Getting Error while Compiling YOLOv4 with Deepsream 5.1
I am compiling YOLOv4 with Deepstream 5.1 REF but getting the below error, So can you help me
g++ -o libnvdsinfer_custom_impl_Yolo.so nvdsparsebbox_Yolo.o -shared -Wl,–start-group -lnvinfer_plugin -lnvinfer -lnvparsers -L/usr/local/cuda-11.1/lib64 -lcudart -lcublas -lstdc++fs -Wl,–end-group
/usr/bin/ld: cannot find -lnvinfer_plugin
/usr/bin/ld: cannot find -lnvparsers
collect2: error: ld returned 1 exit status
Makefile:48: recipe for target ‘libnvdsinfer_custom_impl_Yolo.so’ failed
make: *** [libnvdsinfer_custom_impl_Yolo.so] Error 1
Complete information of setup.
• Hardware Platform (Jetson / GPU): GPU
• DeepStream Version: 5.1
• TensorRT Version: 7.2.3.4
• NVIDIA GPU Driver Version (valid for GPU only): 460.84
• Issue Type( questions, new requirements, bugs): questions
This must be a setup issue.
Please detail how you setup your system and run into this issue
Thanks Mchi for reply.
For DeepStream 5.1 installation : Quickstart Guide — DeepStream 6.1.1 Release documentation
And tested with command: deepstream-app -c /opt/nvidia/deepstream/deepstream-5.1/samples/configs/deepstream-app/source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt
Works well.
Darknet Yolov4 model converted into TRT engine using: https://github.com/Tianxiaomo/pytorch-YOLOv4
Model tested using REF
For compilation getting above error: REF
Sorry for late!
Please check GitHub - NVIDIA-AI-IOT/yolov4_deepstream
