Hi @WayneWWW,
I start with answering your questions:
- No, the PCIe error happens only with the B01 model. The new one that I have bought. It happens both with the new SD card and the system running from USB SSD.
- Yes, it also happens with no application running. The serial monitor logs that error even with the board in idel condition. That does not happen with the model A02.
Update on the reboot test. I followed your suggestion and I have tested the B01 board with a virgin installation running the test3 (with modified sink). The system rebooted after 13 hours:
[ 2481.298310] nvmap_alloc_handle: PID 24629: deepstream-test: WARNING: All NvMap Allocations must have a tag to identify the subsystem allocating memory.Please pass the tag to the API call NvRmMemHanldeAllocAttr() or relevant.
[ 2547.142540] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[ 2547.153127] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[ 2547.162748] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[ 3069.310332] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[ 3069.320567] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[ 3069.328951] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[ 3204.620069] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[ 3204.630348] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[ 3204.638751] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[ 3237.325623] nvmap_alloc_handle: PID 25504: deepstream-test: WARNING: All NvMap Allocations must have a tag to identify the subsystem allocating memory.Please pass the tag to the API call NvRmMemHanldeAllocAttr() or relevant.
[ 3544.895179] nvmap_alloc_handle: PID 25762: deepstream-test: WARNING: All NvMap Allocations must have a tag to identify the subsystem allocating memory.Please pass the tag to the API call NvRmMemHanldeAllocAttr() or relevant.
[ 3694.486136] nvmap_alloc_handle: PID 25876: deepstream-test: WARNING: All NvMap Allocations must have a tag to identify the subsystem allocating memory.Please pass the tag to the API call NvRmMemHanldeAllocAttr() or relevant.
[ 3829.505138] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[ 3829.515495] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[ 3829.525101] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[ 4301.401428] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[ 4301.411648] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[ 4301.420127] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[ 4699.923482] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[ 4699.933845] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[ 4699.942254] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[ 4704.380219] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[ 4704.390432] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[ 4704.398903] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[ 4984.462448] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[ 4984.472733] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[ 4984.481219] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[ 5239.496408] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[ 5239.506646] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[ 5239.515151] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[ 5244.856556] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[ 5244.866894] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[ 5244.876513] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[ 5383.112661] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[ 5383.125853] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[ 5383.135285] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[ 5555.630474] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[ 5555.640725] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[ 5555.649163] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[ 5582.934188] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[ 5582.945952] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[ 5582.955437] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[ 5986.752396] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[ 5986.762661] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[ 5986.771138] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[ 6001.066925] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[ 6001.077253] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[ 6001.085679] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[ 6385.286333] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[ 6385.296596] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[ 6385.305052] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[ 6518.078827] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[ 6518.090378] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[ 6518.098772] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[ 6827.179587] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[ 6827.189865] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[ 6827.198402] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[ 6845.122111] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[ 6845.133746] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[ 6845.142752] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[ 7136.454764] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[ 7136.465071] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[ 7136.473680] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[ 7315.957757] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[ 7315.968028] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[ 7315.976656] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[ 7428.406574] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[ 7428.416804] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[ 7428.425196] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[ 7594.376226] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[ 7594.386526] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[ 7594.395016] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[ 7742.343007] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[ 7742.353328] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[ 7742.361910] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[ 7805.350766] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[ 7805.361027] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[ 7805.369429] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[ 7895.531107] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[ 7895.541476] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[ 7895.549871] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[ 7934.418950] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[ 7934.430483] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[ 7934.438882] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[ 8143.524417] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[ 8143.534724] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[ 8143.543170] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[ 8740.552607] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[ 8740.562898] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[ 8740.571294] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[ 8747.308790] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[ 8747.319122] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[ 8747.327563] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[ 8983.357800] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[ 8983.368024] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[ 8983.376450] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[ 9047.552739] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[ 9047.564234] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[ 9047.572712] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[ 9083.811655] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[ 9083.821941] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[ 9083.830341] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[ 9247.128331] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[ 9247.140172] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[ 9247.148636] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[ 9348.844755] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[ 9348.855164] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[ 9348.863602] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[ 9518.018461] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[ 9518.028704] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[ 9518.037089] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[ 9599.143523] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[ 9599.153844] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[ 9599.162274] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[ 9691.924645] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[ 9691.936598] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[ 9691.945096] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[ 9825.917152] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[ 9825.929158] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[ 9825.938318] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[ 9965.968999] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[ 9965.979244] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[ 9965.987681] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[10448.900720] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[10448.912456] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[10448.920869] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[10467.754846] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[10467.766459] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[10467.775570] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[10627.103412] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[10627.113638] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[10627.122112] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[11032.099079] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[11032.109421] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[11032.117898] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[11156.423722] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[11156.434029] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[11156.442409] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[11432.059473] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[11432.069908] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[11432.078431] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[11536.615924] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[11536.626178] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[11536.634563] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[11663.731535] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[11663.741866] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[11663.750301] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[11704.676000] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[11704.686422] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[11704.694817] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[11715.507221] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[11715.517517] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[11715.525983] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[11954.196226] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[11954.206892] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[11954.215543] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[12295.010337] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[12295.020945] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[12295.029448] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[12296.191527] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[12296.201792] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[12296.210250] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[12309.818186] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[12309.828488] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[12309.836925] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[12466.580244] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[12466.591948] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[12466.600777] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[12867.862794] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[12867.873095] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[12867.881513] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[12883.473557] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[12883.483868] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[12883.492307] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[13233.060192] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[13233.070480] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[13233.078868] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[13274.358051] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[13274.369962] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[13274.378423] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[13314