I would like to find out the return address for a device function (for use only in device emulation), and I was wondering if someone knew how to do that. I’m using linux.
The following structure illustrates my point:-
__device__ inline void helperfunc1()
printf("This function was called from address %x\n", [return address function] );
__global__ void kernel(arguments)
// code
helperfunc1();
// code
I tried using __builtin_return_address(1), which is a gcc function (and works on my system).
On trying to compile my code (using make emu=1), I get the following error:-
obj/emurelease/genop.cu_o: In function `void gpu_genop<50u, 0u>(float, float*, float*, unsigned int)':
genop.cu.c:(.text+0xb3d): undefined reference to `__cuda_return_address’
genop.cu.c:(.text+0xb9c): undefined reference to `__cuda_return_address’
collect2: ld returned 1 exit status
make: *** [out/emurelease/genop] Error 1
What is the function __cuda_return_address() ? Can someone explain how to make it work?
My actual problem lies in uniquely identifying (out of potentially many locations) where a function was called in a thread. I could do if I had the instruction pointer for the return.
Thanks for the help.
