Hi, I have a problem with a jetson Xavier NX, I get an error when I launch a glfw application: GLX: No GLXFBConfigs returned the strange is that this happens only with some apps. Any idea ? I use the latest Jetpack…
Would need you r help to share us a way to replicate the issue. Please check the samples in
/usr/src/nvidia/graphics_demos/
And try to reproduce it with either sample. For latest Jetpack, do you mean Jetpack 4.6.2 or 5.0.2?
Also, be certain you are not connected using ssh
with or without forwarding. The error might be to a different computer than you think if using ssh