.398364] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[13314.408633] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[13314.417060] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[13407.152802] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[13407.163019] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[13407.171431] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[13803.947849] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[13803.958431] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[13803.966809] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[13853.501711] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[13853.512021] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[13853.520503] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[13863.916831] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[13863.928419] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[13863.936812] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[14179.851081] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[14179.861348] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[14179.870020] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[14195.625717] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[14195.635966] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[14195.644347] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[14567.343598] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[14567.353881] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[14567.362281] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[14611.627146] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[14611.637447] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[14611.645894] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[14640.574484] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[14640.584770] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[14640.593251] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[14951.978855] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[14951.990443] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[14951.998825] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[15136.815257] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[15136.825543] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[15136.833907] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[15220.585809] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[15220.596070] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[15220.604537] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[15525.006691] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[15525.016964] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[15525.025398] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[15658.621418] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[15658.631678] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[15658.640067] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[15796.143257] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[15796.153480] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[15796.163103] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[16124.444871] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[16124.455166] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[16124.463596] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[16261.341463] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[16261.351939] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[16261.360352] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[16321.996622] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[16322.007119] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[16322.015519] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[16511.657290] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[16511.667621] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[16511.676085] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[16738.561125] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[16738.571355] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[16738.579798] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[16748.539225] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[16748.549443] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[16748.557867] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[16801.108411] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[16801.120047] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[16801.128428] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[16870.459330] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[16870.469611] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[16870.478340] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[16922.403772] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[16922.414086] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[16922.422538] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[16995.767352] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[16995.777701] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[16995.786165] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[17241.815603] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[17241.827195] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[17241.835591] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[17262.487767] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[17262.498005] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[17262.506392] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[17313.452181] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[17313.462768] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[17313.471133] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[17347.509027] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[17347.519619] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[17347.528227] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[17465.323200] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[17465.333414] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[17465.341794] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[17676.517559] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[17676.527797] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[17676.536180] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[17705.886292] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[17705.896525] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[17705.904911] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[17763.490621] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[17763.500873] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[17763.509488] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[18008.554584] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[18008.566358] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[18008.574749] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[18548.707962] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[18548.719432] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[18548.727830] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[18598.321547] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[18598.331846] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[18598.340362] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[18760.514887] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[18760.525142] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[18760.533538] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[18844.325806] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[18844.337380] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[18844.345822] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[19225.396102] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[19225.406374] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[19225.414769] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[19291.971921] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[19291.982148] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[19291.990532] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[19331.334222] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[19331.344500] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[19331.352907] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[19705.993990] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[19706.004215] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[19706.012615] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[19805.565941] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[19805.576166] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[19805.584574] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[19924.921335] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[19924.931569] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[19924.939981] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[20089.184937] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[20089.195346] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[20089.203787] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[20110.701762] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[20110.711981] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[20110.720371] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[20525.956585] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[20525.966967] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[20525.975451] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[20733.711903] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[20733.722130] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[20733.730540] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[20753.976935] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[20753.987403] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[20753.995802] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[20864.658986] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[20864.669761] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[20864.678353] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[20868.316309] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[20868.326591] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[20868.334988] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[20897.298449] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[20897.308680] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[20897.317065] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[21150.509562] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[21150.519831] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[21150.528261] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[21182.967692] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[21182.977939] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[21182.986345] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[21220.470230] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[21220.480448] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[21220.488849] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[21517.257859] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[21517.268060] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[21517.276438] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[21797.717797] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[21797.728360] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[21797.736827] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[21998.368518] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[21998.378742] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[21998.387130] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[22184.790167] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[22184.800753] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[22184.809158] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[22212.721739] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[22212.732101] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[22212.740540] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[22321.441245] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[22321.451479] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[22321.459877] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[22477.596700] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[22477.608238] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[22477.616791] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[22571.813852] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[22571.824117] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[22571.832520] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[23060.573037] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[23060.583348] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[23060.591796] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[23110.707653] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[23110.717914] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[23110.726314] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[23133.214266] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[23133.224531] