I get these messages when I set an OpenGL debug message callback on NVidia drivers:
Buffer detailed info: Buffer object 2 (bound to GL_ELEMENT_ARRAY_BUFFER_ARB, usage hint is GL_STATIC_DRAW) will use VIDEO memory as the source for buffer object operations.
Buffer detailed info: Buffer object 1 (bound to GL_ARRAY_BUFFER_ARB, usage hint is GL_STATIC_DRAW) will use VIDEO memory as the source for buffer object operations.
Can someone explain what these messages mean and/or if I should be doing something differently?
Thats just debug output from the GL context giving more details as to what the driver is doing with the hints provided when populating a vertex/index buffer data store.
It sounds quite logical though; GL_STATIC_DRAW means don’t mess with CPU memory and use GPU memory. Right now it seems the driver (344.11 in my case) is a bit too enthusiastic. I log these messages, but seemingly I have to write specific code to skip meaningless messages like this?
