GLM 5.3 Flash Intel AutoQuant W4A16 TP2 MTP3 - Concurrent Agentic Use
I decided to start a new topic, because the existing 400+ posts topic contains a wild mix of multiple different recipes for different use cases already.
Key fact Value
Model Intel/GLM-5.3-Flash-W4A16-AutoRound
Weight quantization AutoRound W4A16, adapted to GPTQ-compatible metadata
Weight kernel Marlin
Parallelism Tensor parallel 2 over ConnectX-7
Speculative decoding Native MTP3
KV-cache dtype FP8 E4M3
KV-cache allocation 13.5 GB per rank
Logical KV capacity 1,920,956 tokens
Prefix-match unit 128 tokens
Retention interval 0 — reachable endpoints only; no periodic Mamba/SWA checkpoints
Effective cache blocks 4,608-token attention/scheduler blocks; 2,304-token Mamba blocks
Effective max context 1,048,576 tokens
Maximum sequences 6
Max batched tokens 8,192
GPU memory utilization 0.85
200K replay, MTP3 199,936 cached / 64 recomputed
8×200K evidence Passed under MTP3 using PMU128 cache stack
Observed throughput Roughly 1,100–1,500 prompt tok/s; up to 108 generation tok/s at C6
Tool evaluation 91/100 in the matched hard-mode MTP3 run at temperature 1.0
vLLM build 0.1.dev20051+g487ecf187
So here is my semi-custom recipe which uses the Intel AutoRound W4A16 Quant, adapted to vLLM-loadable GPTQ metadata, and MTP3 (performs significantly better than DFlash2 for reasoning heavy workloads).
It uses ghcr.io/tonyd2wild/vllm-glm53-flash as base image and includes a small patch series plus Tony’s SM121 kpool overlay to allow PMU128 and fix the prefix caching issues.
It’s likely not the fastest recipe (1100-1500 pp/s, max. 108 tg/s @ C6 for code heavy prompts) but unlike most other recipes I tried, it has enough cache capacity to retain and later recall 8x 200k contexts. The same PMU128 cache stack was directly validated at 8x 200k under MTP5; this MTP3 profile was directly replay-tested at 200k and has an even larger 1.92m-token pool.
It is also not optimized towards TTFT - there is no disaggregated PP & decode, so both share the same TP2 engine. During long prefills, due to the batch size chosen, parallel requests degrade to 2-5 tg/s.
The expected avg. prompt reprocessing is 82 tokens, whereas other recipes use 4,608-token cache granularity and average around 2,304 reprocessed tokens per consecutive turn. Some other recipes I tried were considerably worse (1 full block + partial block). This made them useless for my concurrent agentic use.
The low prompt reprocessing is bought with a retention setting of 0, meaning eligible intermediate checkpoints are retained sparsely. Prefix branches are therefore NOT possible unless the full context matches.
It can be adjusted if needed, but this changes the memory/capacity vs. branching/reprocessing trade-off. Anything lower than 64k (which many recipes use) limits prefix concurrency to 1-2 @ D100k.
Total KV pool is 1.92m tokens, but there is still at least around 2.5 GiB left on each multi-user-configured node (with nothing else running).
tool-eval-bench 2.6.x in hard-mode, seed 42, C4 and z.ai recommended settings (t: 1, topp: 0.95) yielded 91/100 (161/176; 74 pass, 13 partial, 1 fail). The safety gate still failed on TC-43 (I think the test itself is debatable).
I’m running this setup for a few days now with over 1B input tokens and around 5M output tokens so far. It has zero request errors or crashes and I haven’t seen it stall or loop.
awesome thank you! going to test this out