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[23133.232985] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[23209.655648] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[23209.666031] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[23209.674445] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[23328.692313] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[23328.702574] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[23328.710998] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[23467.437180] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[23467.447402] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[23467.455977] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[23599.543630] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[23599.553943] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[23599.562368] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[23774.274812] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[23774.285118] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[23774.293697] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[24011.380134] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[24011.390375] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[24011.398796] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[24499.914669] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[24499.924904] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[24499.933295] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[24727.044147] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[24727.054391] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[24727.062782] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[25275.608911] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[25275.619377] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[25275.627832] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[25292.497183] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[25292.507452] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[25292.515857] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[25582.014403] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[25582.024623] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[25582.033024] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[25603.346181] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[25603.356471] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[25603.364858] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[25630.307934] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[25630.318160] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[25630.326557] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[25756.848711] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[25756.858977] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[25756.867364] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[25859.029691] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[25859.040116] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[25859.048517] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[25883.022161] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[25883.032424] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[25883.040975] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[26160.635076] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[26160.645723] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[26160.654113] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[26688.427027] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[26688.437278] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[26688.445663] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[26908.111055] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[26908.121283] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[26908.129681] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[27022.564938] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[27022.575231] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[27022.583664] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[27302.925014] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[27302.935275] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[27302.943705] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[27386.357335] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[27386.367584] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[27386.375972] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[27703.346878] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[27703.357166] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[27703.365557] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[27797.052329] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[27797.062570] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[27797.070949] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[27832.301798] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[27832.312025] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[27832.320432] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[28416.734524] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[28416.744744] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[28416.753156] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[28498.299572] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[28498.309882] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[28498.318384] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[28856.161171] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[28856.171631] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[28856.180139] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[28913.888785] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[28913.899068] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[28913.907516] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[29541.895606] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[29541.905815] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[29541.914257] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[29890.008502] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[29890.018766] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[29890.027196] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[29890.675165] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[29890.685393] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[29890.693774] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[30330.044333] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[30330.054919] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[30330.063327] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[30423.596577] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[30423.606822] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[30423.615280] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[30428.548528] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[30428.558797] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[30428.567235] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[30450.350553] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[30450.361212] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[30450.369698] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[31214.340331] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[31214.350566] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[31214.359027] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[31666.237590] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[31666.249464] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[31666.257996] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[31870.334638] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[31870.345009] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[31870.353416] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[31933.213091] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[31933.223346] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[31933.231734] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[32004.082683] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[32004.093012] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[32004.101463] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[32026.049405] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[32026.059721] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[32026.068142] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[32076.148372] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[32076.158645] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[32076.167043] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[32225.181818] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[32225.192094] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[32225.200552] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[32238.586768] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[32238.597046] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[32238.605412] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[32420.971280] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[32420.981529] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[32420.989944] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[32575.841872] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[32575.852121] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[32575.860506] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[32595.284259] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[32595.294529] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[32595.302954] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[33140.371248] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[33140.381501] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[33140.389951] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[33155.418776] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[33155.429046] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[33155.437429] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[33330.931790] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[33330.942052] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[33330.950424] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[33561.599317] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[33561.610801] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[33561.619200] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[34011.702648] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[34011.712940] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[34011.721362] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[34122.325391] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[34122.335712] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[34122.344176] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[34516.586558] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[34516.596848] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[34516.605353] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[34535.018726] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[34535.029008] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[34535.037402] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[34633.137734] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[34633.153631] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[34633.162189] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[34649.813125] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[34649.823580] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[34649.832037] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[34770.949852] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[34770.960224] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[34770.968853] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[34910.976446] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[34910.986959] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[34910.995370] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[35390.603252] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[35390.614812] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[35390.623206] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[35594.083654] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[35594.093974] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[35594.102432] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[35739.552967] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[35739.563196] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[35739.571639] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[35789.335870] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[35789.347463] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[35789.356132] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[35806.349452] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[35806.359723] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[35806.368114] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[36084.152404] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[36084.164248] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[36084.172644] