Getting deepstreamer error
Hi i am trying to develop emotion recognition project with FaceNet and my own TAO model over deepstream_test_2 template. I am getting this error:
ali@ali:~/Desktop/face-deployable-test-2$ python3.8 deepstream_test_2.py womanexpression.h264
Creating Pipeline
Creating Source
Creating H264Parser
Creating Decoder
Creating EGLSink
Playing file womanexpression.h264
Adding elements to Pipeline
Linking elements in the Pipeline
Starting pipeline
0:00:00.205528347 55909 0x23bed90 INFO nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1923> [UID = 1]: Trying to create engine from model files
WARNING: [TRT]: CUDA lazy loading is not enabled. Enabling it can significantly reduce device memory usage. See CUDA_MODULE_LOADING in CUDA C++ Programming Guide
ERROR: [TRT]: 3: [builder.cpp::~Builder::307] Error Code 3: API Usage Error (Parameter check failed at: optimizer/api/builder.cpp::~Builder::307, condition: mObjectCounter.use_count() == 1. Destroying a builder object before destroying objects it created leads to undefined behavior.
WARNING: [TRT]: The implicit batch dimension mode has been deprecated. Please create the network with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag whenever possible.
ERROR: [TRT]: 3: predictions/MatMul:kernel weights has count 3584 but 0 was expected
ERROR: [TRT]: UffParser: Parser error: predictions/BiasAdd: The input to the Scale Layer is required to have a minimum of 3 dimensions.
parseModel: Failed to parse UFF model
ERROR: tlt/tlt_decode.cpp:358 Failed to build network, error in model parsing.
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:723 Failed to create network using custom network creation function
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:789 Failed to get cuda engine from custom library API
0:00:02.160553403 55909 0x23bed90 ERROR nvinfer gstnvinfer.cpp:640:gst_nvinfer_logger: NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1943> [UID = 1]: build engine file failed
dstest2_pgie_config.txt:
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
model-file=facemodel.etlt
labelfile-path=labels.txt
force-implicit-batch-dim=1
tlt-model-key=nvidia_tlt
batch-size=1
network-mode=1
process-mode=1
model-color-format=0
num-detected-classes=1
interval=0
gie-unique-id=1
output-blob-names=conv2d_bbox;conv2d_cov/Sigmoid
#scaling-filter=0
#scaling-compute-hw=0
[class-attrs-all]
pre-cluster-threshold=0.2
eps=0.2
group-threshold=1
dstest2_sgie1_config.txt:
[property]
gpu-id=0
net-scale-factor=1.0
offsets=103.939;116.779;123.68
model-color-format=1
batch-size=30
labelfile-path=emotionlabels.txt
tlt-encoded-model=emotionmodel.etlt
infer-dims=3;48;48 # where c = number of channels, h = height of the model input, w = width of model input
uff-input-blob-name=input_1
uff-input-order=0
output-blob-names=predictions/Softmax
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=0
# process-mode: 2 - inferences on crops from primary detector, 1 - inferences on whole frame
process-mode=2
num-detected-classes=7
interval=0
network-type=1 # defines that the model is a classifier.
gie-unique-id=1
classifier-threshold=0.2
my dataset is fer13, consist of 48*48 px gray images.
GPU 1060 GTX
deepstream-app version 6.1.1
DeepStreamSDK 6.1.1
Can you please help?
Thank You.
Seems this topic is duplicated with Getting UFFParser Error - Intelligent Video Analytics / DeepStream SDK - NVIDIA Developer Forums, let’s close this one and only keep one topic open.
As the team is on CNY holiday, we’ll check the topic in next week, thank you.
Please refer to the c/c++ sample of emotion model deployment. deepstream_tao_apps/apps/tao_others/deepstream-emotion-app at master · NVIDIA-AI-IOT/deepstream_tao_apps (github.com)
