [TRT] Searching for input: onnx::QuantizeLinear_1888
[06/13/2024-10:16:09] [V] [TRT] Searching for input: _v_822
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level3_tree1_conv1/Conv [Conv] inputs: [/backbone_base_level2_root_conv/Relu_output_0 -> (-1, 48, 88, 160)[FLOAT]], [onnx::QuantizeLinear_1888 -> (64, 48, 3, 3)[FLOAT]], [_v_822 -> (64)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Registering layer: /backbone_base_level3_tree1_conv1/Conv for ONNX node: /backbone_base_level3_tree1_conv1/Conv
[06/13/2024-10:16:09] [V] [TRT] Using kernel: (3, 3), strides: (2, 2), prepadding: (1, 1), postpadding: (1, 1), dilations: (1, 1), numOutputs: 64
[06/13/2024-10:16:09] [V] [TRT] Convolution output dimensions: (-1, 64, 44, 80)
[06/13/2024-10:16:09] [V] [TRT] Registering tensor: /backbone_base_level3_tree1_conv1/Conv_output_0 for ONNX tensor: /backbone_base_level3_tree1_conv1/Conv_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level3_tree1_conv1/Conv [Conv] outputs: [/backbone_base_level3_tree1_conv1/Conv_output_0 -> (-1, 64, 44, 80)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Parsing node: /backbone_base_level3_downsample/MaxPool [MaxPool]
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level3_downsample/MaxPool [MaxPool] inputs: [/backbone_base_level2_root_conv/Relu_output_0 -> (-1, 48, 88, 160)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Registering layer: /backbone_base_level3_downsample/MaxPool for ONNX node: /backbone_base_level3_downsample/MaxPool
[06/13/2024-10:16:09] [V] [TRT] Registering tensor: /backbone_base_level3_downsample/MaxPool_output_0 for ONNX tensor: /backbone_base_level3_downsample/MaxPool_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level3_downsample/MaxPool [MaxPool] outputs: [/backbone_base_level3_downsample/MaxPool_output_0 -> (-1, 48, 44, 80)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Parsing node: /backbone_base_level3_tree1_conv1/Relu [Relu]
[06/13/2024-10:16:09] [V] [TRT] Searching for input: /backbone_base_level3_tree1_conv1/Conv_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level3_tree1_conv1/Relu [Relu] inputs: [/backbone_base_level3_tree1_conv1/Conv_output_0 -> (-1, 64, 44, 80)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Registering layer: /backbone_base_level3_tree1_conv1/Relu for ONNX node: /backbone_base_level3_tree1_conv1/Relu
[06/13/2024-10:16:09] [V] [TRT] Registering tensor: /backbone_base_level3_tree1_conv1/Relu_output_0 for ONNX tensor: /backbone_base_level3_tree1_conv1/Relu_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level3_tree1_conv1/Relu [Relu] outputs: [/backbone_base_level3_tree1_conv1/Relu_output_0 -> (-1, 64, 44, 80)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Parsing node: /backbone_base_level3_project_0/Conv [Conv]
[06/13/2024-10:16:09] [V] [TRT] Searching for input: /backbone_base_level3_downsample/MaxPool_output_0
[06/13/2024-10:16:09] [V] [TRT] Searching for input: onnx::QuantizeLinear_1910
[06/13/2024-10:16:09] [V] [TRT] Searching for input: _v_828
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level3_project_0/Conv [Conv] inputs: [/backbone_base_level3_downsample/MaxPool_output_0 -> (-1, 48, 44, 80)[FLOAT]], [onnx::QuantizeLinear_1910 -> (64, 48, 1, 1)[FLOAT]], [_v_828 -> (64)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Convolution input dimensions: (-1, 48, 44, 80)
[06/13/2024-10:16:09] [V] [TRT] Registering layer: /backbone_base_level3_project_0/Conv for ONNX node: /backbone_base_level3_project_0/Conv
[06/13/2024-10:16:09] [V] [TRT] Using kernel: (1, 1), strides: (1, 1), prepadding: (0, 0), postpadding: (0, 0), dilations: (1, 1), numOutputs: 64
[06/13/2024-10:16:09] [V] [TRT] Registering tensor: /backbone_base_level3_project_0/Conv_output_0 for ONNX tensor: /backbone_base_level3_project_0/Conv_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level3_project_0/Conv [Conv] outputs: [/backbone_base_level3_project_0/Conv_output_0 -> (-1, 64, 44, 80)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Parsing node: /backbone_base_level3_tree1_conv2/Conv [Conv]
[06/13/2024-10:16:09] [V] [TRT] Searching for input: /backbone_base_level3_tree1_conv1/Relu_output_0
[06/13/2024-10:16:09] [V] [TRT] Searching for input: onnx::QuantizeLinear_1899
[06/13/2024-10:16:09] [V] [TRT] Searching for input: _v_825
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level3_tree1_conv2/Conv [Conv] inputs: [/backbone_base_level3_tree1_conv1/Relu_output_0 -> (-1, 64, 44, 80)[FLOAT]], [onnx::QuantizeLinear_1899 -> (64, 64, 3, 3)[FLOAT]], [_v_825 -> (64)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Convolution input dimensions: (-1, 64, 44, 80)
[06/13/2024-10:16:09] [V] [TRT] Registering layer: /backbone_base_level3_tree1_conv2/Conv for ONNX node: /backbone_base_level3_tree1_conv2/Conv
[06/13/2024-10:16:09] [V] [TRT] Using kernel: (3, 3), strides: (1, 1), prepadding: (1, 1), postpadding: (1, 1), dilations: (1, 1), numOutputs: 64
[06/13/2024-10:16:09] [V] [TRT] Registering tensor: /backbone_base_level3_tree1_conv2/Conv_output_0 for ONNX tensor: /backbone_base_level3_tree1_conv2/Conv_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level3_tree1_conv2/Conv [Conv] outputs: [/backbone_base_level3_tree1_conv2/Conv_output_0 -> (-1, 64, 44, 80)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Parsing node: /backbone_base_level3_tree1_Add/Add [Add]
[06/13/2024-10:16:09] [V] [TRT] Searching for input: /backbone_base_level3_tree1_conv2/Conv_output_0
[06/13/2024-10:16:09] [V] [TRT] Searching for input: /backbone_base_level3_project_0/Conv_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level3_tree1_Add/Add [Add] inputs: [/backbone_base_level3_tree1_conv2/Conv_output_0 -> (-1, 64, 44, 80)[FLOAT]], [/backbone_base_level3_project_0/Conv_output_0 -> (-1, 64, 44, 80)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Registering layer: /backbone_base_level3_tree1_Add/Add for ONNX node: /backbone_base_level3_tree1_Add/Add
