and this is the case ;)
Uh, what is āCanadaā here. Iāve only been following this loosely lately and Iām really confused. Would love trying it as Iām mostly interested in accuracy as well.
Yeah, well Iāve been following it, and yet this is the first Iāve heard of it⦠I am perplexed tbh.
Iām going to ask that you adopt my āRochdaleā fork istead:
HF: canada-quant/GLM-5.3-Flash-W4A16-MTP
I would totally be down to try it. Iāve hit a slight pause in my months long document processing task, so it would be a good time. The problem is that I do want to still keep a copy of the old Entrpi variant around, but my Spark(s) barely has/have any space left, so Iām gonna need to clear a lot out somehow, and I feel like Iāve looked under the cushion in almost every couch at this point. My poor 1TB drive has been thoroughly abused on this thing.
Question, does this still keep all of the usual OpenAI endpoints, so I can query it with curl and Open WebUI like normal? Supports tool calling fine, etc? Have seen people complain about that. Does it support the āreasoning_effortā flag normally?
Otherwise yeah Iām going to definitely see if I can get it up and running, thanks.
I see, what engine are you using to run it? Or is it just on the HF page? Thanks.
sorry, forgot to mention:
eugr/spark-vllm-b12x:nightly-20260927 (vLLM 0.1.dev21510+g1794dcf18, digest sha256:42f762c0...84cd, native MTP
Hi all, weāre the canada-quant folks behind canada-quant/GLM-5.3-Flash-W4A16-MTP. Thanks @jetspark for the recommendation and the bits-per-byte numbers. Your component table matches how we built it: only the 36,288 routed-expert GEMMs are INT4 (GPTQ, symmetric, group size 128). Attention including the DSA indexer, dense layers 0ā2, shared experts, router, embeddings/lm_head, the vision tower and the MTP layer all stay BF16.
One difference being the b12x nightly with native MTP isnāt the stack we validate on. Our Spark recipe uses the drafter we built:
- Image:
ghcr.io/canada-quant/vllm-glm53-flash-sm121:v2-w4a16-dflash2e(public, aarch64). Launcher and quickstart: canada-quant/vllm-glm53-flash-sm121 - Drafter: canada-quant/GLM-5.3-Flash-DFlash2-G, our own DFlash2 drafter (Apache-2.0), K=7
- TP=2 + EP, fp8 KV, CUDA graphs on
The drafter matters most. On our 500-prompt holdout, the built-in MTP head accepts about 2.4ā2.5 tokens per step. DFlash2-G accepts 3.68 at K=7; incoaiās reference drafter measured 3.63 on the same hardware.
What our recipe measures on 2Ć Spark (llama-benchy pp2048/tg128, single stream):
| context depth | 0 | 4K | 65K | 100K |
| decode t/s | 31.4 ±3.5 | 30.7 | 15.3 | 10.0* |
*The 100K cell is from the 09-26 grid run; the rest are from a quiet re-run on 09-28. The depth-0 cell is tg32.
- Context: with DFlash2-G we serve 262K by default (366,749-token KV pool at 8 GiB fp8); the llama-benchy numbers above were run at 800K.
- AIME 2026 (n=120, max thinking, 131K budget): 85.0% (102/120), vs 80.0% for EXL3 under the same config on the same pair.
Cold boot on our image is 6ā10 min, so your 145 s with instanttensor + read_ahead_kb beats ours. Nice find.
@jetspark, if you can run the same llama-benchy grid on your b12x + MTP setup, weād love to see it next to ours. We havenāt measured our weights on b12x (with MTP or our drafter), and it may well be faster.
For anyone using the b12x build: this checkpoint needs the ignore-list workaround from eugr/spark-vllm-docker#403. The broad self_attn regex is safe here because nothing under self_attn is quantized. The narrow version is re:.*\.self_attn\.(f_a_proj|f_b_proj|in_proj_qkvgfab)$.
Weāve been running it 100% flat-out for days generating synthetic data, with great results.
What would be the current most recommended GLM recipe for 2 sparks?
I know I said I mostly cared about quality, but 10 t/s at higher context is oof levels of slow, I can only assume it goes downhill from there, too. I guess I will try out these TensorRT ones first.
here we go:
| decode t/s | 31.6 ±3.4 | 29.8 ±3.3 | 25.4 ±2.2 | 31.0 ±0.7 |
NOTE: gpu clock = 1700
cmd
tool-eval-bench --base-url http://jetspark01:8045 \
--perf-only --tokenizer canada-quant/GLM-5.3-Flash-W4A16-MTP \
--benchy-runs 2 --depth 0,4000,65000,100000 \
--concurrency 1,2
P.S. thanks for your quant :)
UPDATE:
I tried the canada-quant drafter hoping to free up some memory, since itās way smaller than the built-in MTP head: 6 GB vs 15 GB. Turns out it does the opposite. Itās 8 full layers, and each one keeps its own uncompressed cache for the whole context, so on long chats that cache eats way more than the smaller weights save. My usable context dropped from about 930K tokens to 330K, and 512K didnāt fit anymore.
