I took the sources from the Jetson Download Center (https://developer.nvidia.com/embedded/downloads | L4T Sources for L4T 32.1) and generated the Image and dtb files as indicated in the Kernel Customization section of the Documentation for L4T 32.1. That went all well, and then I achieved to flash the kernel as follows:
sudo ./flash.sh -r -k kernel jetson-tx2 mmcblk0p1
After that, I built a simple char driver, which is working when I build the binary files and load them as a module (insmod *.ko file, mknod /dev/mydev …). Now, I wanted to include it in the kernel, so I copied the char_driver.c file to
kernel-4.9/drivers/char/
And modified the Kconfig and Makefile of this path, including:
Makefile add:
obj-$(CONFIG_HELLOWORLD) += helloworld_char_driver.o
Kconfig add:
config HELLOWORLD
tristate "My simple helloworld driver"
default n
help
The simplest driver.
I keep proceeding as defined in the Kernel Customization docs, althoug instead of doing “make ARCH=arm64 O=$TEGRA_KERNEL_OUT tegra_defconfig” I just activate the driver doing “make ARCH=arm64 O=$TEGRA_KERNEL_OUT menuconfig” and then save the .config file. Anyway, when building it, it crashes:
Cmd:
make ARCH=arm64 O=$TEGRA_KERNEL_OUT -j12
Output:
make[1]: Entering directory '/home/julen/kernel_src/kernel_out'
GEN ./Makefile
HOSTCC scripts/kconfig/conf.o
HOSTLD scripts/kconfig/conf
scripts/kconfig/conf --silentoldconfig Kconfig
CHK include/config/kernel.release
GEN ./Makefile
WRAP arch/arm64/include/generated/asm/bugs.h
WRAP arch/arm64/include/generated/asm/clkdev.h
WRAP arch/arm64/include/generated/asm/cputime.h
WRAP arch/arm64/include/generated/asm/delay.h
WRAP arch/arm64/include/generated/asm/div64.h
WRAP arch/arm64/include/generated/asm/dma.h
WRAP arch/arm64/include/generated/asm/dma-contiguous.h
WRAP arch/arm64/include/generated/asm/early_ioremap.h
WRAP arch/arm64/include/generated/asm/emergency-restart.h
WRAP arch/arm64/include/generated/asm/errno.h
WRAP arch/arm64/include/generated/asm/hw_irq.h
WRAP arch/arm64/include/generated/asm/ioctl.h
WRAP arch/arm64/include/generated/asm/ioctls.h
WRAP arch/arm64/include/generated/asm/ipcbuf.h
WRAP arch/arm64/include/generated/asm/irq_regs.h
CHK include/generated/uapi/linux/version.h
WRAP arch/arm64/include/generated/asm/kdebug.h
WRAP arch/arm64/include/generated/asm/kmap_types.h
WRAP arch/arm64/include/generated/asm/kvm_para.h
WRAP arch/arm64/include/generated/asm/local.h
WRAP arch/arm64/include/generated/asm/local64.h
UPD include/generated/uapi/linux/version.h
WRAP arch/arm64/include/generated/asm/mcs_spinlock.h
WRAP arch/arm64/include/generated/asm/mm-arch-hooks.h
WRAP arch/arm64/include/generated/asm/mman.h
WRAP arch/arm64/include/generated/asm/msgbuf.h
WRAP arch/arm64/include/generated/asm/msi.h
WRAP arch/arm64/include/generated/asm/mutex.h
WRAP arch/arm64/include/generated/asm/poll.h
WRAP arch/arm64/include/generated/asm/preempt.h
WRAP arch/arm64/include/generated/asm/resource.h
WRAP arch/arm64/include/generated/asm/rwsem.h
WRAP arch/arm64/include/generated/asm/segment.h