[06/13/2024-10:16:09] [V] [TRT] Registering tensor: /backbone_base_level3_tree1_Add/Add_output_0 for ONNX tensor: /backbone_base_level3_tree1_Add/Add_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level3_tree1_Add/Add [Add] outputs: [/backbone_base_level3_tree1_Add/Add_output_0 -> (-1, 64, 44, 80)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Parsing node: /backbone_base_level3_tree1_Add/relu/Relu [Relu]
[06/13/2024-10:16:09] [V] [TRT] Searching for input: /backbone_base_level3_tree1_Add/Add_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level3_tree1_Add/relu/Relu [Relu] inputs: [/backbone_base_level3_tree1_Add/Add_output_0 -> (-1, 64, 44, 80)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Registering layer: /backbone_base_level3_tree1_Add/relu/Relu for ONNX node: /backbone_base_level3_tree1_Add/relu/Relu
[06/13/2024-10:16:09] [V] [TRT] Registering tensor: /backbone_base_level3_tree1_Add/relu/Relu_output_0 for ONNX tensor: /backbone_base_level3_tree1_Add/relu/Relu_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level3_tree1_Add/relu/Relu [Relu] outputs: [/backbone_base_level3_tree1_Add/relu/Relu_output_0 -> (-1, 64, 44, 80)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Parsing node: /backbone_base_level3_tree2_conv1/Conv [Conv]
[06/13/2024-10:16:09] [V] [TRT] Searching for input: /backbone_base_level3_tree1_Add/relu/Relu_output_0
[06/13/2024-10:16:09] [V] [TRT] Searching for input: onnx::QuantizeLinear_1922
[06/13/2024-10:16:09] [V] [TRT] Searching for input: _v_831
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level3_tree2_conv1/Conv [Conv] inputs: [/backbone_base_level3_tree1_Add/relu/Relu_output_0 -> (-1, 64, 44, 80)[FLOAT]], [onnx::QuantizeLinear_1922 -> (64, 64, 3, 3)[FLOAT]], [_v_831 -> (64)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Registering layer: /backbone_base_level3_tree2_conv1/Conv for ONNX node: /backbone_base_level3_tree2_conv1/Conv
[06/13/2024-10:16:09] [V] [TRT] Registering tensor: /backbone_base_level3_tree2_conv1/Conv_output_0 for ONNX tensor: /backbone_base_level3_tree2_conv1/Conv_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level3_tree2_conv1/Conv [Conv] outputs: [/backbone_base_level3_tree2_conv1/Conv_output_0 -> (-1, 64, 44, 80)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Parsing node: /backbone_base_level3_tree2_conv1/Relu [Relu]
[06/13/2024-10:16:09] [V] [TRT] Searching for input: /backbone_base_level3_tree2_conv1/Conv_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level3_tree2_conv1/Relu [Relu] inputs: [/backbone_base_level3_tree2_conv1/Conv_output_0 -> (-1, 64, 44, 80)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Registering layer: /backbone_base_level3_tree2_conv1/Relu for ONNX node: /backbone_base_level3_tree2_conv1/Relu
[06/13/2024-10:16:09] [V] [TRT] Registering tensor: /backbone_base_level3_tree2_conv1/Relu_output_0 for ONNX tensor: /backbone_base_level3_tree2_conv1/Relu_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level3_tree2_conv1/Relu [Relu] outputs: [/backbone_base_level3_tree2_conv1/Relu_output_0 -> (-1, 64, 44, 80)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Parsing node: /backbone_base_level3_tree2_conv2/Conv [Conv]
[06/13/2024-10:16:09] [V] [TRT] Searching for input: /backbone_base_level3_tree2_conv1/Relu_output_0
[06/13/2024-10:16:09] [V] [TRT] Searching for input: onnx::QuantizeLinear_1933
[06/13/2024-10:16:09] [V] [TRT] Searching for input: _v_834
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level3_tree2_conv2/Conv [Conv] inputs: [/backbone_base_level3_tree2_conv1/Relu_output_0 -> (-1, 64, 44, 80)[FLOAT]], [onnx::QuantizeLinear_1933 -> (64, 64, 3, 3)[FLOAT]], [_v_834 -> (64)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Registering layer: /backbone_base_level3_tree2_conv2/Conv for ONNX node: /backbone_base_level3_tree2_conv2/Conv
[06/13/2024-10:16:09] [V] [TRT] Registering tensor: /backbone_base_level3_tree2_conv2/Conv_output_0 for ONNX tensor: /backbone_base_level3_tree2_conv2/Conv_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level3_tree2_conv2/Conv [Conv] outputs: [/backbone_base_level3_tree2_conv2/Conv_output_0 -> (-1, 64, 44, 80)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Parsing node: /backbone_base_level3_tree2_Add/Add [Add]
[06/13/2024-10:16:09] [V] [TRT] Searching for input: /backbone_base_level3_tree2_conv2/Conv_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level3_tree2_Add/Add [Add] inputs: [/backbone_base_level3_tree2_conv2/Conv_output_0 -> (-1, 64, 44, 80)[FLOAT]], [/backbone_base_level3_tree1_Add/relu/Relu_output_0 -> (-1, 64, 44, 80)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Registering layer: /backbone_base_level3_tree2_Add/Add for ONNX node: /backbone_base_level3_tree2_Add/Add
[06/13/2024-10:16:09] [V] [TRT] Registering tensor: /backbone_base_level3_tree2_Add/Add_output_0 for ONNX tensor: /backbone_base_level3_tree2_Add/Add_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level3_tree2_Add/Add [Add] outputs: [/backbone_base_level3_tree2_Add/Add_output_0 -> (-1, 64, 44, 80)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Parsing node: /backbone_base_level3_tree2_Add/relu/Relu [Relu]
[06/13/2024-10:16:09] [V] [TRT] Searching for input: /backbone_base_level3_tree2_Add/Add_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level3_tree2_Add/relu/Relu [Relu] inputs: [/backbone_base_level3_tree2_Add/Add_output_0 -> (-1, 64, 44, 80)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Registering layer: /backbone_base_level3_tree2_Add/relu/Relu for ONNX node: /backbone_base_level3_tree2_Add/relu/Relu
[06/13/2024-10:16:09] [V] [TRT] Registering tensor: /backbone_base_level3_tree2_Add/relu/Relu_output_0 for ONNX tensor: /backbone_base_level3_tree2_Add/relu/Relu_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level3_tree2_Add/relu/Relu [Relu] outputs: [/backbone_base_level3_tree2_Add/relu/Relu_output_0 -> (-1, 64, 44, 80)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Parsing node: /Concat_1 [Concat]
