I am using gstreamer pipeline with encoders and inference going on. I am able to write an application where I can get bbox information from nvdsosd after nvinfer in my pipeline. But in my application, I already have a big pipeline and adding nvdsosd to that will be overkill. I am looking to see if I can get raw output from nvinfer. Any ideas please. Thank you!
HI
About getting bbox information from nvinfer output, Refer sample sources/apps/sample_apps/deepstream-infer-tensor-meta-test
it should meet your needs.
Thanks for replying @amycao, but I have a huge multimedia gstreamer pipeline which is doing dual encoding and is already keeping stress on the hardware encoders that I am using. I would like to have a callback from NVINFER itself and try to print the output that the plugin spits out. I would not like to have OSD on the pipeline which will stress my hardware encoders. So, I was looking through some of the structures like NvDsInferObjectDetectionInfo, my question is, can we print out this structure right after NVINFER plugin and get the information? Can I use gst_nvinfer_raw_output_generated_callback as callback to nvinfer element and have it print the DetectionInfo struct? Is there any more information on this somewhere?
Please forget the above two posts. Thank you for your suggestion @amycao, I was able to get the information from nvinfer itself. Thank you! This thread can be closed. Thanks again!
