Graphics / DLSS
System:
- GPU: NVIDIA GeForce RTX 4070
- Driver: 617.14 WHQL
- Engine: Unreal Engine 5.6
- DLSS Plugin: DLSS 4.5 Plugin 8.7.2
- OS: Windows 11 64-bit
Issue:
A black cat character (skeletal mesh, fur uses a masked material with some translucency on the edges) walking across a dark floor. With DLSS enabled, a semi-transparent copy of the cat appears behind it and stays for several frames. In motion it looks like a second cat following the first one. Our team now calls it “Ghost Cat” and it’s become a running joke in our Discord, but it’s actually hurting our trailer captures, so I’d like to fix it.
What I tested:
- DLSS Performance: very visible, sometimes 2–3 faded silhouettes
- DLSS Quality: reduced but still noticeable
- DLAA: almost gone
- TAA: slight trail, much weaker than DLSS Performance
- Ray Reconstruction on: mostly fixes it, but the performance cost is too high for our target
What I suspect:
Motion vectors on the fur edges. The masked/translucent parts probably aren’t writing correct velocity, so the upscaler reuses old history. Similar to the hair translucency issue someone mentioned in another thread.
Steps to reproduce:
- Dark skeletal mesh character with masked/translucent fur material
- Dark, low-contrast floor
- Enable DLSS (Performance)
- Move the character quickly across the screen
Is there a recommended way to handle velocity output for translucent fur, or a preset that handles this better?
