Getting nvidia/LocateAnything-3B Running as an OpenAI-Compatible API on a DGX Spark / GB10 Blackwell
Setup
  • Hardware: NVIDIA DGX Spark / Lenovo ThinkStation PGX (GB10 Blackwell Superchip, 128GB unified memory)
  • Base Docker image: custom vLLM build from eugr/spark-vllm-docker, built with the --tf5 flag (vllm-node-tf5:latest)
  • Model: nvidia/LocateAnything-3B
We used the eugr/spark-vllm-docker build pipeline because it targets the GB10 Blackwell (SM121) architecture, which the official vLLM container doesn’t fully support out of the box. The --tf5 flag enables CUDA 13 compatibility needed on DGX Spark. It’s unclear whether a plain PyTorch container would also work — we didn’t test that — but if you’re on a DGX Spark or ThinkStation PGX this is a known-good base image.
LocateAnything is not a vLLM-served model. We run it as a standalone FastAPI server inside the container using the official LocateAnythingWorker from the NVlabs/Eagle repo, exposing a task-oriented REST API.
Issues encountered and how we solved them
1. decord not available on ARM64
The model’s custom code imports decord (a video loading library). transformers’ check_imports scans for it statically before any code runs, so a sys.modules stub doesn’t work. The PyPI decord package also has no ARM64 wheel.
Fix: build and install a minimal stub package locally:
bash
mkdir -p /tmp/decord-stub/decord
cat > /tmp/decord-stub/decord/__init__.py << 'EOF'
class VideoReader:
    def __init__(self, *a, **kw): pass
    def __len__(self): return 0
    def __getitem__(self, idx): return None
    def get_avg_fps(self): return 30.0
EOF
cat > /tmp/decord-stub/setup.py << 'EOF'
from setuptools import setup, find_packages
setup(name='decord', version='0.6.0', packages=find_packages())
EOF
pip install /tmp/decord-stub
2. Several deps in pyproject.toml don’t build on ARM64
deepspeed, bitsandbytes, and liger_kernel either have no ARM64 wheels or require compilation that fails in this environment. Since we’re only doing inference, none of them are needed. We install deps manually and use pip install --no-deps -e . for the package itself.
3. MoonViT vision encoder downloads separately
The model config references moonshotai/MoonViT-SO-400M as a sub-model fetched from HF Hub at load time. Without authentication this hangs silently on rate limiting. Pass your HF token via both env vars:
bash
-e HF_TOKEN=your_token_here
-e HUGGING_FACE_HUB_TOKEN=your_token_here
Once downloaded it’s cached in the mounted ~/.cache/huggingface volume permanently.
4. Don’t use device_map='auto'
On the GB10 with 128GB unified memory, device_map='auto' runs a slow metadata analysis pass that can appear frozen for many minutes. The LocateAnythingWorker uses .to(device) directly which loads from cache in under a second.
5. Use LocateAnythingWorker, not raw model.generate()
The model uses Parallel Box Decoding (PBD) with a custom generation_mode parameter (fast/slow/hybrid). Raw model.generate() doesn’t invoke this correctly. Always use the official worker from the repo.
Full working docker run command
bash
docker rm -f locate-anything-vllm 2>/dev/null
docker run -d --gpus all \
  --name locate-anything-vllm \
  --shm-size=16g \
  --ipc=host \
  -p 8889:8889 \
  -v ~/.cache/huggingface:/root/.cache/huggingface \
  -e HF_TOKEN=your_token_here \
  -e HUGGING_FACE_HUB_TOKEN=your_token_here \
  --entrypoint /bin/bash \
  vllm-node-tf5 \
  -c "
    git clone https://github.com/NVlabs/Eagle.git /eagle && \
    cd /eagle/Embodied && \
    pip install --no-cache-dir \
      'transformers==4.57.1' \
      'tokenizers==0.22.0' \
      'sentencepiece==0.2.0' \
      'accelerate==1.5.2' \
      'peft==0.12.0' \
      'numpy>=1.25,<2' \
      'timm>=1.0.11' \
      'einops' \
      'einops-exts' \
      'scipy>=1.10.0' \
      'scikit-image' \
      'opencv-python-headless' \
      'pillow' \
      'requests' \
      'uvicorn' \
      'fastapi' \
      'lmdb' \
      'filetype' \
      'bitstring' \
      'shortuuid' && \
    mkdir -p /tmp/decord-stub/decord && \
class VideoReader:
EOF
EOF
    pip install /tmp/decord-stub && \
    pip install --no-deps -e /eagle/Embodied && \
    cat > /app.py << 'PYEOF'
import torch
import requests
import base64
from io import BytesIO
from PIL import Image
from fastapi import FastAPI, Request
from fastapi.responses import JSONResponse
import uvicorn
import sys
sys.path.insert(0, '/eagle/Embodied')
from locateanything_worker import LocateAnythingWorker
app = FastAPI()
model_id = 'nvidia/LocateAnything-3B'
print('Loading LocateAnythingWorker...', flush=True)
worker = LocateAnythingWorker(model_id)
print('Model ready.', flush=True)
@app.post('/v1/locate')
async def locate(request: Request):
    body = await request.json()
    image_url = body.get('image_url')
    image_b64 = body.get('image_b64')
    if not image_url and not image_b64:
        return JSONResponse({'error': 'image_url or image_b64 required'}, status_code=400)
    try:
        if image_url:
            resp = requests.get(image_url, timeout=10, headers={'User-Agent': 'Mozilla/5.0'})
            image = Image.open(BytesIO(resp.content)).convert('RGB')
        else:
            image = Image.open(BytesIO(base64.b64decode(image_b64))).convert('RGB')
    except Exception as e:
        return JSONResponse({'error': f'Failed to load image: {e}'}, status_code=400)
