Hi!
I have made a custom board using TK1 and now i am going to run shmoo package but when i run the test, myphidget.exe crashed.
I have this phidget kit for testing
I have tested it separately by running its utility. I tried to copy the Phidget21.NET.dll in shmoo folder but it seems no working.
can anyone know the solution for this problem.
Thank You
Hi, did you download Phidget driver 2.1 or later(available at http://www.phidgets.com/drivers.php) used to
control the Phidget for device power on & off and reset signals. ?
I am getting this error:
MyPhidget has stopped working
in Description of error:
Description:
Stopped working
Problem signature:
Problem Event Name: CLR20r3
Problem Signature 01: phidget.exe
Problem Signature 02: 1.0.0.0
Problem Signature 03: 4f26e871
Problem Signature 04: phidget
Problem Signature 05: 1.0.0.0
Problem Signature 06: 4f26e871
Problem Signature 07: 2
Problem Signature 08: 2bc
Problem Signature 09: System.BadImageFormatException
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1033
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
can you guess what is the problem?
Actually, it is also not working when I run it separately in shmoo package. I am testing it from the separately installed library that is available on www.phidgets.com.