On top of that it was 20-30% slower in non English, though faster on English code. So Iām sticking with MTP.
Well holy moly, this thing is indeed really fast. Or at least it feels fast. Unfortunately TensorFold doesnāt seem to report ongoing generation numbers, so itās hard to get any idea of how fast itās going on average per second or something. Will now start trying it on my actual dataset. Iām just hoping the output quality has not degraded. For some reason people found that MiaAI had issues with not scoring as high as entrpiās engine on code bench testing so Iām a bit wary about the quality. We shall see.
I switched from vllm to tensorfold without any modification and opencode and openwebui continued to just work.
Something thatās a bit weird: why does this default to a default max_tokens of ~32.7k?
Thatās just really low. The kv cache size is over 1 million, so itās just odd that it stops 1/30th of using it. I mean I guess thatās to make it easier to process 1m size contexts safely, so I guess thatās made for agentic work where it might need to keep a lot of previous work in context but each output could be low?
Either way for now I just bumped it to 1m for my ~120-150k token prompt size, but I guess to be safe I would set it to around 800k to give enough room for reasoning and then output. Itās kind of weird that the engine asks me this though I guess. VLLM just chugged along till each payload was done processing. I just noticed this one was stopping at almost exactly 100k chars of output every time which was mildly annoying because it was just silently botching every single request and I didnāt even know it.
Otherwise, still seems to be quite fast. I guess I will leave it open for a few weeks to see if it can just keep going like entrpiās engine did.
Have tested and found that on the 9GiB there is early OOM. Shirnk KV cache to 7730941132 and it stay megastable during long run.
And this is the new king.
Here are the results:
GLM-5.3-Flash on 2ĆDGX Spark ā variant T: technigmaai native TP2 (C6)
Follow-up to the K/K2/K-6144 series: this run moves from the kindlingai Mentat/Ray
serving stack to the technigmaai glm-5.3-flash-gb10-tp2-native recipe (@24ba8fb) ā
native vLLM multiprocess TP2, no Mentat/Ray, display-reserved KV carveout (+1.79 GiB), and
same pinned model bytes as everything before: nvidia/GLM-5.3-Flash-NVFP4 (NVFP4 W4A4
routed experts, BF16 attention/shared/MTP) + incoai/GLM-5.3-Flash-DFlash2 (k=7) speculative.
Weight snapshots were reused from our kindlingai run (identical vLLM build) ā zero re-download,
zero rebuild of ~90 GiB snapshots.
Profile (C6): MAX_NUM_BATCHED_TOKENS 6144 Ā· MAX_NUM_SEQS 6 Ā· KV_CACHE_MEMORY
7.2 GiB (7730941132 ā matching our proven kindlingai pin, NOT the recipeās riskier 9 GiB
default, see OOM note) Ā· max len 1,047,552 Ā· fp8_e4m3 KV Ā· DFlash2 k=7 Ā· TP2 over RoCE
(.23 head + .25 worker).
Headline ā wall-time and score/hour first (our decision metric):
T tool-eval high 278 pts/hr (ties K2, beats K 274 and K-6144 257) and
max 205 pts/hr (beats K-6144 185, K2 207 about equal) ā at quality high 92.0 / max 96.0,
the highest max score of the whole series (K 95.67, K-6144 95.0, K2 92.0).
Total wall for the 6-run tool-eval set = ~144 min (vs K-6144 157, K 147.9, K2 139.6).
Cold prefill +6% over K-6144 (2678 vs 2522 t/s), TTFT@262k ā9% (100.4 vs 110.5 s).
Method (identical harness to the whole series): cold-prefill+gen sweep, 64 points,
4096 ā 262 144 tokens, UNIQUE prompt per size (seed = size ā radix cold), streamed SSE
first-byte TTFT, forced 256-token gen; tool-eval-bench 3Ć high + 3Ć max, seed 42, hardmode,
α 0.7, per-request reasoning_effort.
