• Hardware Platform (Jetson / GPU) NVIDIA RTX A5000 • DeepStream Version 6.2 • JetPack Version (valid for Jetson only) • TensorRT Version 8.5 • NVIDIA GPU Driver Version (valid for GPU only) 515.57 • Issue Type( questions, new requirements, bugs) questions
I am trying to create docker to run my deepstream app. For the same i followed deepstream tutorials and examples to create my app. App run fine as expected. Then i created docker first for jetson devices then now while trying to run same application but with docker compatible with and architecture i am getting Segmentation fault. In my app i am trying to get frame from nvds buffer using
We needed to change memory if pipeline is not running on aarch64.
Solution to add if not is_aarch64():
# Use CUDA unified memory in the pipeline so frames
# can be easily accessed on CPU in Python.
mem_type = int(pyds.NVBUF_MEM_CUDA_UNIFIED)
streammux.set_property("nvbuf-memory-type", mem_type)
nvvidconv.set_property("nvbuf-memory-type", mem_type)
nvvidconv1.set_property("nvbuf-memory-type", mem_type)
tiler.set_property("nvbuf-memory-type", mem_type)
I have few more question regarding my pipeline should I add them here or create new post.
Thanks a lot again.
If it is a different type of issue, we recommend to open a new topic.
As what you said, you mean the app you used runs well in the RTX A5000. But it crashed when running on the Jetson platform? Did you use the docker we provided? deepstream docker
Could you try to add your patches to our demo and check if it is crash? deepstream_imagedata-multistream.py
The issue is how I can restart a single or n stream if they are stopped because of network issues and then reconnects. But my pipeline returns EOS for them and doesn’t restart them.
