**• DeepStream Version 6.2 • TensorRT Version 8.5.1
**• NVIDIA GPU Driver Version 535.0.1
Why do i get segmentation fault when i press ‘p’ to pause and then press ‘r’ while to resume the application of deepstream test 5 and the application is stopped. How do i overcome this problem.
How did you run deepstream test 5 , host or docker ?
And whether you modified the code or configuration file.
Can you share these files so I can reproduce the problem?
