GH200 Cuda not available on pytorch
I’m trying to run torch on top of GPUs of a server which i’m root. Drivers seems installed correctly:
> nvcc --version
< nvcc: NVIDIA (R) Cuda compiler driver
Copyright (c) 2005-2023 NVIDIA Corporation
Built on Wed_Nov_22_11:03:34_PST_2023
Cuda compilation tools, release 12.3, V12.3.107
Build cuda_12.3.r12.3/compiler.33567101_0
> nvidia-smi
< Tue Apr  2 18:28:01 2024
| NVIDIA-SMI 545.23.08              Driver Version: 545.23.08    CUDA Version: 12.3     |
| GPU  Name                 Persistence-M | Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp   Perf          Pwr:Usage/Cap |         Memory-Usage | GPU-Util  Compute M. |
|                                         |                      |               MIG M. |
|   0  GH200 480GB                    On  | 00000009:01:00.0 Off |                    0 |
| N/A   27C    P0              79W / 900W |      4MiB / 97871MiB |      0%      Default |
|                                         |                      |             Disabled |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                            GPU Memory |
|        ID   ID                                                             Usage      |
|  No running processes found                                                           |
> lscpu
< Architecture:           aarch64
  CPU op-mode(s):       64-bit
  Byte Order:           Little Endian
CPU(s):                 72
  On-line CPU(s) list:  0-71
Vendor ID:              ARM
  Model name:           Neoverse-V2
    Model:              0
    Thread(s) per core: 1
    Core(s) per socket: 72
    Socket(s):          1
    Stepping:           r0p0
    Frequency boost:    disabled
    CPU max MHz:        3510.0000
    CPU min MHz:        81.0000
    BogoMIPS:           2000.00
    Flags:              fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm jscvt fcma lrcpc
                        dcpop sha3 sm3 sm4 asimddp sha512 sve asimdfhm dit uscat ilrcpc flagm ssbs sb paca pacg dcpodp s
                        ve2 sveaes svepmull svebitperm svesha3 svesm4 flagm2 frint svei8mm svebf16 i8mm bf16 dgh bti
Caches (sum of all):
  L1d:                  4.5 MiB (72 instances)
  L1i:                  4.5 MiB (72 instances)
  L2:                   72 MiB (72 instances)
  L3:                   114 MiB (1 instance)
NUMA:
  NUMA node(s):         9
  NUMA node0 CPU(s):    0-71
  NUMA node1 CPU(s):
  NUMA node2 CPU(s):
  NUMA node3 CPU(s):
  NUMA node4 CPU(s):
  NUMA node5 CPU(s):
  NUMA node6 CPU(s):
  NUMA node7 CPU(s):
  NUMA node8 CPU(s):
Vulnerabilities:
  Gather data sampling: Not affected
  Itlb multihit:        Not affected
  L1tf:                 Not affected
  Mds:                  Not affected
  Meltdown:             Not affected
  Mmio stale data:      Not affected
  Retbleed:             Not affected
  Spec rstack overflow: Not affected
  Spec store bypass:    Mitigation; Speculative Store Bypass disabled via prctl
  Spectre v1:           Mitigation; __user pointer sanitization
  Spectre v2:           Not affected
  Srbds:                Not affected
  Tsx async abort:      Not affected
but when i run
> import torch
> print(torch.cuda.is_available())
< False
what could be the problem?
Solutions i’ve already tried (and not working):
  1. reinstall torch
  2. downgrade cuda drivers from scratch following this link
  3. I also tried to run the previous python script into a container (nvcr.io/nvidia/pytorch) and seems working! However its not what i want, because i need to work direcly on host filesystem.
Thanks in advance! :)
This is a common question on various forums.
I think you’re more likely to get help by asking on a torch forum like discuss.pytorch.org
There are NVIDIA experts on those forums.
That was going to be my suggestion also. You should be able to mount a portion of the host filesystem in the container.
Already asked on pytorch forum. However i wondered if occurred something like that in someone’s experience.
Yes i can but i prefer to avoid using containers in this situation.
Seems that pytorch does not support ARM architecture + cuda