[06/13/2024-10:16:09] [V] [TRT] Searching for input: /backbone_base_level3_tree2_Add/relu/Relu_output_0
[06/13/2024-10:16:09] [V] [TRT] /Concat_1 [Concat] inputs: [/backbone_base_level3_tree2_Add/relu/Relu_output_0 -> (-1, 64, 44, 80)[FLOAT]], [/backbone_base_level3_tree1_Add/relu/Relu_output_0 -> (-1, 64, 44, 80)[FLOAT]], [/backbone_base_level3_downsample/MaxPool_output_0 -> (-1, 48, 44, 80)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Registering layer: /Concat_1 for ONNX node: /Concat_1
[06/13/2024-10:16:09] [V] [TRT] Registering tensor: /Concat_1_output_0 for ONNX tensor: /Concat_1_output_0
[06/13/2024-10:16:09] [V] [TRT] /Concat_1 [Concat] outputs: [/Concat_1_output_0 -> (-1, 176, 44, 80)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Parsing node: /backbone_base_level3_root_conv/Conv [Conv]
[06/13/2024-10:16:09] [V] [TRT] Searching for input: /Concat_1_output_0
[06/13/2024-10:16:09] [V] [TRT] Searching for input: onnx::QuantizeLinear_1946
[06/13/2024-10:16:09] [V] [TRT] Searching for input: _v_837
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level3_root_conv/Conv [Conv] inputs: [/Concat_1_output_0 -> (-1, 176, 44, 80)[FLOAT]], [onnx::QuantizeLinear_1946 -> (64, 176, 1, 1)[FLOAT]], [_v_837 -> (64)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Convolution input dimensions: (-1, 176, 44, 80)
[06/13/2024-10:16:09] [V] [TRT] Registering layer: /backbone_base_level3_root_conv/Conv for ONNX node: /backbone_base_level3_root_conv/Conv
[06/13/2024-10:16:09] [V] [TRT] Registering tensor: /backbone_base_level3_root_conv/Conv_output_0_0 for ONNX tensor: /backbone_base_level3_root_conv/Conv_output_0
[06/13/2024-10:16:09] [V] [TRT] /backbone_base_level3_root_conv/Conv [Conv] outputs: [/backbone_base_level3_root_conv/Conv_output_0 -> (-1, 64, 44, 80)[FLOAT]],
[06/13/2024-10:16:09] [V] [TRT] Marking /backbone_base_level3_root_conv/Conv_output_0_0 as output: /backbone_base_level3_root_conv/Conv_output_0
[06/13/2024-10:16:09] [I] Finish parsing network model
[06/13/2024-10:16:09] [E] Error[3]: [builderConfig.cpp::setFlag::75] Error Code 3: API Usage Error (Parameter check failed at: optimizer/api/builderConfig.cpp::setFlag::75, condition: builderFlag != BuilderFlag::kPREFER_PRECISION_CONSTRAINTS || !flags[BuilderFlag::kOBEY_PRECISION_CONSTRAINTS]. kPREFER_PRECISION_CONSTRAINTS cannot be set if kOBEY_PRECISION_CONSTRAINTS is set.
[06/13/2024-10:16:09] [V] [TRT] Original: 36 layers
[06/13/2024-10:16:09] [V] [TRT] After dead-layer removal: 36 layers
[06/13/2024-10:16:09] [V] [TRT] After Myelin optimization: 36 layers
[06/13/2024-10:16:09] [V] [TRT] Running: ActivationToPointwiseConversion on /backbone_base_base_layer_0/Relu
[06/13/2024-10:16:09] [V] [TRT] Swap the layer type of /backbone_base_base_layer_0/Relu from ACTIVATION to POINTWISE
[06/13/2024-10:16:09] [V] [TRT] Running: ActivationToPointwiseConversion on /backbone_base_level0_0/Relu
[06/13/2024-10:16:09] [V] [TRT] Swap the layer type of /backbone_base_level0_0/Relu from ACTIVATION to POINTWISE
[06/13/2024-10:16:09] [V] [TRT] Running: ActivationToPointwiseConversion on /backbone_base_level1_0/Relu
[06/13/2024-10:16:09] [V] [TRT] Swap the layer type of /backbone_base_level1_0/Relu from ACTIVATION to POINTWISE
[06/13/2024-10:16:09] [V] [TRT] Running: ActivationToPointwiseConversion on /backbone_base_level2_tree1_conv1/Relu
[06/13/2024-10:16:09] [V] [TRT] Swap the layer type of /backbone_base_level2_tree1_conv1/Relu from ACTIVATION to POINTWISE
[06/13/2024-10:16:09] [V] [TRT] Running: ActivationToPointwiseConversion on /backbone_base_level2_tree1_Add/relu/Relu
[06/13/2024-10:16:09] [V] [TRT] Swap the layer type of /backbone_base_level2_tree1_Add/relu/Relu from ACTIVATION to POINTWISE
[06/13/2024-10:16:09] [V] [TRT] Running: ActivationToPointwiseConversion on /backbone_base_level2_tree2_conv1/Relu
[06/13/2024-10:16:09] [V] [TRT] Swap the layer type of /backbone_base_level2_tree2_conv1/Relu from ACTIVATION to POINTWISE
[06/13/2024-10:16:09] [V] [TRT] Running: ActivationToPointwiseConversion on /backbone_base_level2_tree2_Add/relu/Relu
[06/13/2024-10:16:09] [V] [TRT] Swap the layer type of /backbone_base_level2_tree2_Add/relu/Relu from ACTIVATION to POINTWISE
[06/13/2024-10:16:09] [V] [TRT] Running: ActivationToPointwiseConversion on /backbone_base_level2_root_conv/Relu
[06/13/2024-10:16:09] [V] [TRT] Swap the layer type of /backbone_base_level2_root_conv/Relu from ACTIVATION to POINTWISE
[06/13/2024-10:16:09] [V] [TRT] Running: ActivationToPointwiseConversion on /backbone_base_level3_tree1_conv1/Relu
[06/13/2024-10:16:09] [V] [TRT] Swap the layer type of /backbone_base_level3_tree1_conv1/Relu from ACTIVATION to POINTWISE
[06/13/2024-10:16:09] [V] [TRT] Running: ActivationToPointwiseConversion on /backbone_base_level3_tree1_Add/relu/Relu
[06/13/2024-10:16:09] [V] [TRT] Swap the layer type of /backbone_base_level3_tree1_Add/relu/Relu from ACTIVATION to POINTWISE
[06/13/2024-10:16:09] [V] [TRT] Running: ActivationToPointwiseConversion on /backbone_base_level3_tree2_conv1/Relu
[06/13/2024-10:16:09] [V] [TRT] Swap the layer type of /backbone_base_level3_tree2_conv1/Relu from ACTIVATION to POINTWISE
[06/13/2024-10:16:09] [V] [TRT] Running: ActivationToPointwiseConversion on /backbone_base_level3_tree2_Add/relu/Relu
[06/13/2024-10:16:09] [V] [TRT] Swap the layer type of /backbone_base_level3_tree2_Add/relu/Relu from ACTIVATION to POINTWISE
[06/13/2024-10:16:09] [V] [TRT] After final dead-layer removal: 36 layers
[06/13/2024-10:16:09] [V] [TRT] After vertical fusions: 36 layers
[06/13/2024-10:16:09] [V] [TRT] After slice removal: 36 layers
[06/13/2024-10:16:09] [V] [TRT] Eliminating concatenation /Concat_1
[06/13/2024-10:16:09] [V] [TRT] Generating copy for /backbone_base_level3_tree2_Add/relu/Relu_output_0 to /Concat_1_output_0 because copy elision is disabled for concat.
