I am getting the same error. What could be the problem?
Following are the details:
ece$ nvidia-smi
Mon Aug 28 16:21:36 2017
| NVIDIA-SMI 384.59 Driver Version: 384.59 |
| 0 GeForce GTX 1080 Off | 00000000:07:00.0 Off | N/A |
| 0% 43C P8 12W / 198W | 1MiB / 8114MiB | 0% Default |
| 1 GeForce GTX 980 Off | 00000000:09:00.0 On | N/A |
| 15% 53C P0 55W / 195W | 158MiB / 4037MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 1 1721 G /usr/bin/X 78MiB |
| 1 2693 G /usr/bin/gnome-shell 76MiB |
ece$ vulkaninfo
VULKAN INFO
Vulkan API Version: 1.0.51
INFO: [loader] Code 0 : Found ICD manifest file /etc/vulkan/icd.d/nvidia_icd.json, version “1.0.0”
ERROR: [loader] Code 0 : NV_VK_ICD: cannot open shared object file: No such file or directory
Cannot create Vulkan instance.
/builddir/build/BUILD/Vulkan-LoaderAndValidationLayers-sdk-1.0.51.0/demos/vulkaninfo.c:671: failed with VK_ERROR_INCOMPATIBLE_DRIVER
