On, ConnectX®-3 Pro EN I receive large number of “CQE error - vendor syndrome: 0xf9 syndrome: 0x5” logs in kernel log. They start with one “CQE error - vendor syndrome: 0x69 syndrome: 0x1” and then lots of 0xf9 and 0x5 follows. And the transmission is interrupted. What I can do to debug or fix that ?
The configuration looks like - Linux 4.15, Ubuntu Xenial with 4.0 kernel driver (tried OFED 4.7 - the same), firmware version 2.40.5000, pcie x8.
Many thanks for posting your inquiry on the Mellanox Community.
Based on the information provided, syndrome 0x5 points to “Work Request Flushed Error”.
For further debugging the issue, we recommend to open a Mellanox Support Ticket (Valid Support contract needed) so we can go deeper into the debug of this issue. You can open a ticket through support@mellanox.com
Also we noticed that your f/w is version 2.40.5000. The validated and supported version for the ConnectX-3 Pro EN in combination with MLXN_OFED version 4.7, is version 2.42.5000.