[06/13/2024-10:16:09] [V] [TRT] Generating copy for /backbone_base_level3_tree1_Add/relu/Relu_output_0 to /Concat_1_output_0 because copy elision is disabled for concat.
[06/13/2024-10:16:09] [V] [TRT] Generating copy for /backbone_base_level3_downsample/MaxPool_output_0 to /Concat_1_output_0 because copy elision is disabled for concat.
[06/13/2024-10:16:09] [V] [TRT] Generating copy for /backbone_base_level2_tree2_Add/relu/Relu_output_0 to /Concat_output_0 because copy elision is disabled for concat.
[06/13/2024-10:16:09] [V] [TRT] Generating copy for /backbone_base_level2_tree1_Add/relu/Relu_output_0 to /Concat_output_0 because copy elision is disabled for concat.
[06/13/2024-10:16:09] [V] [TRT] After concat removal: 39 layers
[06/13/2024-10:16:09] [V] [TRT] After tensor merging: 39 layers
[06/13/2024-10:16:09] [V] [TRT] Trying to split Reshape and strided tensor
[06/13/2024-10:16:09] [I] [TRT] Reading Calibration Cache for calibrator: EntropyCalibration2
[06/13/2024-10:16:09] [I] [TRT] Generated calibration scales using calibration cache. Make sure that calibration cache has latest scales.
[06/13/2024-10:16:09] [I] [TRT] To regenerate calibration cache, please delete the existing one. TensorRT will generate a new calibration cache.
[06/13/2024-10:16:09] [V] [TRT] INT8 Inference Tensor scales and zero-points: /normalize_input/Conv_output_0 scale and zero-point Quantization(scale: {0.0204256,}, zero-point: {0,})
[06/13/2024-10:16:09] [V] [TRT] INT8 Inference Tensor scales and zero-points: /backbone_base_base_layer_0/Conv_output_0 scale and zero-point Quantization(scale: {0.0278693,}, zero-point: {0,})
[06/13/2024-10:16:09] [V] [TRT] INT8 Inference Tensor scales and zero-points: /backbone_base_base_layer_0/Relu_output_0 scale and zero-point Quantization(scale: {0.0278693,}, zero-point: {0,})
[06/13/2024-10:16:09] [V] [TRT] INT8 Inference Tensor scales and zero-points: /backbone_base_level0_0/Conv_output_0 scale and zero-point Quantization(scale: {0.086582,}, zero-point: {0,})
[06/13/2024-10:16:09] [V] [TRT] INT8 Inference Tensor scales and zero-points: /backbone_base_level0_0/Relu_output_0 scale and zero-point Quantization(scale: {0.086582,}, zero-point: {0,})
[06/13/2024-10:16:09] [V] [TRT] INT8 Inference Tensor scales and zero-points: /backbone_base_level1_0/Conv_output_0 scale and zero-point Quantization(scale: {0.0698093,}, zero-point: {0,})
[06/13/2024-10:16:09] [V] [TRT] INT8 Inference Tensor scales and zero-points: /backbone_base_level1_0/Relu_output_0 scale and zero-point Quantization(scale: {0.0698093,}, zero-point: {0,})
[06/13/2024-10:16:09] [V] [TRT] INT8 Inference Tensor scales and zero-points: /backbone_base_level2_tree1_conv1/Conv_output_0 scale and zero-point Quantization(scale: {0.0791153,}, zero-point: {0,})
[06/13/2024-10:16:09] [V] [TRT] INT8 Inference Tensor scales and zero-points: /backbone_base_level2_downsample/MaxPool_output_0 scale and zero-point Quantization(scale: {0.0698093,}, zero-point: {0,})
[06/13/2024-10:16:09] [V] [TRT] INT8 Inference Tensor scales and zero-points: /backbone_base_level2_tree1_conv1/Relu_output_0 scale and zero-point Quantization(scale: {0.0791153,}, zero-point: {0,})
[06/13/2024-10:16:09] [V] [TRT] INT8 Inference Tensor scales and zero-points: /backbone_base_level2_project_0/Conv_output_0 scale and zero-point Quantization(scale: {0.0799413,}, zero-point: {0,})
[06/13/2024-10:16:09] [V] [TRT] INT8 Inference Tensor scales and zero-points: /backbone_base_level2_tree1_conv2/Conv_output_0 scale and zero-point Quantization(scale: {0.0935553,}, zero-point: {0,})
[06/13/2024-10:16:09] [V] [TRT] INT8 Inference Tensor scales and zero-points: /backbone_base_level2_tree1_Add/Add_output_0 scale and zero-point Quantization(scale: {0.104235,}, zero-point: {0,})
[06/13/2024-10:16:09] [V] [TRT] INT8 Inference Tensor scales and zero-points: /backbone_base_level2_tree1_Add/relu/Relu_output_0 scale and zero-point Quantization(scale: {0.104235,}, zero-point: {0,})
[06/13/2024-10:16:09] [V] [TRT] INT8 Inference Tensor scales and zero-points: /backbone_base_level2_tree2_conv1/Conv_output_0 scale and zero-point Quantization(scale: {0.0735086,}, zero-point: {0,})
[06/13/2024-10:16:09] [V] [TRT] INT8 Inference Tensor scales and zero-points: /backbone_base_level2_tree2_conv1/Relu_output_0 scale and zero-point Quantization(scale: {0.0735086,}, zero-point: {0,})
[06/13/2024-10:16:09] [V] [TRT] INT8 Inference Tensor scales and zero-points: /backbone_base_level2_tree2_conv2/Conv_output_0 scale and zero-point Quantization(scale: {0.122808,}, zero-point: {0,})
[06/13/2024-10:16:09] [V] [TRT] INT8 Inference Tensor scales and zero-points: /backbone_base_level2_tree2_Add/Add_output_0 scale and zero-point Quantization(scale: {0.137775,}, zero-point: {0,})
[06/13/2024-10:16:09] [V] [TRT] INT8 Inference Tensor scales and zero-points: /backbone_base_level2_tree2_Add/relu/Relu_output_0 scale and zero-point Quantization(scale: {0.137775,}, zero-point: {0,})
[06/13/2024-10:16:09] [V] [TRT] INT8 Inference Tensor scales and zero-points: /Concat_output_0 scale and zero-point Quantization(scale: {0.127774,}, zero-point: {0,})
[06/13/2024-10:16:09] [V] [TRT] INT8 Inference Tensor scales and zero-points: /backbone_base_level2_root_conv/Conv_output_0 scale and zero-point Quantization(scale: {0.0765355,}, zero-point: {0,})
[06/13/2024-10:16:09] [V] [TRT] INT8 Inference Tensor scales and zero-points: /backbone_base_level2_root_conv/Relu_output_0 scale and zero-point Quantization(scale: {0.0765355,}, zero-point: {0,})
