Getting Error in installing vllm on Nvidia Jetson AGX ORIN
I have tried installation using pip , source git source and building setup.py also but could not succeed.
Below are the details about my setup -
Operating System: Linux - 5.15.136-tegra - aarch64
Compiler: /usr/bin/c++
Compiler Version: 11.4.0 (Ubuntu 11.4.0-1ubuntu1~22.04)
With pip -
(bot_venv) lftds@ubuntu:~/Documents/copilot$ pip install vllm
Collecting vllm
Using cached vllm-0.5.1.tar.gz (790 kB)
Installing build dependencies … done
Getting requirements to build wheel … error
error: subprocess-exited-with-error
× Getting requirements to build wheel did not run successfully.
│ exit code: 1
╰─> [16 lines of output]
File “/home/lftds/Documents/copilot/bot_venv/lib/python3.10/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py”, line 353, in
main()
File “/home/lftds/Documents/copilot/bot_venv/lib/python3.10/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py”, line 335, in main
json_out[‘return_val’] = hook(**hook_input[‘kwargs’])
File “/home/lftds/Documents/copilot/bot_venv/lib/python3.10/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py”, line 118, in get_requires_for_build_wheel
return hook(config_settings)
File “/tmp/pip-build-env-wsi_ghvs/overlay/lib/python3.10/site-packages/setuptools/build_meta.py”, line 327, in get_requires_for_build_wheel
return self._get_build_requires(config_settings, requirements=)
File “/tmp/pip-build-env-wsi_ghvs/overlay/lib/python3.10/site-packages/setuptools/build_meta.py”, line 297, in _get_build_requires
self.run_setup()
File “/tmp/pip-build-env-wsi_ghvs/overlay/lib/python3.10/site-packages/setuptools/build_meta.py”, line 313, in run_setup
exec(code, locals())
File “”, line 432, in
File “”, line 353, in get_vllm_version
RuntimeError: Unknown runtime environment
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
│ exit code: 1
╰─> See above for output.
From git source -
bot_venv) lftds@ubuntu:~/Documents/copilot$ git clone GitHub - vllm-project/vllm: A high-throughput and memory-efficient inference and serving engine for LLMs
Cloning into ‘vllm’…
remote: Enumerating objects: 22588, done.
remote: Total 22588 (delta 0), reused 0 (delta 0), pack-reused 22588
Receiving objects: 100% (22588/22588), 21.67 MiB | 8.61 MiB/s, done.
Resolving deltas: 100% (16741/16741), done.
(bot_venv) lftds@ubuntu:~/Documents/copilot$ cd vllm/
(bot_venv) lftds@ubuntu:~/Documents/copilot/vllm$ pip install .
Processing /home/lftds/Documents/copilot/vllm
│ exit code: 1
main()
File “/tmp/pip-build-env-x2sad19s/overlay/lib/python3.10/site-packages/setuptools/build_meta.py”, line 327, in get_requires_for_build_wheel
File “/tmp/pip-build-env-x2sad19s/overlay/lib/python3.10/site-packages/setuptools/build_meta.py”, line 297, in _get_build_requires
self.run_setup()
File “/tmp/pip-build-env-x2sad19s/overlay/lib/python3.10/site-packages/setuptools/build_meta.py”, line 313, in run_setup
[end of output]
│ exit code: 1
Building from source.py -
(bot_venv) lftds@ubuntu:~/Documents/copilot/vllm$ python setup.py bdist_wheel
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-aarch64-cpython-310
creating build/lib.linux-aarch64-cpython-310/vllm
copying vllm/tracing.py → build/lib.linux-aarch64-cpython-310/vllm
copying vllm/model_executor/layers/fused_moe/configs/E=8,N=7168,device_name=AMD_Instinct_MI300X.json → build/lib.linux-aarch64-cpython-310/vllm/model_executor/layers/fused_moe/configs
copying vllm/model_executor/layers/fused_moe/configs/E=8,N=14336,device_name=AMD_Instinct_MI300X.json → build/lib.linux-aarch64-cpython-310/vllm/model_executor/layers/fused_moe/configs
running build_ext
– The CXX compiler identification is GNU 11.4.0
– Detecting CXX compiler ABI info
– Detecting CXX compiler ABI info - done
– Check for working CXX compiler: /usr/bin/c++ - skipped
– Detecting CXX compile features
– Detecting CXX compile features - done
– Build type: RelWithDebInfo
– Target device: cuda
– Could NOT find Python (missing: Python_INCLUDE_DIRS Interpreter Development.Module Development.SABIModule) (found version “3.10.12”)
CMake Error at cmake/utils.cmake:10 (message):
Unable to find python matching:
/home/lftds/Documents/copilot/bot_venv/bin/python.
Call Stack (most recent call first):
CMakeLists.txt:43 (find_python_from_executable)
– Configuring incomplete, errors occurred!
See also “/home/lftds/Documents/copilot/vllm/build/temp.linux-aarch64-cpython-310/CMakeFiles/CMakeOutput.log”.
File “/home/lftds/Documents/copilot/vllm/setup.py”, line 430, in
setup(
File “/home/lftds/Documents/copilot/bot_venv/lib/python3.10/site-packages/setuptools/init.py”, line 103, in setup
return distutils.core.setup(**attrs) .
File “/home/lftds/Documents/copilot/vllm/setup.py”, line 175, in configure
subprocess.check_call(
File “/usr/lib/python3.10/subprocess.py”, line 369, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command ‘[‘cmake’, ‘/home/lftds/Documents/copilot/vllm’, ‘-DCMAKE_BUILD_TYPE=RelWithDebInfo’, ‘-DCMAKE_LIBRARY_OUTPUT_DIRECTORY=/home/lftds/Documents/copilot/vllm/build/lib.linux-aarch64-cpython-310/vllm’, ‘-DCMAKE_ARCHIVE_OUTPUT_DIRECTORY=build/temp.linux-aarch64-cpython-310’, ‘-DVLLM_TARGET_DEVICE=cuda’, ‘-DVLLM_PYTHON_EXECUTABLE=/home/lftds/Documents/copilot/bot_venv/bin/python’, ‘-DNVCC_THREADS=1’]’ returned non-zero exit status 1.
(bot_venv) lftds@ubuntu:~/Documents/copilot/vllm$ cmake -DPYTHON_EXECUTABLE=/home/lftds/Documents/copilot/bot_venv/bin/python …
CMake Error: The source directory “/home/lftds/Documents/copilot” does not appear to contain CMakeLists.txt.
Specify --help for usage, or press the help button on the CMake GUI.
(bot_venv) lftds@ubuntu:~/Documents/copilot/vllm$ cd /home/lftds/Documents/copilot/vllm
mkdir -p build
cd build
cmake -DPYTHON_EXECUTABLE=/home/lftds/Documents/copilot/bot_venv/bin/python -DPYTHON_INCLUDE_DIR=/usr/include/python3.10 -DPYTHON_LIBRARY=/usr/lib/x86_64-linux-gnu/libpython3.10.so …
– Build type:
CMake Error at CMakeLists.txt:45 (message):
Please set VLLM_PYTHON_EXECUTABLE to the path of the desired python version
before running cmake configure.
See also “/home/lftds/Documents/copilot/vllm/build/CMakeFiles/CMakeOutput.log”.
