Getting "Too Many Requests" always in MiniMax M3
Hi, i’m getting ALWAYS “Too Many Requests” when sending literally “Hi” string for the model.
24 hours after i got the same message.
Model Availability status for Free Endpoint is “Available” in the website, but for sure this isn’t working as should be.
Anyone had this problem i got a solution for this?
Thanks adv.
Did you consider an option that your API key may be exposed and used by someone else? Tried to rotate it and try again?
Not the case, tried this too.
After some tests i saw that max RPM is 2, but is not the only limit in the moment.
The limit is based by tokens too. Sometimes 1 request is enough to trigger the limit in the current 60s delta.
Minimax also works not stable for me, but not as bad as for you.