[06/13/2024-10:16:09] [V] [TRT] INT8 Inference Tensor scales and zero-points: /backbone_base_level3_tree1_conv1/Conv_output_0 scale and zero-point Quantization(scale: {0.0784342,}, zero-point: {0,})
[06/13/2024-10:16:09] [V] [TRT] INT8 Inference Tensor scales and zero-points: /backbone_base_level3_downsample/MaxPool_output_0 scale and zero-point Quantization(scale: {0.0765355,}, zero-point: {0,})
[06/13/2024-10:16:09] [V] [TRT] INT8 Inference Tensor scales and zero-points: /backbone_base_level3_tree1_conv1/Relu_output_0 scale and zero-point Quantization(scale: {0.0784342,}, zero-point: {0,})
[06/13/2024-10:16:09] [V] [TRT] INT8 Inference Tensor scales and zero-points: /backbone_base_level3_project_0/Conv_output_0 scale and zero-point Quantization(scale: {0.0463886,}, zero-point: {0,})
[06/13/2024-10:16:09] [V] [TRT] INT8 Inference Tensor scales and zero-points: /backbone_base_level3_tree1_conv2/Conv_output_0 scale and zero-point Quantization(scale: {0.0750571,}, zero-point: {0,})
[06/13/2024-10:16:09] [V] [TRT] INT8 Inference Tensor scales and zero-points: /backbone_base_level3_tree1_Add/Add_output_0 scale and zero-point Quantization(scale: {0.0724247,}, zero-point: {0,})
[06/13/2024-10:16:09] [V] [TRT] INT8 Inference Tensor scales and zero-points: /backbone_base_level3_tree1_Add/relu/Relu_output_0 scale and zero-point Quantization(scale: {0.0724247,}, zero-point: {0,})
[06/13/2024-10:16:09] [V] [TRT] INT8 Inference Tensor scales and zero-points: /backbone_base_level3_tree2_conv1/Conv_output_0 scale and zero-point Quantization(scale: {0.0590003,}, zero-point: {0,})
[06/13/2024-10:16:09] [V] [TRT] INT8 Inference Tensor scales and zero-points: /backbone_base_level3_tree2_conv1/Relu_output_0 scale and zero-point Quantization(scale: {0.0590003,}, zero-point: {0,})
[06/13/2024-10:16:09] [V] [TRT] INT8 Inference Tensor scales and zero-points: /backbone_base_level3_tree2_conv2/Conv_output_0 scale and zero-point Quantization(scale: {0.111902,}, zero-point: {0,})
[06/13/2024-10:16:09] [V] [TRT] INT8 Inference Tensor scales and zero-points: /backbone_base_level3_tree2_Add/Add_output_0 scale and zero-point Quantization(scale: {0.12398,}, zero-point: {0,})
[06/13/2024-10:16:09] [V] [TRT] INT8 Inference Tensor scales and zero-points: /backbone_base_level3_tree2_Add/relu/Relu_output_0 scale and zero-point Quantization(scale: {0.12398,}, zero-point: {0,})
[06/13/2024-10:16:09] [V] [TRT] INT8 Inference Tensor scales and zero-points: /Concat_1_output_0 scale and zero-point Quantization(scale: {0.116908,}, zero-point: {0,})
[06/13/2024-10:16:09] [V] [TRT] Configuring builder for Int8 Mode completed in 0.00409282 seconds.
[06/13/2024-10:16:09] [W] [TRT] Missing scale and zero-point for tensor img, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[06/13/2024-10:16:09] [W] [TRT] Missing scale and zero-point for tensor /backbone_base_level3_root_conv/Conv_output_0, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[06/13/2024-10:16:09] [W] [TRT] Node: /backbone_base_level3_root_conv/Conv cannot run in INT8 mode due to missing scale and zero point. Attempting to fall back to FP16.
[06/13/2024-10:16:09] [V] [TRT] Applying generic optimizations to the graph for inference.
[06/13/2024-10:16:10] [V] [TRT] {ForeignNode[/normalize_input/Conv.../backbone_base_level3_root_conv/Conv]} successfully offloaded to DLA.
[06/13/2024-10:16:10] [V] [TRT] Memory consumption details:
[06/13/2024-10:16:10] [V] [TRT] Pool Sizes: Managed SRAM = 0.5 MiB, Local DRAM = 1024 MiB, Global DRAM = 512 MiB
[06/13/2024-10:16:10] [V] [TRT] Required: Managed SRAM = 0.5 MiB, Local DRAM = 256 MiB, Global DRAM = 4 MiB
[06/13/2024-10:16:10] [V] [TRT] DLA Memory Consumption Summary:
[06/13/2024-10:16:10] [V] [TRT] Number of DLA node candidates offloaded : 1 out of 1
[06/13/2024-10:16:10] [V] [TRT] Total memory required by accepted candidates : Managed SRAM = 0.5 MiB, Local DRAM = 256 MiB, Global DRAM = 4 MiB
[06/13/2024-10:16:10] [V] [TRT] After DLA optimization: 1 layers
[06/13/2024-10:16:10] [V] [TRT] Graph construction and optimization completed in 1.73826 seconds.
[06/13/2024-10:16:10] [I] [TRT] ---------- Layers Running on DLA ----------
[06/13/2024-10:16:10] [I] [TRT] [DlaLayer] {ForeignNode[/normalize_input/Conv.../backbone_base_level3_root_conv/Conv]}
[06/13/2024-10:16:10] [I] [TRT] ---------- Layers Running on GPU ----------
[06/13/2024-10:16:10] [V] [TRT] Trying to load shared library libcublas.so.11
[06/13/2024-10:16:10] [V] [TRT] Loaded shared library libcublas.so.11
[06/13/2024-10:16:11] [V] [TRT] Using cublas as plugin tactic source
[06/13/2024-10:16:11] [V] [TRT] Trying to load shared library libcublasLt.so.11
[06/13/2024-10:16:11] [V] [TRT] Loaded shared library libcublasLt.so.11
[06/13/2024-10:16:11] [V] [TRT] Using cublasLt as core library tactic source
[06/13/2024-10:16:11] [I] [TRT] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +534, GPU +824, now: CPU 1109, GPU 8900 (MiB)
[06/13/2024-10:16:11] [V] [TRT] Trying to load shared library libcudnn.so.8
[06/13/2024-10:16:11] [V] [TRT] Loaded shared library libcudnn.so.8
[06/13/2024-10:16:11] [V] [TRT] Using cuDNN as plugin tactic source
[06/13/2024-10:16:12] [V] [TRT] Using cuDNN as core library tactic source
[06/13/2024-10:16:12] [I] [TRT] [MemUsageChange] Init cuDNN: CPU +83, GPU +113, now: CPU 1192, GPU 9013 (MiB)
[06/13/2024-10:16:12] [I] [TRT] Local timing cache in use. Profiling results in this builder pass will not be stored.
[06/13/2024-10:16:12] [V] [TRT] Constructing optimization profile number 0 [1/1].
[06/13/2024-10:16:12] [V] [TRT] 0 requirements combinations were removed due to type constraints.
