eclipse-cdt reports as installed successfully but no C/C++ functionality is in eclipse
Why on earth would you move from a stable 14.04 to this crap? :-(
Even trying to install CDT from software update gives an error
An error occurred while installing the items
session context was:(profile=PlatformProfile, phase=org.eclipse.equinox.internal.p2.engine.phases.Install, operand=null --> [R]org.eclipse.help.feature.jar 1.4.1.dist-8v7oFS1FCmSPZrHoSx597H, action=org.eclipse.equinox.internal.p2.touchpoint.eclipse.actions.InstallFeatureAction).
The artifact file for org.eclipse.update.feature,org.eclipse.help,1.4.1.dist-8v7oFS1FCmSPZrHoSx597H was not found.
That canonical Ubuntu moved the LTS support from 14.04 -> 16.04 - notice the “LTS” on: “Ubuntu 16.04.1 LTS (Xenial Xerus)” per: http://releases.ubuntu.com/16.04/
You can find particular libraries by using the “apt-file search XYZ.so” command to see which debian package you need to install and if it exists on this 16.04 version of Ubuntu (sometimes the packages are just “re-named” from previous ubuntu versions like 14.04). You could also troll through the ubuntu web-ui for packages (obviously for xenial instead of trusty): http://packages.ubuntu.com/trusty/glade-gtk2
And if it isn’t available on 16.04 (this is a ubuntu thing not an NVIDIA issue) you can either download a previous version and install it, or you can download the sources and build from it. But in no cases is this a bug from NVIDIA SW.
i think 14.04 remains LTS until 2019. at least that is what the roadmap shows. my experience has been the most problematic issue is the move to 64bit userspace , many packages lag behind in 64bit coverage. personally i’m happy for the change to 64bit even if there are a few bumps on the way because the packages that do work are much better than the 32bit equivelent.
Just because Ubuntu move from 14.04LTS to 16.04LTS should not mean that the vendor of an embedded system (i.e. Nvidia) update their supported file system lock stock and barrel.
I’m still running Windows 7 on my PC. Why? Because I don’t want to introduce problems that don’t currently exist.
Build glade from source? Have you seen how many packages it depends on? No thanks.
