Getting JSON related errors when training in docker container
on host i am able to run the training successfully but when i tried to run the training docker container I am getting json errors. I am using nvcr.io/nvidia/tao/tao-toolkit:4.0.0-tf1.15.5 as base image but i understand the problem might coming from mounts.json this is how i used mounts in docker
Define the file path for mounts file.
mounts_file=“/root/.tao_mounts.json”
Define the dictionary with the mapped drives.
drive_map=‘{“Mounts”: [
“source”: "’“${LOCAL_PROJECT_DIR}”‘",
“destination”: “/use/src/tao-experiments”
“source”: "’“${LOCAL_SPECS_DIR}”‘",
“destination”: "’“${SPECS_DIR}”‘"
and this is the error
tfrecords generation
2023-05-04 03:20:05,403 [INFO] root: Registry: [‘nvcr.io’]
2023-05-04 03:20:05,445 [INFO] tlt.components.instance_handler.local_instance: Running command in container: nvcr.io/nvidia/tao/tao-toolkit:4.0.0-tf1.15.5
File “/usr/local/bin/tao”, line 8, in
sys.exit(main())
File “/usr/local/lib/python3.6/dist-packages/tlt/entrypoint/tao.py”, line 116, in main
args[1:]
File “/usr/local/lib/python3.6/dist-packages/tlt/components/instance_handler/local_instance.py”, line 319, in launch_command
docker_handler.run_container(command)
File “/usr/local/lib/python3.6/dist-packages/tlt/components/docker_handler/docker_handler.py”, line 284, in run_container
mount_data, env_vars, docker_options = self._get_mount_env_data()
File “/usr/local/lib/python3.6/dist-packages/tlt/components/docker_handler/docker_handler.py”, line 92, in _get_mount_env_data
data = self._load_mounts_file(self._docker_mount_file)
File “/usr/local/lib/python3.6/dist-packages/tlt/components/docker_handler/docker_handler.py”, line 77, in _load_mounts_file
data = json.load(mfile)
File “/usr/lib/python3.6/json/init.py”, line 299, in load
parse_constant=parse_constant, object_pairs_hook=object_pairs_hook, **kw)
File “/usr/lib/python3.6/json/init.py”, line 354, in loads
return _default_decoder.decode(s)
File “/usr/lib/python3.6/json/decoder.py”, line 339, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File “/usr/lib/python3.6/json/decoder.py”, line 357, in raw_decode
raise JSONDecodeError(“Expecting value”, s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 7 column 19 (char 146)
2023-05-04 03:20:05,834 [INFO] root: Registry: [‘nvcr.io’]
2023-05-04 03:20:05,875 [INFO] tlt.components.instance_handler.local_instance: Running command in container: nvcr.io/nvidia/tao/tao-toolkit:4.0.0-tf1.15.5
could you please tell me how to use mounts properly when training in docker container.
Thanks in advance.
You can run with below way to login docker.
$ docker run --runtime=nvidia -it --rm -v your_local_path:docker_path nvcr.io/nvidia/tao/tao-toolkit:4.0.0-tf1.15.5 /bin/bash
Then, run commands without “tao”.
For example,
#ssd train xxx
Thanks a lot, working now.
Hi, could you please tell me Yolo_v4 supports json format
Refer to TAO Toolkit Launcher - NVIDIA Docs.
The ~/.tao_mounts.json can be setup.
Then user can trigger TAO with tao launcher.
I mean the dataset format right now it is using kitti format right, so is it possible to muse json format instead of kitti format.
For yolov4, it is not supported for COCO format json file.
Please use KITTI format.
Tips:
https://github.com/NVIDIA-AI-IOT/deepstream_tao_apps/blob/release/tao3.0/misc/dev_blog/SOTA/dataset_tools/coco2kitti.py
Got it, Thank you so much for your quick response.
Do you still need support for this topic? Or should we close it? Thanks.
I solved it from your previous solution, thank you so much
