I have a Centos 7.2 system and am using a Tesla M4 video card with the system.
Since the Tesla M4 has no output (no VGA/DVI) I am using the onboard VGA.
The issue is when I install the nvidia driver, the VGA output goes away and if I uninstall the driver VGA is back. I am able to set the IP address, and then install the nvidia driver and use the sample sdk so I know the video card is working.
Do I need to do something to switch the display on or forward the video to the onboard VGA?
| NVIDIA-SMI 352.99 Driver Version: 352.99 |
| 0 Tesla M4 Off | 0000:02:00.0 Off | 0 |
| N/A 32C P8 7W / 75W | 44MiB / 3839MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 3101 G /usr/bin/Xorg 0MiB |
| 0 97297 G /usr/bin/X 12MiB |
| 0 97528 G /usr/bin/gnome-shell 10MiB |
Thanks!!
