Hi, I got some trouble in using the image “nvcr.io/nvidia/deepstream:4.0.1-19-devel”. I download the image in a laptop without GPU, then use the following “save” command to save an image tar file:
docker save -o /path/deepstream401devel.tar nvcr.io/nvidia/deepstream:4.0.1-19-devel
After this, I load this tar file in a GPU server with GPU 1080TI and T4, respectively, using the following command:
docker load -i /path/deepstream401devel.tar
then I get the following error:
open /data/docker/docker/tmp/docker-import-257678482/d4a66b5d5e3acc2bbf0052d3b8a8ef60b5e38e3d10454f1c38fb611db3ec3cc0/json: no such file or directory
However, this error dosen’t happen for images deepstream:4.0.1-19-base, deepstream:4.0.1-19-samples.
I really hope someone can tell me how to fix this, thank you in advance!!
