Is there anyway to get the current amount of free memory without keeping track of the current memory used, calculating the memory that is used to display based on the system’s resolution, and then subtracting that from the total memory available on the device?
thank you
Thank you. I assume there is no way to do it from the runtime side
Correct, but you can safely run cuGetMemInfo() when you are using the runtime API. (This is an API design bug that hopefully someone will fix eventually.)
Is there a bug in cuMemInfo’s implementation in cuda 2.3 (have not tested it in previous versions), but I am getting
free = 786432 , total = 2
free = 759934976 , total = 938803200
free = 756789248 , total = 938803200
from the following code
unsigned int freeDeviceMemorySize(int device) {
unsigned int free, total;
cuMemGetInfo(&free, &total);
printf("free = %d , total = %d\n", free, total);
return free;
the last two outputs should be correct, but the first is not. This is on the 295 device
I am also putting
cuInit(0);
to init the device before any operation.
Did you create a context before calling cuMemGetInfo?
thanks. that was the problem