ā± Wall-time & utility (the decision metric)
| Config | stack | high | pts/hr high | time/run high | max | pts/hr max | time/run max | total wall |
| T (this) | technigmaai native TP2 | 92.0±0.0 | 278 | 19.8 min | 96.0±0.0 š | 205 | 28.1 min | ~144 min |
| K-6144 | kindlingai TP2 b.6144 | 92.0±0.0 | 257 | 21.5 min | 95.0±0.0 | 185 | 30.8 min | 157 min |
| K | kindlingai TP2 b.4096 | 92.0±0.0 | 274 | 20.2 min | 95.67±0.58 | 196 | 29.2 min | 147.9 min |
| K2 | Mia TensorFold Ć4 | 92.0±0.0 | 278 | 19.9 min | 92.0±0.0 | 207 | 26.7 min | 139.6 min |
| D | eugr b12x | 91.33±0.58 | 230 | ā | 92.0±1.0 | 165 | ā | ā |
(all n=3 except historical A/B; equal quality on high ā the knob/topology moves only speed.)
ā± Cold-prefill sweep (64/64 ok, zero OOM on every config)
| Config | pp avg t/s | gen avg t/s | TTFT avg | TTFT@262k | KV pool (tokens) |
| T (new) | 2678 | 42.7 | 49.8 s | 100.4 s | 1,215,513 |
| K-6144 | 2522 | 38.2 | 53.7 s | 110.5 s | 1,165,254 |
| K | 2296 | 42.7 | 59.6 s | 129.8 s | 1,169,491 |
| K2 Ā· TensorFold | 1620 | 59.0 | 85.3 s | 181.4 s | 2,033,664 |
š Cold prefill per size (t/s) ā T vs the field
| size | K (4096) | K-6144 | T | Ī T/K-6144 | K2 |
| 4k | 2411 | 2610 | 2571 | ā1% | 1649 |
| 32k | 2360 | 2681 | 2627 | ā2% | 1765 |
| 64k | 2366 | 2501 | 2655 | +6% | 1729 |
| 128k | 2100 | 2552 | 2737 | +7% | ā |
| 196k | 2271 | 2497 | 2672 | +7% | ā |
| 262k | 2019 | 2372 | 2610 | +10% | 1445 |
T is the flattest prefill curve of the series: 2453ā2784 t/s across the whole 4kā262k
range (median 2676), no sag toward the long end. At 262k it beats K-6144 by +10% and
TensorFold by +81%. The only T losses are small and in the 4kā32k cold start zone (constant
multiprocess overhead); from 40k up it wins every point (55/64 across prefill & TTFT).
ā Generation (t/s, forced 256-tok single-stream cold)
| K | K-6144 | T | K2 | |
| avg over grid | 42.7 | 38.2 | 42.7 | 59.0 |
| @262k | 39.1 | 38.8 | 40.4 | 51.8 |
T restores the generation throughput that the kindlingai 6144 bump gave away (42.7 ā K,
above K-6144ās 38.2) while keeping the 6144-sized prefill win ā the best of both. Sprint
decode still served by DFlash2 k=7.
š¾ KV/context implications
- KV pool 7.2 GiB = 1,215,513 tokens (fp8_e4m3, block 2304, LBHNC). Same pin as kindlingai
ā same 2.33Ć headroom over the 500k window. - OOM note: the technigmaai C6 recipe ships KV 9 GiB (
9663676416), which on these
unified-memory boxes overflows real host RAM at ~155k (vLLMRuntimeError: cancelledā
EngineDeadError, client sees ConnectionError; boot log warns130 GiB needed, 117 free).
Pinning 7.2 GiB ā the value proven across K/K-6144 ā eliminates it. 300k sanity re-check
passes clean, sweep completes 64/64, tool-eval 6/6 with zero swap pressure. - TensorFold still holds the biggest KV headroom (2.03M) but pays for it in loaded-cache
parallel decode (llama-benchy d8192c4 ā 17 vs 26-28 t/s on kindlingai/T-style stacks).
šÆ Tool-eval details (n=3, seed 42, hardmode, per-request reasoning_effort)
| variant | high | max | spec-eff high/max (t/s) |
| T | 92.0 ± 0.0 | 96.0 ± 0.0 | 63.4 / 65.1 |
| K-6144 | 92.0 ± 0.0 | 95.0 ± 0.0 | 61.1 / 60.5 |
| K | 92.0 ± 0.0 | 95.67 ± 0.58 | ā |
| K2 | 92.0 ± 0.0 | 92.0 ± 0.0 | ā |
Tās max-effort quality (96.0) is the best measured on this farm, at the fastest high-effort
time (19.8 min) ā and its spec-decoding efficiency is up across the board (63.4/65.1 vs
K-6144ās 61.1/60.5 t/s).
