Hi Kai,
Thanks for your advice. By selecting Visual Studio 15 2017 Win64 and the v140 toolset I was able to generate the project without having to run cmake-gui from a visual studio command prompt.
I do still get the $<COMPILE_LANGUAGE:CXX> messages however and I’ve included the complete error output regarding those below.
I also still get the undeclared M_PI errors. I tried adding the explicit M_PI define in CMakeLists.txt however that didn’t fix the problem. I checked the Command Line properties in the mdl-jit-gnerator_jit project and it doesn’t even contain an M_PI define in there. I undid my changes then configured from scratch again and the _USE_MATH_DEFINES define isn’t being set either. In fact I’m not seeing any of the defines from CMakeLists.txt (__STDC_CONSTANT_MACROS etc.) in there:
/MP /GS /TP /W3 /Zc:wchar_t /I"E:\git\mdl\build\another\src\mdl\jit\generator_jit" /I"E:\git\mdl\MDL-SDK\src\mdl\jit\generator_jit" /I"E:\git\mdl\MDL-SDK\include" /I"E:\git\mdl\MDL-SDK\src" /I"E:\git\mdl\build\another\src\mdl\jit\generator_jit\generated" /I"E:\git\mdl\MDL-SDK\src\base\system\version" /I"E:\git\mdl\thirdparty\boost_1_67_0" /I"E:\git\mdl\MDL-SDK\src\mdl\jit\llvm\dist\include" /I"E:\git\mdl\build\another\src\mdl\jit\llvm\dist\include" /Zi /Gm- /Od /Ob0 /Fd"mdl-jit-generator_jit.dir\Debug\mdl-jit-generator_jit.pdb" /Zc:inline /fp:precise /D "WIN32" /D "_WINDOWS" /D "DEBUG" /D "_DEBUG" /D "MISTD=std" /D "BIT64=1" /D "X86=1" /D "MI_PLATFORM=\"nt-x86-64-vc14\"" /D "MI_PLATFORM_WINDOWS" /D "WIN_NT" /D "_MSC_VER=1900" /D "CMAKE_INTDIR=\"Debug\"" /D "_MBCS" /errorReport:prompt /WX- /Zc:forScope /RTC1 /GR /Gd /MTd /Fa"Debug/" /EHsc /nologo /Fo"mdl-jit-generator_jit.dir\Debug\" /Fp"mdl-jit-generator_jit.dir\Debug\mdl-jit-generator_jit.pch"
[code]
CMake Error at cmake/utilities.cmake:26 (target_compile_options):
Error evaluating generator expression:
$<COMPILE_LANGUAGE:…> may not be used with Visual Studio generators.
Call Stack (most recent call first):
cmake/utilities.cmake:507 (target_build_setup)
src/base/system/main/CMakeLists.txt:11 (create_from_base_preset)
src/base/system/version/CMakeLists.txt:11 (create_from_base_preset)
src/base/lib/libzip/CMakeLists.txt:129 (create_from_base_preset)
src/base/lib/zlib/CMakeLists.txt:25 (create_from_base_preset)
src/mdl/compiler/coco/CMakeLists.txt:31 (create_from_base_preset)
src/base/util/string_utils/CMakeLists.txt:10 (create_from_base_preset)
src/base/util/registry/CMakeLists.txt:10 (create_from_base_preset)
src/base/hal/disk/CMakeLists.txt:15 (create_from_base_preset)
src/base/hal/hal/CMakeLists.txt:12 (create_from_base_preset)
src/base/hal/link/CMakeLists.txt:10 (create_from_base_preset)
src/base/hal/time/CMakeLists.txt:11 (create_from_base_preset)
src/base/lib/config/CMakeLists.txt:10 (create_from_base_preset)
src/base/lib/mem/CMakeLists.txt:11 (create_from_base_preset)
src/base/lib/path/CMakeLists.txt:10 (create_from_base_preset)
src/base/lib/plug/CMakeLists.txt:11 (create_from_base_preset)
src/base/data/attr/CMakeLists.txt:18 (create_from_base_preset)
src/base/data/dblight/CMakeLists.txt:14 (create_from_base_preset)
src/base/data/serial/CMakeLists.txt:13 (create_from_base_preset)
src/io/image/CMakeLists.txt:15 (create_from_base_preset)
src/io/scene/CMakeLists.txt:26 (create_from_base_preset)
src/api/api/mdl/CMakeLists.txt:63 (create_from_base_preset)
src/mdl/codegenerators/generator_code/CMakeLists.txt:10 (create_from_base_preset)
src/mdl/codegenerators/generator_dag/CMakeLists.txt:23 (create_from_base_preset)
src/mdl/compiler/compilercore/CMakeLists.txt:71 (create_from_base_preset)
src/mdl/jit/devlib/CMakeLists.txt:10 (create_from_base_preset)
CMake Error at src/mdl/jit/devlib/CMakeLists.txt:17 (target_compile_options):
src/mdl/jit/generator_jit/CMakeLists.txt:37 (create_from_base_preset)
CMake Error at src/mdl/jit/generator_jit/CMakeLists.txt:45 (target_compile_options):
src/mdl/no_glsl/generator_stub/CMakeLists.txt:10 (create_from_base_preset)
src/mdl/no_jit/generator_stub/CMakeLists.txt:10 (create_from_base_preset)
src/mdl/runtime/CMakeLists.txt:14 (create_from_base_preset)
src/mdl/integration/mdlnr/CMakeLists.txt:11 (create_from_base_preset)
src/render/mdl/backends/CMakeLists.txt:11 (create_from_base_preset)
src/render/mdl/runtime/CMakeLists.txt:13 (create_from_base_preset)
src/prod/bin/mdlc/CMakeLists.txt:13 (create_from_base_preset)
src/prod/lib/mdl_core/CMakeLists.txt:14 (create_from_base_preset)
src/prod/lib/mdl_sdk/CMakeLists.txt:17 (create_from_base_preset)
src/shaders/plugin/dds/CMakeLists.txt:19 (create_from_base_preset)
src/shaders/plugin/freeimage/CMakeLists.txt:17 (create_from_base_preset)
examples/thirdparty/imgui/CMakeLists.txt:21 (create_from_base_preset)
examples/thirdparty/tinyxml2/CMakeLists.txt:12 (create_from_base_preset)
examples/mdl_sdk/shared/CMakeLists.txt:21 (create_from_base_preset)