[06/13/2024-10:16:12] [V] [TRT] Reserving memory for host IO tensors. Host: 0 bytes
[06/13/2024-10:16:12] [V] [TRT] =============== Computing reformatting costs:
[06/13/2024-10:16:12] [V] [TRT] *************** Autotuning Reformat: Half(675840,225280,640,1) -> Half(225280,225280:16,640,1) ***************
[06/13/2024-10:16:12] [V] [TRT] --------------- Timing Runner: Optimizer Reformat(img -> <out>) (Reformat)
[06/13/2024-10:16:12] [V] [TRT] Setting a default quantization params because quantization data is missing for
[06/13/2024-10:16:12] [V] [TRT] Tactic: 0x00000000000003e8 Time: 16.5904
[06/13/2024-10:16:12] [V] [TRT] Tactic: 0x00000000000003ea Time: 3.11351
[06/13/2024-10:16:12] [V] [TRT] Tactic: 0x0000000000000000 Time: 16.2153
[06/13/2024-10:16:12] [V] [TRT] Fastest Tactic: 0x00000000000003ea Time: 3.11351
[06/13/2024-10:16:12] [V] [TRT] *************** Autotuning Reformat: Half(14080,3520:16,80,1) -> Half(270336,4224,96,1) ***************
[06/13/2024-10:16:12] [V] [TRT] --------------- Timing Runner: Optimizer Reformat(<in> -> /backbone_base_level3_root_conv/Conv_output_0) (Reformat)
[06/13/2024-10:16:12] [V] [TRT] Tactic: 0x00000000000003e8 Time: 0.414665
[06/13/2024-10:16:12] [V] [TRT] Tactic: 0x00000000000003ea Time: 0.396521
[06/13/2024-10:16:12] [V] [TRT] Tactic: 0x0000000000000000 Time: 0.413541
[06/13/2024-10:16:12] [V] [TRT] Fastest Tactic: 0x00000000000003ea Time: 0.396521
[06/13/2024-10:16:12] [V] [TRT] =============== Computing costs for
[06/13/2024-10:16:12] [V] [TRT] *************** Autotuning format combination: Half(675840,225280,640,1) -> Half(270336,4224,96,1) ***************
[06/13/2024-10:16:12] [V] [TRT] --------------- Timing Runner: {ForeignNode[/normalize_input/Conv.../backbone_base_level3_root_conv/Conv]} (DLA)
[06/13/2024-10:16:12] [V] [TRT] Setting a default quantization params because quantization data is missing for {ForeignNode[/normalize_input/Conv.../backbone_base_level3_root_conv/Conv]}
[06/13/2024-10:16:13] [V] [TRT] Tactic: 0x0000000000000003 Time: 34.1704
[06/13/2024-10:16:13] [V] [TRT] Fastest Tactic: 0x0000000000000003 Time: 34.1704
[06/13/2024-10:16:13] [V] [TRT] >>>>>>>>>>>>>>> Chose Runner Type: DLA Tactic: 0x0000000000000003
[06/13/2024-10:16:13] [V] [TRT] *************** Autotuning format combination: Half(675840,225280,640,1) -> Half(14080,3520:16,80,1) ***************
[06/13/2024-10:16:13] [V] [TRT] --------------- Timing Runner: {ForeignNode[/normalize_input/Conv.../backbone_base_level3_root_conv/Conv]} (DLA)
[06/13/2024-10:16:13] [V] [TRT] Setting a default quantization params because quantization data is missing for {ForeignNode[/normalize_input/Conv.../backbone_base_level3_root_conv/Conv]}
[06/13/2024-10:16:13] [V] [TRT] Tactic: 0x0000000000000003 Time: 33.8291
[06/13/2024-10:16:13] [V] [TRT] Fastest Tactic: 0x0000000000000003 Time: 33.8291
[06/13/2024-10:16:13] [V] [TRT] *************** Autotuning format combination: Half(225280,225280:16,640,1) -> Half(270336,4224,96,1) ***************
[06/13/2024-10:16:14] [V] [TRT] Setting a default quantization params because quantization data is missing for {ForeignNode[/normalize_input/Conv.../backbone_base_level3_root_conv/Conv]}
[06/13/2024-10:16:14] [V] [TRT] Tactic: 0x0000000000000003 Time: 28.8579
[06/13/2024-10:16:14] [V] [TRT] Fastest Tactic: 0x0000000000000003 Time: 28.8579
[06/13/2024-10:16:14] [V] [TRT] >>>>>>>>>>>>>>> Chose Runner Type: DLA Tactic: 0x0000000000000003
[06/13/2024-10:16:14] [V] [TRT] *************** Autotuning format combination: Half(225280,225280:16,640,1) -> Half(14080,3520:16,80,1) ***************
[06/13/2024-10:16:14] [V] [TRT] --------------- Timing Runner: {ForeignNode[/normalize_input/Conv.../backbone_base_level3_root_conv/Conv]} (DLA)
[06/13/2024-10:16:15] [V] [TRT] Setting a default quantization params because quantization data is missing for {ForeignNode[/normalize_input/Conv.../backbone_base_level3_root_conv/Conv]}
[06/13/2024-10:16:15] [V] [TRT] Tactic: 0x0000000000000003 Time: 28.5168
[06/13/2024-10:16:15] [V] [TRT] Fastest Tactic: 0x0000000000000003 Time: 28.5168
[06/13/2024-10:16:15] [V] [TRT] >>>>>>>>>>>>>>> Chose Runner Type: DLA Tactic: 0x0000000000000003
[06/13/2024-10:16:15] [V] [TRT] Formats and tactics selection completed in 3.21948 seconds.
