I have a question regarding the usage of the replicator composer. In the replicator composer overview I saw that it supports the output of occlusion data, but I could not find any tutorials or source code, where I could find out how it works. Are there any tutorials or code snippets available?
Thanks for your suggestion. That was the page where I saw under point “5.2. Replicator Composer Overview” that Replicator Composer supports the output of occlusion data, but I could not find information on how to get this data. Are there code snippets where I could learn how to use it?
it seems the occlusion parameter is not in the output annotators list documentation. Can you try setting occlusion to True, similarly to the other annotators.
I added “occlusion: True” for testing to the example “flying_things_3d” but the program crashed with the error message “ValueError: Parameter ‘occlusion’ is not a parameter.”. You can find a screenshot with the error message attached.
the feature did not make it in this release, it will most probably be out in 2022.2.1. As a workaround you can use the occlusion data from the bbox annotator.
