Platform: Jetson AGX Orin
L4T version: r36.3
JetPack: 6.x
Kernel: 5.15.136-tegra
NVCSI: single port, 4 Virtual Channels (VC0–VC3)
Sensors: 4× identical sensor type, distinct I2C addresses
Summary
When 4 cameras share a single NVCSI port using Virtual Channel IDs 0–3, ICameraProperties::getModuleString() returns the same module_string for all 4 cameras. All cameras report the badge of the first module in the Device Tree (module0), regardless of which physical sensor is queried.
Everything else works correctly: all 4 cameras stream video, V4L2 devices enumerate as expected, SensorPlacement UUIDs are unique per camera, and sensor-id-based selection in nvarguscamerasrc functions normally.
Device Tree Configuration
The overlay DTS is structured following standard NVIDIA camera DT conventions. Each module entry has a unique badge (3-token format), distinct position, and drivernode0 pointing to the correct sensor I2C node.
tegra-camera-platform/modules section (relevant excerpt):
tegra-camera-platform {
modules {
module0 {
badge = "imx623_bottomleft_IMX623";
position = "bottomleft";
orientation = "1";
drivernode0 {
pcl_id = "v4l2_sensor";
sysfs-device-tree = "/sys/firmware/devicetree/base/bus@0/i2c@3180000/imx623@1e";
proc-device-tree = "/proc/device-tree/bus@0/i2c@3180000/imx623@1e";
module1 {
badge = "imx623_bottomright_IMX623";
position = "bottomright";
orientation = "1";
drivernode0 {
sysfs-device-tree = "/sys/firmware/devicetree/base/bus@0/i2c@3180000/imx623@1b";
proc-device-tree = "/proc/device-tree/bus@0/i2c@3180000/imx623@1b";
module2 {
badge = "imx623_topleft_IMX623";
position = "topleft";
orientation = "1";
drivernode0 {
sysfs-device-tree = "/sys/firmware/devicetree/base/bus@0/i2c@3180000/imx623@1c";
proc-device-tree = "/proc/device-tree/bus@0/i2c@3180000/imx623@1c";
module3 {
badge = "imx623_topright_IMX623";
position = "topright";
orientation = "1";
drivernode0 {
sysfs-device-tree = "/sys/firmware/devicetree/base/bus@0/i2c@3180000/imx623@1d";
proc-device-tree = "/proc/device-tree/bus@0/i2c@3180000/imx623@1d";
Sensor nodes :
Each sensor node has a unique I2C address, vc-id, and devnode. All 4 have the same sensor_model = "imx623".
Note on V4L2 ordering: The kernel VI driver assigns
/dev/videoNin reverse VC order for sensors sharing a CSI port (VC0 →video3, VC3 →video0). Thedevnodevalues reflect this verified runtime assignment.
Observed Behaviour
Querying ICameraProperties::getModuleString() for each camera via the Argus API returns the same string for all 4 cameras:
Camera 0 (UUID ...0000): module_string = 'imx623_bottomleft_IMX623'
Camera 1 (UUID ...0003): module_string = 'imx623_bottomleft_IMX623'
Camera 2 (UUID ...0004): module_string = 'imx623_bottomleft_IMX623'
Camera 3 (UUID ...0005): module_string = 'imx623_bottomleft_IMX623'
All 4 report module0’s badge (imx623_bottomleft_IMX623) rather than their own unique badge.
SensorPlacement UUIDs are unique per camera and correctly distinguish the sensors — this is the only per-camera identity that currently works via the Argus API.
According to documentation, module_string should be unique since badge is unique.
Are we doing something wrong in the dts? We have tried also with last characters from badge unique