[06/13/2024-10:16:15] [V] [TRT] After reformat layers: 1 layers
[06/13/2024-10:16:15] [V] [TRT] Total number of blocks in pre-optimized block assignment: 1
[06/13/2024-10:16:15] [I] [TRT] Total Activation Memory: 32078786560
[06/13/2024-10:16:15] [V] [TRT] {ForeignNode[/normalize_input/Conv.../backbone_base_level3_root_conv/Conv]}: DLA Network Layer Information:
Layer(CONVOLUTION): /normalize_input/Conv, Precision: Half, img'[Half([8,3,352,640])] -> /normalize_input/Conv_output_0'[Int8([8,3,352,640])]
Layer(CONVOLUTION): /backbone_base_base_layer_0/Conv, Precision: Int8, /normalize_input/Conv_output_0'[Int8([8,3,352,640])] -> /backbone_base_base_layer_0/Conv_output_0'[Int8([8,16,176,320])]
Layer(ACTIVATION): /backbone_base_base_layer_0/Relu, Precision: Int8, /backbone_base_base_layer_0/Conv_output_0'[Int8([8,16,176,320])] -> /backbone_base_base_layer_0/Relu_output_0'[Int8([8,16,176,320])]
Layer(CONVOLUTION): /backbone_base_level0_0/Conv, Precision: Int8, /backbone_base_base_layer_0/Relu_output_0'[Int8([8,16,176,320])] -> /backbone_base_level0_0/Conv_output_0'[Int8([8,16,176,320])]
Layer(ACTIVATION): /backbone_base_level0_0/Relu, Precision: Int8, /backbone_base_level0_0/Conv_output_0'[Int8([8,16,176,320])] -> /backbone_base_level0_0/Relu_output_0'[Int8([8,16,176,320])]
Layer(CONVOLUTION): /backbone_base_level1_0/Conv, Precision: Int8, /backbone_base_level0_0/Relu_output_0'[Int8([8,16,176,320])] -> /backbone_base_level1_0/Conv_output_0'[Int8([8,32,176,320])]
Layer(ACTIVATION): /backbone_base_level1_0/Relu, Precision: Int8, /backbone_base_level1_0/Conv_output_0'[Int8([8,32,176,320])] -> /backbone_base_level1_0/Relu_output_0'[Int8([8,32,176,320])]
Layer(CONVOLUTION): /backbone_base_level2_tree1_conv1/Conv, Precision: Int8, /backbone_base_level1_0/Relu_output_0'[Int8([8,32,176,320])] -> /backbone_base_level2_tree1_conv1/Conv_output_0'[Int8([8,48,88,160])]
Layer(POOLING): /backbone_base_level2_downsample/MaxPool, Precision: Int8, /backbone_base_level1_0/Relu_output_0'[Int8([8,32,176,320])] -> /backbone_base_level2_downsample/MaxPool_output_0'[Int8([8,32,88,160])]
Layer(ACTIVATION): /backbone_base_level2_tree1_conv1/Relu, Precision: Int8, /backbone_base_level2_tree1_conv1/Conv_output_0'[Int8([8,48,88,160])] -> /backbone_base_level2_tree1_conv1/Relu_output_0'[Int8([8,48,88,160])]
Layer(CONVOLUTION): /backbone_base_level2_project_0/Conv, Precision: Int8, /backbone_base_level2_downsample/MaxPool_output_0'[Int8([8,32,88,160])] -> /backbone_base_level2_project_0/Conv_output_0'[Int8([8,48,88,160])]
Layer(CONVOLUTION): /backbone_base_level2_tree1_conv2/Conv, Precision: Int8, /backbone_base_level2_tree1_conv1/Relu_output_0'[Int8([8,48,88,160])] -> /backbone_base_level2_tree1_conv2/Conv_output_0'[Int8([8,48,88,160])]
Layer(ELEMENTWISE): /backbone_base_level2_tree1_Add/Add, Precision: Int8, /backbone_base_level2_tree1_conv2/Conv_output_0'[Int8([8,48,88,160])], /backbone_base_level2_project_0/Conv_output_0'[Int8([8,48,88,160])] -> /backbone_base_level2_tree1_Add/Add_output_0'[Int8([8,48,88,160])]
Layer(ACTIVATION): /backbone_base_level2_tree1_Add/relu/Relu, Precision: Int8, /backbone_base_level2_tree1_Add/Add_output_0'[Int8([8,48,88,160])] -> /backbone_base_level2_tree1_Add/relu/Relu_output_0'[Int8([8,48,88,160])]
Layer(CONVOLUTION): /backbone_base_level2_tree2_conv1/Conv, Precision: Int8, /backbone_base_level2_tree1_Add/relu/Relu_output_0'[Int8([8,48,88,160])] -> /backbone_base_level2_tree2_conv1/Conv_output_0'[Int8([8,48,88,160])]
Layer(ACTIVATION): /backbone_base_level2_tree2_conv1/Relu, Precision: Int8, /backbone_base_level2_tree2_conv1/Conv_output_0'[Int8([8,48,88,160])] -> /backbone_base_level2_tree2_conv1/Relu_output_0'[Int8([8,48,88,160])]
Layer(CONVOLUTION): /backbone_base_level2_tree2_conv2/Conv, Precision: Int8, /backbone_base_level2_tree2_conv1/Relu_output_0'[Int8([8,48,88,160])] -> /backbone_base_level2_tree2_conv2/Conv_output_0'[Int8([8,48,88,160])]
Layer(ELEMENTWISE): /backbone_base_level2_tree2_Add/Add, Precision: Int8, /backbone_base_level2_tree2_conv2/Conv_output_0'[Int8([8,48,88,160])], /backbone_base_level2_tree1_Add/relu/Relu_output_0'[Int8([8,48,88,160])] -> /backbone_base_level2_tree2_Add/Add_output_0'[Int8([8,48,88,160])]
Layer(ACTIVATION): /backbone_base_level2_tree2_Add/relu/Relu, Precision: Int8, /backbone_base_level2_tree2_Add/Add_output_0'[Int8([8,48,88,160])] -> /backbone_base_level2_tree2_Add/relu/Relu_output_0'[Int8([8,48,88,160])]
Layer(CONCATENATION): /Concat, Precision: Int8, /backbone_base_level2_tree2_Add/relu/Relu_output_0'[Int8([8,48,88,160])], /backbone_base_level2_tree1_Add/relu/Relu_output_0'[Int8([8,48,88,160])] -> /Concat_output_0'[Int8([1,96,88,160])]
Layer(CONVOLUTION): /backbone_base_level2_root_conv/Conv, Precision: Int8, /Concat_output_0'[Int8([1,96,88,160])] -> /backbone_base_level2_root_conv/Conv_output_0'[Int8([8,48,88,160])]
Layer(ACTIVATION): /backbone_base_level2_root_conv/Relu, Precision: Int8, /backbone_base_level2_root_conv/Conv_output_0'[Int8([8,48,88,160])] -> /backbone_base_level2_root_conv/Relu_output_0'[Int8([8,48,88,160])]
Layer(CONVOLUTION): /backbone_base_level3_tree1_conv1/Conv, Precision: Int8, /backbone_base_level2_root_conv/Relu_output_0'[Int8([8,48,88,160])] -> /backbone_base_level3_tree1_conv1/Conv_output_0'[Int8([8,64,44,80])]
Layer(POOLING): /backbone_base_level3_downsample/MaxPool, Precision: Int8, /backbone_base_level2_root_conv/Relu_output_0'[Int8([8,48,88,160])] -> /backbone_base_level3_downsample/MaxPool_output_0'[Int8([8,48,44,80])]
Layer(ACTIVATION): /backbone_base_level3_tree1_conv1/Relu, Precision: Int8, /backbone_base_level3_tree1_conv1/Conv_output_0'[Int8([8,64,44,80])] -> /backbone_base_level3_tree1_conv1/Relu_output_0'[Int8([8,64,44,80])]
