whenever I try to play gst-launch-1.0 rtspsrc location="uri" ! fakesink
It throws couple of warning errors to me:
(gst-plugin-scanner:11388): GStreamer-WARNING **: 23:22:09.944: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-plugin-scanner:11388): GStreamer-WARNING **: 23:22:11.291: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstchromaprint.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Progress: (open) Opening Stream
Progress: (connect) Connecting to rtsp://user:passwd@192.168.1.1:554/h265/main/ch4/main/av_stream
Progress: (open) Retrieving server options
ERROR: from element /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0: Could not open resource for reading.
Additional debug info:
gstrtspsrc.c(5829): gst_rtspsrc_setup_auth (): /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0:
No supported authentication protocol was found
ERROR: pipeline doesn't want to preroll.
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
My device is Xavier NX running JP 4.5 and DeepStream-5.1
Before sharing feedback - I tried this: sudo rm ${HOME}/.cache/gstreamer-1.0/registry.aarch64.bin
It says no such directory
And tried,
But the solution didn’t work out.
Also - my tegrastats shows 6GB utilization without running anything.
I tried reinstalling gstreamer plugins but didn’t help either.
Looking for a solution - thanks
