I wouldn’t be so categorical. Both models are good, and I run them together. But if the choice is between the two with a limited number of nodes, I would definitely go with the GLM checkpoint from MiaAI with the dense layer adjusted to FP8, because DeepSeek’s two-node quantization does degrade model quality (in my view, it only makes sense as a working model at TP4 in its native quantization).
I’m going to test your hypothesis in-depth. Also against various GLM-5.3 serving stacks.
To give you idea → varying: max_tokens from 16384 up to 65536 with reasoning effort (high|max).
tool-eval-bench run --model glm-5.3-flash --base-url http://spark_cluster2.xxx:8000/v1 --backend tensorfold --seed 42 --hardmode --parallel 4 --temperature 0 --timeout 300 │
│ --max-turns 8 --trials 2 --scenarios TC-23 TC-40 TC-43 TC-51 TC-63 TC-74 TC-89 TC-98 TC-104 --backend-kwargs '{"reasoning_effort":"max","max_tokens":65536}' --label glm53-tf-max-65k-subset 2>&1 | tail -50
IMHO A proper harness selection per model (serving stack) and per (output) task is far more important nowadays.
Update
Tested it on the MiaAI TensorFold stack, TEB v3.0.1.dev7, 104 scenarios, temp 0/seed 42/parallel 4, 2 trials per arm:
- high @ 65,536: 94.0 ± 0.0 (196/208), median turn 4.9 s
- max @ 65,536: 91.0 ± 0.0 (190/208), median turn 10.2 s
Uncapped serving is for sure defensible for hard prompts; it just doesn’t explain or fix the TEB max gap.
By the way: my harnesses are set to 32k by default.
Depends on a task, I guess. GLM is exceptionally good, but I had to elevate 1 out of 3-4 tasks to Mr. Sol as GLM simply lacked depth. I don’t have to do that anymore with DS - it is at frontier level already, in my own experience far ahead new Terra, maybe lacking Sol and Opus but not by a mile. Much less gunsligner that it was pre 1017 but still bit wild comparing to GLM. GLM for sure is safer. But given DS speed gain with Zig stack (60-80 t/s single) I am working with it real time and correct when needed, instead of leaving GLM to cook slower and check end result
From my experience, DS will stop before GLM and declare it has a conclusion, just to be agreeable. Saying it has an answer even when it doesn’t is exactly what these synthetic benchmarks reward. GLM will just keep going until it hits your harness cap or restrictions, which scores as a fail even when it was on its way to the right answer.
As far as workflows go, “GLM’s keep churning and get steered to the conclusion” beats “Deepseek’s, I’ll decide what you meant to say, call it a conclusion, and look good on benchmarks.” I’d rather have GLM do nothing and try than have DS make helpful changes I never asked for or wanted. Sure, sometimes those changes happen to be helpful, but then it’s a gamble every turn.
My experience with 1017 is different. Been using it now for weeks for many hours a day usually in 2 parallel session.
Agreed, DS 1017 feels a lot like 5.6 Sol. Even on tasks that it doesn’t have a straight answer I found that any 5.6 model doesn’t do much better. 6.1 is definitely smarter but as you said not by a mile. I am running DS with native weights.
Based on my current experience (processing around 400 million input tokens per day), DeepSeek requires strict constraints within the prompt; otherwise, it tends to do more than what is actually requested. Achieving the opposite - getting a model to do more - is quite difficult with GLM. Consequently, DeepSeek offers greater flexibility. As a result, its operator gains more control levers, which is a good thing.
I recently had to temporarily dismantle one of my mini-clusters (which handle GLM) to return a unit via RMA (and I’m not sure how or when that will be resolved). As a result, I set up the latest available stack of Qwen 3.8 Flash Next (GitHub - myllmbox/qwen38-flash-next-recipe: qwen38-flash-next recipe for solo GB10 · GitHub) on a third device.
In terms of both feel and speed, it is very similar to DeepSeek. It also requires prompt-based constraints and occasional instructions to “think less.”
However, it utilizes a very interesting quantization method from NVIDIA, which has significantly improved the model’s reasoning capabilities. I highly recommend giving it a try and compare with the current top open weight models.
I concur - that is the case. But this is exactly what frontier models do too - they add pizzaz and try to guess what else I might have wanted. Medium level tasks given to Sol 6.1 with answers that can be found in the same codebase just looking at similar implementations are too easy to it - it built a whole harness to disassemble and de-obfuscate commercial platform DLLs (broker software) to find signatures of functions and how they behave that a part of public API but never documented anywhere. And got a perfect result 300k tokens later. And lately a similar task with DS41 1017 produced very similar behaviour - started to unpack dlls, deobfuscate code. Also successfully. I guess they did distilled it from Sol and Opus really really hard! Hey, I am lovin’ it (c) Macca D :D
Ill just leave this here as this is going to make GLM a spark king if true. Mia on X: "BREAKING: GLM 5.5 training traces show they might ship 32B, 122B and 256B variants 🔥🔥 If they DO ship a 32B, Qwen3.6-35B might finally be beaten! The next two weeks should be interesting 👀" / X
MIaAI-Lab just dropped new serving stack for GLM 5.3 Flash:
I know now how to call their style of development!
It’s PDD, Patch Driven Development!
Interesting. At first blush, it seems like a downgrade from their previous stack. What am I missing?
As I understand it, there’s no speed gain, or it’s small — the potential plus is only in parallel operation, but imho even 8 parallel instances, even working ones, in fact make real work impossible — so it’s really a downgrade (it seems)
possibly the tool calling problem is solved, but I doubt it, because the problem is in the quant itself, not in the pipe
I think as I said in the other thread, this is more about the move to zig, from python, which will continue to get the upstream Tensorfold updates.
It’s my speculation, but if performance still isn’t there, it won’t be for this model unless someone will target this model specifically. New models will get all of the attention like fresh deepseek now.
Funny enough, this model is strong enough to implement features and fix it’s own stack (even in patch style, which should be harder). In my setup I simply have Stix Halo Qwen 3.8 Flash act as main agent, send work to GLM is subagent and Qwen restarts/roll back if it goes black after fixes :)
The effort is not lost (on optimising engines for old models), the effort translates to less work getting up to speed with later revisions.
Sure - everyone is away at the moment reaping the benefits of Deepseek 4 1f-1031, but they’ll be back before long looking at glm5.xf - and these engines will be more ready for that.
Ah, we don’t know. If new GLM is architecturally different enough, than support of old GLM is doomed. Also first hand I’ve been optimizing kernels before, testing on previous models of the same family was such a hassle, so I dropped it completely and only kept my improvements local.
TBH, current current mia or yours (python tf) is good enough I would say. There is this invisible line of 50-60tps thinking that makes it not bother you :)
Yeah - you have points there.
For me this is an experiment - make the model autonomously improve it’s engine 24/7. Once it reaches parity with the previous revision, switch the develop model with the one in production, rinse repeat. I am doing this with glm as it seemed to be the first model capable without going down an invisible rabbit hole.
Been there, done that :)
I think pragmatically better to give it to Opus/Astra on Max :)
And problem with auto-research you describe I hit is inevitably any model will hit a point when fusion/decomposition alters math, model will report like here we have KLD difference/Perplexity difference because of changes math and bla-bla-bla.
The problem that to prove that model isn’t getting dumber because of this requires to rerun all serious benchmarks (cause effect of changing distribution over one token prediction is as crude metric as it can be) and none of us have resources of frontier lab to do this.
We just test our luck :)
Yeah, I dont do cloud AI mate.