Layer(CONVOLUTION): /backbone_base_level3_project_0/Conv, Precision: Int8, /backbone_base_level3_downsample/MaxPool_output_0'[Int8([8,48,44,80])] -> /backbone_base_level3_project_0/Conv_output_0'[Int8([8,64,44,80])]
Layer(CONVOLUTION): /backbone_base_level3_tree1_conv2/Conv, Precision: Int8, /backbone_base_level3_tree1_conv1/Relu_output_0'[Int8([8,64,44,80])] -> /backbone_base_level3_tree1_conv2/Conv_output_0'[Int8([8,64,44,80])]
Layer(ELEMENTWISE): /backbone_base_level3_tree1_Add/Add, Precision: Int8, /backbone_base_level3_tree1_conv2/Conv_output_0'[Int8([8,64,44,80])], /backbone_base_level3_project_0/Conv_output_0'[Int8([8,64,44,80])] -> /backbone_base_level3_tree1_Add/Add_output_0'[Int8([8,64,44,80])]
Layer(ACTIVATION): /backbone_base_level3_tree1_Add/relu/Relu, Precision: Int8, /backbone_base_level3_tree1_Add/Add_output_0'[Int8([8,64,44,80])] -> /backbone_base_level3_tree1_Add/relu/Relu_output_0'[Int8([8,64,44,80])]
Layer(CONVOLUTION): /backbone_base_level3_tree2_conv1/Conv, Precision: Int8, /backbone_base_level3_tree1_Add/relu/Relu_output_0'[Int8([8,64,44,80])] -> /backbone_base_level3_tree2_conv1/Conv_output_0'[Int8([8,64,44,80])]
Layer(ACTIVATION): /backbone_base_level3_tree2_conv1/Relu, Precision: Int8, /backbone_base_level3_tree2_conv1/Conv_output_0'[Int8([8,64,44,80])] -> /backbone_base_level3_tree2_conv1/Relu_output_0'[Int8([8,64,44,80])]
Layer(CONVOLUTION): /backbone_base_level3_tree2_conv2/Conv, Precision: Int8, /backbone_base_level3_tree2_conv1/Relu_output_0'[Int8([8,64,44,80])] -> /backbone_base_level3_tree2_conv2/Conv_output_0'[Int8([8,64,44,80])]
Layer(ELEMENTWISE): /backbone_base_level3_tree2_Add/Add, Precision: Int8, /backbone_base_level3_tree2_conv2/Conv_output_0'[Int8([8,64,44,80])], /backbone_base_level3_tree1_Add/relu/Relu_output_0'[Int8([8,64,44,80])] -> /backbone_base_level3_tree2_Add/Add_output_0'[Int8([8,64,44,80])]
Layer(ACTIVATION): /backbone_base_level3_tree2_Add/relu/Relu, Precision: Int8, /backbone_base_level3_tree2_Add/Add_output_0'[Int8([8,64,44,80])] -> /backbone_base_level3_tree2_Add/relu/Relu_output_0'[Int8([8,64,44,80])]
Layer(CONCATENATION): /Concat_1, Precision: Int8, /backbone_base_level3_tree2_Add/relu/Relu_output_0'[Int8([8,64,44,80])], /backbone_base_level3_tree1_Add/relu/Relu_output_0'[Int8([8,64,44,80])], /backbone_base_level3_downsample/MaxPool_output_0'[Int8([8,48,44,80])] -> /Concat_1_output_0'[Half([1,176,44,80])]
Layer(CONVOLUTION): /backbone_base_level3_root_conv/Conv, Precision: Half, /Concat_1_output_0'[Half([1,176,44,80])] -> /backbone_base_level3_root_conv/Conv_output_0'[Half([8,64,44,80])]
[06/13/2024-10:16:15] [V] [TRT] Layer: {ForeignNode[/normalize_input/Conv.../backbone_base_level3_root_conv/Conv]} Host Persistent: 88 Device Persistent: 0 Scratch Memory: 0
[06/13/2024-10:16:15] [V] [TRT] Skipped printing memory information for 0 layers with 0 memory size i.e. Host Persistent + Device Persistent + Scratch Memory == 0.
[06/13/2024-10:16:15] [I] [TRT] Total Host Persistent Memory: 96
[06/13/2024-10:16:15] [I] [TRT] Total Device Persistent Memory: 0
[06/13/2024-10:16:15] [I] [TRT] Total Scratch Memory: 0
[06/13/2024-10:16:15] [I] [TRT] [MemUsageStats] Peak memory usage of TRT CPU/GPU memory allocators: CPU 1 MiB, GPU 69 MiB
[06/13/2024-10:16:15] [V] [TRT] Total number of blocks in optimized block assignment: 0
[06/13/2024-10:16:15] [I] [TRT] Total Activation Memory: 0
[06/13/2024-10:16:15] [V] [TRT] Total number of generated kernels selected for the engine: 0
[06/13/2024-10:16:15] [V] [TRT] Disabling unused tactic source: CUDNN
[06/13/2024-10:16:15] [V] [TRT] Disabling unused tactic source: CUBLAS, CUBLAS_LT
[06/13/2024-10:16:15] [V] [TRT] Disabling unused tactic source: EDGE_MASK_CONVOLUTIONS
[06/13/2024-10:16:15] [V] [TRT] Disabling unused tactic source: JIT_CONVOLUTIONS
[06/13/2024-10:16:15] [V] [TRT] Engine generation completed in 4.92113 seconds.
[06/13/2024-10:16:15] [V] [TRT] Deleting timing cache: 2 entries, served 0 hits since creation.
[06/13/2024-10:16:15] [V] [TRT] Engine Layer Information:
Layer(DLA): {ForeignNode[/normalize_input/Conv.../backbone_base_level3_root_conv/Conv]}, Tactic: 0x0000000000000003, img (Half[8,3,352,640]) -> /backbone_base_level3_root_conv/Conv_output_0 (Half[8,64,44,80])
[06/13/2024-10:16:15] [I] [TRT] [MemUsageChange] TensorRT-managed allocation in building engine: CPU +1, GPU +4, now: CPU 1, GPU 4 (MiB)
[06/13/2024-10:16:15] [I] Engine built in 10.2974 sec.
[06/13/2024-10:16:15] [I] [TRT] Loaded engine size: 1 MiB
[06/13/2024-10:16:15] [E] Error[9]: Cannot deserialize serialized engine built with EngineCapability::kDLA_STANDALONE, use cuDLA APIs instead.
[06/13/2024-10:16:15] [E] Error[4]: [runtime.cpp::deserializeCudaEngine::65] Error Code 4: Internal Error (Engine deserialization failed.)
[06/13/2024-10:16:15] [E] Engine deserialization failed
[06/13/2024-10:16:15] [I] Skipped inference phase since --buildOnly is added.
&&&& PASSED TensorRT.trtexec [TensorRT v8502] # /usr/src/tensorrt/bin/trtexec --minShapes=img:8x3x352x640 --maxShapes=img:8x3x352x640 --optShapes=img:8x3x352x640 --shapes=img:8x3x352x640 --onnx=model_dync_bs1/TL_FULL_XG_qat_simplified_modified_noqdq.onnx --useDLACore=0 --buildDLAStandalone --saveEngine=model_dync_bs1/model.fp16.linearin.fp16linearout.standalone.bin --inputIOFormats=fp16:dla_linear --outputIOFormats=fp16:dla_linear --int8 --fp16 --verbose --calib=model_dync_bs1/TL_FULL_XG_qat_simplified_modified_precision_config_calib.cache --precisionConstraints=obey --layerPrecisions=/normalize_input/Conv:fp16,
