Getting error loading the nvidia video driver
I am getting an error when the nvidia video modeset driver is loading.
dmesg output:
14.347155] nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for aarch64 35.3.1 Release Build (jetson@Astro) Sat 24 Jun 2023 11:58:22 AM EDT
[ 14.651662] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x2080013f result 0x56:
[ 14.652557] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x2080017e result 0x56:
[ 14.655884] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x2080014a result 0x56:
[ 14.696708] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x730190 result 0x56:
On another note: this Orin NX hardware configuration under p3767 does not seem to have a hdmi device tree file? Is there one we should be copying and modifying for our carrier board?
I have the hdmi dts blob file set up correctly but I was asking about the dts file that has the head and sor configuration?
Please share the command you run for reference. Some commands/tools are specific to desktop GPUs and may not work on Jetson platforms. We would like to check and confirm this.
For HDMI output, you may try Orin NX module + Xavier NX carrier board. It is DP output if you use Orin NX module + Orin Nano carrier board.
We have our own carrier board and I ran the dcb_tool to verify my dts blob setup for hdmi. I was interested in the errors I get when the display driver initializes?
I ran the dcb_tool -r tegra234-dcb-p3767-0000-hdmi.dtsi to verify settings.
tegra234-dcb-p3767-0000-hdmi.dtsi (27.5 KB)
Issue resolved at No HDMI output displayed on monitor - Jetson & Embedded Systems / Jetson Orin NX - NVIDIA Developer Forums