    task = body.get('task', 'detect')
    query = body.get('query', '')
    mode = body.get('mode', 'hybrid')
    w, h = image.size
    if task == 'detect':
        categories = body.get('categories', query.split(',') if query else [])
        result = worker.detect(image, categories, generation_mode=mode)
    elif task == 'ground':
        result = worker.ground_multi(image, query, generation_mode=mode)
    elif task == 'ground_single':
        result = worker.ground_single(image, query, generation_mode=mode)
    elif task == 'detect_text':
        result = worker.detect_text(image, generation_mode=mode)
    elif task == 'ground_gui':
        output_type = body.get('output_type', 'box')
        result = worker.ground_gui(image, query, output_type=output_type, generation_mode=mode)
    elif task == 'point':
        result = worker.point(image, query, generation_mode=mode)
    else:
        return JSONResponse({'error': f'Unknown task: {task}'}, status_code=400)
    answer = result['answer']
    boxes = LocateAnythingWorker.parse_boxes(answer, w, h)
    points = LocateAnythingWorker.parse_points(answer, w, h)
    return {
        'answer': answer,
        'boxes': boxes,
        'points': points,
        'image_size': {'width': w, 'height': h},
        'stats': result.get('stats'),
@app.get('/health')
async def health():
    return {'status': 'ok'}
if __name__ == '__main__':
    uvicorn.run(app, host='0.0.0.0', port=8889)
PYEOF
    python3 /app.py
Testing — Python client
python
import requests
import base64
import json
with open("your_image.jpg", "rb") as f:
    img_b64 = base64.b64encode(f.read()).decode()
response = requests.post(
    "http://<your-ip>:8889/v1/locate",
    json={
        "task": "detect",
        "categories": ["dice"],
        "image_b64": img_b64
    timeout=120
print(json.dumps(response.json(), indent=2))
Example output detecting dice in a scene:
json
  "answer": "<ref>dice</ref><box><311><596><339><634></box>...<|im_end|>",
  "boxes": [
    {"x1": 279.9, "y1": 357.6, "x2": 305.1, "y2": 380.4},
    {"x1": 291.6, "y1": 237.0, "x2": 320.4, "y2": 261.0},
    {"x1": 370.8, "y1": 240.0, "x2": 397.8, "y2": 264.0},
    {"x1": 405.0, "y1": 349.2, "x2": 432.9, "y2": 375.0},
    {"x1": 825.3, "y1": 579.0, "x2": 899.1, "y2": 598.8}
  "image_size": {"width": 900, "height": 600},
  "stats": "num_tokens=34; generate_time=1.35s; tps=25.2; num_boxes=5; bps=3.71; switch_to_ar=0"
5 dice detected in 1.35 seconds, 3.7 BPS, zero autoregressive fallbacks — Parallel Box Decoding working correctly on GB10 Blackwell.
Supported tasks
Task Field Description
detect categories: ["cat", "car"] Multi-category object detection
ground query: "people in red shirts" Phrase grounding, multiple instances
ground_single query: "the dog on the left" Phrase grounding, single instance
detect_text -– Scene text / OCR detection
ground_gui query: "search button" GUI element grounding
point query: "the traffic light" Point-based localization
Inference mode can be set per-request via "mode": "fast", "slow", or "hybrid" (default).
Thanks for sharing this. Would be good to see other things you’re using the Spark for at Cubemars.
Hey there, are you talking about CubeMars actuators? Are you associated? I am currently working on my robot arm and had CubeMars actuators in the loop. I will try to build applications around the arm running locally on the DGX Spark. Let me know how to get in touch and how to keep you updated!
Thanks for documenting this — LocateAnything is not a vLLM-style text model, so wrapping it in a FastAPI server is the right approach. A couple of suggestions to make the setup more robust:
- Pin the base image tag rather than latest. eugr/spark-vllm-docker moves frequently and a rebuild can change CUDA/TensorRT/vLLM versions under you.
- Add an OpenAI-compatible /v1/chat/completions shim only if your downstream tools need it; otherwise a task-oriented /locate endpoint is cleaner and easier to maintain.
- For production use, run the worker behind a small reverse proxy (nginx/traefik) with request timeout and model-load health check, so the first request after container start doesn’t time out while weights load.
One thing to watch: LocateAnything expects a specific input resolution and prompt format. If you expose it as generic chat, make sure the client is sending the image as a message with the correct role/content schema or you’ll get silent degraded results. Happy to help review the API contract if you share the handler code.
Thanks for the feedback! The FastAPI handler/API contract is already included in the post. The API is intentionally task-specific rather than chat-based: clients send task, categories, and a base64-encoded image to /v1/locate, which is then forwarded to the LocateAnything pipeline. If you spot any issues with the request/response contract or the image preprocessing, I’d really appreciate your thoughts.
Pinning the base image version is a good suggestion. I used latest while iterating, but pinning a specific tag makes a lot more sense for reproducibility—especially on the DGX Spark where CUDA/TensorRT updates can unexpectedly break things.
I may also add an optional OpenAI-compatible /v1/chat/completions endpoint as a thin compatibility layer for tools that expect it, while keeping /v1/locate as the native interface.
