File “/home/kathiravanl4t/L4T_dev/L4T_bsp/Linux_for_Tegra/bootloader/./tegraflash.py”, line 1281, in
tegraflash_run_commands()
File “/home/kathiravanl4t/L4T_dev/L4T_bsp/Linux_for_Tegra/bootloader/./tegraflash.py”, line 1150, in tegraflash_run_commands
interpreter.onecmd(command)
File “/usr/lib/python3.10/cmd.py”, line 217, in onecmd
return func(arg)
File “/home/kathiravan/l4t/L4T_dev/L4T_bsp/Linux_for_Tegra/bootloader/./tegraflash.py”, line 779, in do_dump
tegraflash_dump(exports, args)
File “/home/kathiravanl4t/L4T_dev/L4T_bsp/Linux_for_Tegra/bootloader/tegraflash_internal.py”, line 1246, in tegraflash_dump
tegraflash_dumpeeprom(args, dump_args[1:])
File “/home/kathiravan/4t/L4T_dev/L4T_bsp/Linux_for_Tegra/bootloader/tegraflash_internal.py”, line 1300, in tegraflash_dumpeeprom
tegraflash_boot_mb2_applet()
File “/home/kathiravan/L4T_bsp/Linux_for_Tegra/bootloader/tegraflash_internal.py”, line 2350, in tegraflash_boot_mb2_applet
filename = tegraflash_send_mb2_applet()
File “/home/kathiravan//l4t/L4T_dev/L4T_bsp/Linux_for_Tegra/bootloader/tegraflash_internal.py”, line 2344, in tegraflash_send_mb2_applet
filename = tegraflas_oem_sign_file(filename, 'PLDT')
File “/home/kathiravan//l4t/L4T_dev/L4T_bsp/Linux_for_Tegra/bootloader/tegraflash_internal.py”, line 2109, in tegraflas_oem_sign_file
for file_nodes in xml_tree.getiterator('file'):
AttributeError: ‘ElementTree’ object has no attribute ‘getiterator’
Reading board information failed.
i am getting above error and i changed python to 3.10 in that time also i am getting the same error.
can anyone please help me to identify and slove the problem.
after below state i am getting above error.
2.5070 ] tegrasign_v2 --key None --list nvtboot_applet_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 2.5087 ] Assuming zero filled SBK key
[ 2.5183 ]
thanks.