WRAP arch/arm64/include/generated/asm/sembuf.h
WRAP arch/arm64/include/generated/asm/serial.h
WRAP arch/arm64/include/generated/asm/shmbuf.h
WRAP arch/arm64/include/generated/asm/simd.h
WRAP arch/arm64/include/generated/asm/sizes.h
WRAP arch/arm64/include/generated/asm/socket.h
WRAP arch/arm64/include/generated/asm/sockios.h
WRAP arch/arm64/include/generated/asm/swab.h
WRAP arch/arm64/include/generated/asm/switch_to.h
WRAP arch/arm64/include/generated/asm/termbits.h
WRAP arch/arm64/include/generated/asm/termios.h
WRAP arch/arm64/include/generated/asm/trace_clock.h
WRAP arch/arm64/include/generated/asm/types.h
WRAP arch/arm64/include/generated/asm/unaligned.h
WRAP arch/arm64/include/generated/asm/user.h
WRAP arch/arm64/include/generated/asm/vga.h
WRAP arch/arm64/include/generated/asm/xor.h
WRAP arch/arm64/include/generated/uapi/asm/kvm_para.h
HOSTCC scripts/basic/bin2c
UPD include/config/kernel.release
Using /home/julen/kernel_src/kernel/kernel-4.9 as source for kernel
CHK include/generated/utsrelease.h
UPD include/generated/utsrelease.h
HOSTCC scripts/dtc/dtc.o
HOSTCC scripts/dtc/flattree.o
HOSTCC scripts/dtc/fstree.o
HOSTCC scripts/dtc/data.o
HOSTCC scripts/dtc/livetree.o
HOSTCC scripts/dtc/treesource.o
HOSTCC scripts/dtc/srcpos.o
HOSTCC scripts/dtc/checks.o
HOSTCC scripts/dtc/util.o
CC scripts/mod/empty.o
SHIPPED scripts/dtc/dtc-lexer.lex.c
SHIPPED scripts/dtc/dtc-parser.tab.h
HOSTCC scripts/mod/mk_elfconfig
CHK include/generated/timeconst.h
UPD include/generated/timeconst.h
CC kernel/bounds.s
HOSTCC scripts/selinux/genheaders/genheaders
HOSTCC scripts/selinux/mdp/mdp
CC scripts/mod/devicetable-offsets.s
HOSTCC scripts/kallsyms
CHK include/generated/bounds.h
UPD include/generated/bounds.h
HOSTCC scripts/conmakehash
GEN scripts/gdb/linux/constants.py
MKELF scripts/mod/elfconfig.h
CHK scripts/mod/devicetable-offsets.h
UPD scripts/mod/devicetable-offsets.h
HOSTCC scripts/mod/modpost.o
HOSTCC scripts/recordmcount
HOSTCC scripts/mod/file2alias.o
HOSTCC scripts/mod/sumversion.o
CC arch/arm64/kernel/asm-offsets.s
SHIPPED scripts/dtc/dtc-parser.tab.c
HOSTCC scripts/sortextable
HOSTCC scripts/dtc/dtc-lexer.lex.o
HOSTCC scripts/asn1_compiler
HOSTCC scripts/dtc/dtc-parser.tab.o
HOSTCC scripts/sign-file
HOSTCC scripts/extract-cert
HOSTLD scripts/dtc/dtc
HOSTCC scripts/insert-sys-cert
CHK include/generated/asm-offsets.h
UPD include/generated/asm-offsets.h
CALL /home/julen/kernel_src/kernel/kernel-4.9/scripts/checksyscalls.sh
HOSTLD scripts/mod/modpost
cp -u arch/arm64/boot/dts/
cp: missing destination file operand after 'arch/arm64/boot/dts/'
Try 'cp --help' for more information.
/home/julen/kernel_src/kernel/kernel-4.9/arch/arm64/boot/dts/Makefile:136: recipe for target 'dtbs' failed
make[2]: *** [dtbs] Error 1
arch/arm64/Makefile:154: recipe for target 'dtbs' failed
make[1]: *** [dtbs] Error 2
make[1]: *** Waiting for unfinished jobs....
make[1]: Leaving directory '/home/julen/kernel_src/kernel_out'
Makefile:171: recipe for target 'sub-make' failed
make: *** [sub-make] Error 2
Any suggestion on why this is happening?
