Glibc”2.28” not found when using torch1.6.0
When I was using vscode running an python3.6.9 ai training program using pytorch1.6.0 on Jetson nano and it reported that glibc “2.28” not found. After I checked out that my system ubuntu18.04 which was installed by using jetpack 4.4,I found that the glibc in the system was 2.27, so I was going to download and install glibc2.28. But I failed to do it many times.Later I found it might be the reason that ubuntu18.04 supports up to glibc2.27. Can anyone give me some advice of solving this problem?
How do you install the PyTorch package?
Do you use the package from PyTorch for Jetson ?
If yes, the v1.6.0 package should be compatible to the JetPack4.4.
Could you share a detailed error log with us?
@yangqian406 Hello! I’m facing the exact problem right now and I can’t seem to get over it. Have you solved this issue?
Hi! I noticed that you met the same problem as I did. To solve the problem, I had found that using python3 jetson nano initially installed instead of conda or docker version of python environment should help pytorch to apply successfully.