Takeaways
- T is the new leader on both axes we care about: best max quality (96.0) and best
high throughput-per-hour (278 pts/hr, tied with K2). No other config has done both. - Native TP2 (no Mentat/Ray) is strictly better than kindlingaiās Mentat flavor at equal
knobs: +6% prefill, ā9% TTFT@262k, +12% gen, +3 pts/hr high ā on byte-identical weights,
no code changes, seed-reused snapshots. - KV pin portability warning: take the recipeās KV default with skepticism on
unified-memory 2ĆGB10; reuse your previously-proven pin and verify with a long sanity
prompt before the full grid. - If you are decode-bound with short prompts, TensorFold K2 (59 t/s gen) is still the pick;
for long-prompt/RAG/agentic ā T is now the fastest, highest-quality option.
Files / reproducibility
- Config:
compose/.envon both nodes, KV_CACHE_MEMORY=7730941132, MAX_MODEL_LEN=1047552,
MAX_NUM_BATCHED_TOKENS=6144, MAX_NUM_SEQS=6, API_PORT=8001, SERVED_NAME=glm-5.3-flash. - Recipe: GitHub - technigmaai/glm-5.3-flash-gb10-tp2-native: GLM-5.3-Flash NVFP4 on two NVIDIA GB10 nodes: native TP2, one container per node, display-backed KV and image input Ā· GitHub @ 24ba8fb, image
c748079-displaykv1-arm64-cu130.
Bottom line: swapping the serving topologie (Mentat/Ray ā native multiprocess TP2) on the
same model bytes, same batch-6144 profile, buys +6% prefill, ā9% TTFT@262k, restores gen to
K levels, and posts the best max-effort score (96.0) of the whole AāT series ā with zero
re-downloads and no OOM once KV is pinned to the proven 7.2 GiB.
Have you tried Gilesā engine above?
They are showing average prefill of around 1.85-2k. Generation speed seems to still be about the same.
Relinking engine for completeness:
Just wondering if youāre using an outdated tensorfold variant since your prefill numbers seem low. Overall, looking at your own charts, not sure if you can call it a clean win when Tensorfold variants are doing 38-39% faster gen though. I guess it depends on what you need the model to do.
I have used latest Miaās variant on this Friday. Will try to check in the night gilescoās version.
Itās output tokens, not max session length
I know, but that includes reasoning. On entrpiās engine, my task could reason for over an hour per input. I guess my issue is that I have to (like actually have to) manage output length as well as session length on this manually?
Anyhow:
[tensorfold] done req-a786c249a3a6 prompt=10 cached=0 thinking=False tokens=2 sha=694aab7656bc finish=stop tok/s=22.4 ttft=0.12s prefill=0.12s rounds=1 accepted=0/1
[tensorfold] 127.0.0.1 "POST /v1/chat/completions HTTP/1.1" 200 -
[tensorfold] done req-7e5ddeb869b2 prompt=124425 cached=0 thinking=True tokens=168270 sha=91774f45078c finish=stop tok/s=54.8 ttft=77.71s prefill=77.58s rounds=39095 accepted=129174/215637
[tensorfold] done req-6aca84fc73fc prompt=112713 cached=0 thinking=True tokens=700500 sha=a698a468ee60 finish=length tok/s=82.7 ttft=69.76s prefill=69.65s rounds=47633 accepted=652866/702503
[tensorfold] done req-e994cdb280b3 prompt=112713 cached=112704 thinking=True tokens=700500 sha=a698a468ee60 finish=length tok/s=83.2 ttft=0.13s prefill=0.10s rounds=47633 accepted=652866/702503
[tensorfold] done req-d609df6aee1a prompt=112713 cached=112704 thinking=True tokens=700500 sha=a698a468ee60 finish=length tok/s=82.7 ttft=0.13s prefill=0.10s rounds=47633 accepted=652866/702503
I woke up to find out that it hadnāt completed a single document outside of the first one. It proceeded to do long-form looping for the entire rest of the time and didnāt finish a single one.
grep '12049362 has' glm_logs_21.log |wc -l
510
Iāll restart to see if it was just a bad scenario exacerbated by repeated cache hits which then caused it to do that over and over again⦠but it was very clearly looping to the exact same point multiple times. Even if it was going fast, I would have also finished multiple documents by that point on the other engine without the looping. To be fair, itās a slightly tweaked version of my prompt meant to try to find something different, so that can easily cause looping.
Just increase to the size you need I guess. It was working for 8 hours non stop today running datamining on 4 different computers for me today (80 cores total to parallel massive work corpus)and building code, mending it, documenting, sending telegram notifications. No looping, no going crazy. BTW MediaLLMProxy has a solution for long reasoning and looping - check it out in my GitHub.