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[36145.437180] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[36145.447426] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[36145.455930] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[36467.507823] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[36467.518098] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[36467.526514] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[36655.382338] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[36655.392592] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[36655.401378] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[36798.425407] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[36798.435678] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[36798.444179] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[37051.418190] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[37051.428423] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[37051.436819] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[37384.454134] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[37384.464404] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[37384.472878] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[37570.192879] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[37570.203181] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[37570.211642] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[38031.805627] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[38031.815876] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[38031.824287] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[38177.649281] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[38177.659520] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[38177.667906] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[38338.215016] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[38338.225270] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[38338.233681] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[38361.513731] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[38361.523965] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[38361.532481] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[38388.143798] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[38388.154069] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[38388.162480] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[38633.004080] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[38633.015719] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[38633.024110] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[38692.730814] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[38692.741184] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[38692.749590] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[38709.676221] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[38709.686616] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[38709.695003] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[38783.036232] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[38783.046450] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[38783.054821] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[39082.197231] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[39082.207521] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[39082.215926] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[39265.577030] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[39265.587248] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[39265.595620] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[39732.205343] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[39732.215635] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[39732.224312] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[40054.557369] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[40054.567682] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[40054.576072] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[40239.488663] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[40239.499012] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[40239.507777] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[40756.789588] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[40756.799797] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[40756.808160] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[40936.637303] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[40936.647535] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[40936.655935] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[41152.091967] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[41152.102197] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[41152.110581] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[41202.394856] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[41202.405073] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[41202.413439] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[41509.572231] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[41509.583805] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[41509.592192] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[41722.072536] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[41722.082923] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[41722.091361] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[41777.066300] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[41777.076535] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[41777.084950] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[41962.874889] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[41962.885280] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[41962.893701] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[42347.166828] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[42347.177104] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[42347.185481] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[42731.891542] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[42731.901967] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[42731.910438] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[42978.317063] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[42978.327295] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[42978.335709] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[43197.077838] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[43197.088099] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[43197.096498] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[44145.328139] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[44145.339753] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[44145.348235] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[44145.578456] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[44145.588764] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[44145.597230] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[44375.308590] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[44375.318962] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[44375.327438] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[44587.570415] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[44587.580744] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[44587.589130] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[44591.294716] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[44591.304970] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[44591.313441] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[44661.288233] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[44661.299715] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[44661.308094] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[44669.727042] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[44669.737300] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[44669.745815] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[44765.203456] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[44765.213739] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[44765.222161] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[44777.337257] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[44777.347497] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[44777.355895] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[44817.406072] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[44817.416336] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[44817.424720] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[44875.292646] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[44875.302911] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[44875.311377] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[45050.573779] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[45050.584058] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[45050.592452] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[45299.804981] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[45299.815360] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[45299.824008] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[46113.326258] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[46113.336492] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[46113.344999] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[46229.678035] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[46229.688651] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[46229.697043] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[46299.465806] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[46299.476156] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[46299.484574] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[46704.144156] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[46704.154516] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[46704.163001] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[46860.066968] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[46860.077294] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[46860.085676] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[46935.732043] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[46935.742410] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[46935.750856] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[46972.950477] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[46972.962425] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[46972.971721] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[47004.617436] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[47004.627774] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[47004.636324] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[47426.169666] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[47426.179919] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[47426.188363] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[47485.894364] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[47485.904732] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[47485.913282] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[47525.332425] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[47525.342708] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[47525.351152] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[47565.060558] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[47565.070795] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[47565.079209] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[47604.344142] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[47604.354484] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[47604.362871] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[47639.617258] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[47639.627576] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[47639.636028] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[47644.736237] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[47644.746476] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[47644.755009] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[47692.641197] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[47692.651436] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[47692.659900] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
[47939.692141] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[47939.702370] pcieport 0000:00:02.0: device [10de:0faf] error status/mask=00000001/00002000
[47939.710755] pcieport 0000:00:02.0: [ 0] Receiver Error (First)
\00\00[0000.125] [L4T TegraBoot] (version 00.00.2018.01-l4t-80a468da)
[0000.131] Processing in cold boot mode Bootloader 2
[0000.135] A02 Bootrom Patch rev = 1023
[0000.139] Power-up reason: pmc por
[0000.142] No Battery Present
[0000.145] pmic max77620 reset reason
[0000.148] pmic max77620 NVERC : 0x50
[0000.151] RamCode = 0
[0000.154] Platform has DDR4 type RAM
The PCIe bus error seems to be a common error with certain hardware and Ubuntu: https://itsfoss.com/pcie-bus-error-severity-corrected/
In any case the system crashed anyway. This time it did not say anything about GPU disappearing.
Thanks again!!!
