New GigaChat3.5-432B-A28B dropped. Some quants might fit 2x Sparks if any good. Anyone planning to test it?
I’m sure it has some real good “hallucinations”
Do you also not use any of the “Xi-approved” models? By that logic you should view them as tremendously worse, but I think that’s all I’ll say since this isn’t a political forum. It looks like it could be an interesting model and nice to see more diversity in the space.
I believe that this is absolutely not the way to approach any model.
However, I would like to draw attention to another aspect. I recently spoke with a person who deals with national security issues and conducts quite extensive research in this area. AI technology is not his primary area of interest (rather, the effects of AI application), but in connection with other issues, he said he has serious doubts about the extent of fine-tuning models for political and espionage purposes. He mentioned that he had already seen research on the “Tiananmen Massacre” AI bias, which suggests that model limitations/modifications are not limited to simply refusing to respond but also to more active manipulation - they provide false information, including these limitations in the COT when responding to other topics. As an example, he cited a Chinese model used in a legaltech system, which, when tested in the area of human rights protection outside China, exhibited strange behavior. In this selected area, it provided responses that were clearly aimed at a model of lack of protection of these rights. Interestingly, they observed the same strange behavior even with simple translation of the case documents. I don’t have the knowledge or skills to investigate this myself, but I think great caution is needed here. If what he mentioned is actually happening, then the coding models could very well be injecting backdoors into the applications they create
No need for politics on the forum, I understand everything. No need to teach others, keep your opinion to yourself. Any LLM can be useful, the main thing is to take what you need from each model and use this resource to your advantage
As for the LLM of Russian IT companies, they are far behind in the development of this field. This is my subjective opinion)
I will definitely try it, need only NVFP4 quant or autoround. I think everyone already tired of these political activists everywhere. The only reason for me to not consider some model - bad test results.
P.S. And the license model, sorry MiniMax-M3
Yes, it’s off-topic so it’s not possible to go into the required depth here and there’s no benefit in people repeating simple, widely-repeated talking points under the idea they have some perfect view of things.
I agree it’s likely that Russian companies would be behind, which is why I’d enjoy hearing anything about the training details of the model if anyone knows them or could point to a resource. I made some brief searches but didn’t find anything. They have a significantly more limited chip situation than China does.
Those are always concerns though. Models are literally trained using methods, like RLHF, that require the model-maker(s) to bake tons of their viewpoints into the model. This happens even without any conscious effort to do so.
As for code, all models can introduce vulnerabilities and likely always will, including remote code execution vulnerabilities (backdoors). This has even happened numerous times in open source, before and after LLMs, because humans do it too. I understand that people want to “move faster”, so LLM-generated code is often not properly reviewed, but it’s not a new problem.
Perhaps the person you spoke with also views them as risks, but I’d say be far more worried about computer hardware that’s entirely produced by Chinese companies. There’s a difference between a US company like Apple having its products manufactured in China versus an entirely end-to-end Chinese product, like many of the mini PCs, WiFi routers, drones, robot dogs, or cheaper phones and tablets. All of those products can have backdoors, many have been found by security researchers to have backdoors, and they’re vastly harder to detect and then do anything about compared with code that an LLM generated, although yes, that is always a risk with any model.
In Russia, there are two companies that are actively developing the LLM direction: Yandex (an internet search engine similar to Google) and Sberbank, the bank’s IT division.
In the context of LLM from these brands, I can add the following:
Both models are primarily designed and trained for smart speakers, consultations, and information retrieval. I have tested and compared them in coding and financial instrument management. I observed the result that they lose in logic and in questions with a trick to the QWEN-3.6-27b model very strongly. There are certainly areas to which Qwen will be inferior, but I have not met such.
I hope they will catch up and be able to compete with the advanced models, and we, the ordinary users, will get a little bit of the open models from their desire to become better))
Yeah, a lot of people use actually Yandex Alisa, it’s probably on the level of Siri or GPT 3, mostly voice search assistant. Nothing advanced. Western providers are not available, like ChatGPT and Gemini, without VPN and some western payment methods. But they do have modern computers and gpus, stuff smuggled through Kazakhstan and China mostly. You can find latest iPhone or MacBook in every large shopping center if you have the money. But original research and development - nah. Anyone who genuinely can do it left long time ago. But take a model, sft and bake a Lora in - sure, don’t need massive cost or gigabrains.
This is the saddest part since Russian minds have shaped the math and neuroscience behind machine learning.
Since most of them move to USA and Europe - its a win, I guess :D
This is outdated information. Yandex has dropped out of the race of training its own models. Nowadays, Alisa is just a rebranded Qwen.
There is only one player left in Russia —Sber.
GigaChat: These models are trained completely from scratch.
GigaChat 3: Something similar to Mistral 3. They adopted the DeepSeek-V3 architecture and did their own custom full-training.
GigaChat 3.5: This one is much more interesting. It use the DeltaNet attention mechanism like Qwen 3.5, above implements MLA from DeepSeek-V3. Their official briefing claims it is the only model of this scale utilizing this specific combination of technologies for models more 100b.
It’s funny though that GigaChat 3 Ultra was 700B, while the new 3.5 has been downscaled to 420B. A bit of a step back, but on the bright side, you can actually cram this footprint into dual Sparks! ))
Some folks on this forum quite like Mistral, so perhaps GigaChat might come in handy for certain use cases as well, though that remains to be seen.
Don’t waste your time on this model!
I conducted several tests on this model’s website https://giga.chat
My conclusion: It’s sad…
I believe that more competition is always a good thing. But if you’re busy and localLLM is more work than hobby, I think it’s probably not a good use of your time to try every new model/finetune developed by labs without an existing track record or reputation, unless they have revolutionary research results attached to the model (i.e. DeepSeek R1).
From my limited experience, it’s not wise to expect any fine tunes to fundamentally change a model’s capability. If you are satisfied with Qwen 397b, you could try Nex, or that weird Rio fine tune. If you think 397b is not smart enough for your tasks, then skip all of these. It’s going to be more like spraying WD-40 than getting a new engine or even putting on a turbo. Slightly more reliable tool calls, maybe better/smoother thinking traces if you’re lucky.
Good models need large amount of data, and good data for pre/post train. And labs get more/better data with better model. It’s a positive feedback loop that’s going to make good labs better off and stagnating labs worse off.
